Circular Diffraction Patterns: What is the Correct Diameter of the Slit?
The discussion focuses on calculating the correct diameter of a slit for circular diffraction patterns using the formula D = 2.44(lambda)(L)/w. A user attempted to solve for D and arrived at a value of 0.120 mm but questioned its accuracy after receiving incorrect feedback. Another participant suggested checking previous answers for potential mistakes, particularly regarding decimal placement. The conversation emphasizes the importance of careful calculations and verification in physics problems. Ultimately, the user is encouraged to re-evaluate their calculations to ensure accuracy.
Brown Arrow
Circular Diffraction Patterns HELP!
theata_1=1.22(lambda)(L)/D L distance from screen, D diameter of slit
w=2.44(lambda)(L)/D
so this is what i did not sure where i went wrong maybe at rounding off...
w=2.44(lambda)(L)/D
(10.3/1000)=92.44)(633*10^(-9))(0.8)/D
solving for D i got the diameter to be the following
D=0.119962...mm
i rounded off to three significant figure
D=0.120mm is this correct b/c when i did this i got it wrong, could some one tell me where i went wrong this.
I agree with your answer.
ok ill try it again and see if it works
before you try it a again, there's an option to check what you put as your last answer, ^ might want to check that first before using an attempt
it worked, before i messed up the decimal place, now correct,
Thanks for helping Doc Al
Brown arrow.
  • · Replies 18 ·
