Circular motion as a 2D harmonic oscillator
The discussion centers on modeling the motion of a mass attached to two identical springs in a two-dimensional harmonic oscillator setup. The mass oscillates in both the x and y directions with the same amplitude A and is in phase, leading to a circular motion described in polar coordinates. The relevant equations include the differential equations for x and y, which are both given by \(\ddot{x} + \omega^2x = 0\) and \(\ddot{y} + \omega^2y = 0\). The solution reveals that the mass oscillates along the angle \(\pi/4\) with a radius \(r = A\sqrt{2}\cos(\omega t - \phi)\), indicating a fixed angle of oscillation rather than true circular motion.
  • Understanding of harmonic motion and oscillatory systems
  • Familiarity with differential equations, particularly second-order linear equations
  • Knowledge of polar and Cartesian coordinate systems
  • Basic grasp of complex numbers and their application in physics
  • Explore the derivation and application of polar coordinates in oscillatory motion
  • Study the implications of phase differences in harmonic oscillators
  • Learn about the transition between Cartesian and polar coordinates in mechanics
  • Investigate the role of damping in harmonic oscillators and its effects on motion
Students in mechanics courses, physics enthusiasts, and anyone studying oscillatory motion and harmonic systems will benefit from this discussion.
tjackson3
This is for my mechanics class. It seems like it should be easier than I'm making it.
A single object of mass m is attached to the ends of two identical, very long springs of spring constant k. One spring is lined up on the x-axis; the other on the y-axis. Chpose your axes and positions of the springs so that the equilibrium position of the object is at x = y = 0. The springs are long enough that if the mass is at x\hat{i} + y\hat{j}, then the restoring force is -k(x\hat{i} + y\hat{j}). Assume there is no damping in this problem, and feel free to make the substitution \omega = \sqrt{k/m}.
Problem: Assume that the oscillations in the x and y directions have the same amplitude A and are in phase. Describe the object's path in terms of circular coordinates.
There are more problems like this (one is out of phase by \pi/2, then one is out of phase and has a slightly different amplitude, and then a more general version of the problem), but I feel that if I can get this, I can get the rest.
To make the transition between Cartesian and polar coordinates,
<br /> x = r\cos\theta<br /> <br /> y = r\sin\theta<br /> <br /> x^2 + y^2 = r^2<br /> <br /> \theta = \tan^{-1}\frac{y}{x}<br />
My first instinct was to solve these problems as two separate differential equations and then combine them. The two differential equations were
<br /> \ddot{x} + \omega^2x = 0<br /> \ddot{y} + \omega^2y = 0<br />
Solving these gives
<br /> x(t) = A\cos(\omega t - \phi)<br /> y(t) = A\cos(\omega t - \phi)<br />
In polar coordinates, it seems like that would be r = A\sqrt{2}\cos(\omega t - \phi), but I can't figure out how to get the t out of there. I also tried making this into a complex problem, where z = x + iy = re^{i\theta} (although this way, I cannot figure out how to bring in the phase shift). Taking the last equality makes the differential equation become
\ddot{r} + 2i\dot{\theta}\dot{r} + r(\omega^2 - \ddot{\theta}) = 0
but if that's the correct approach, I have no idea how to solve it.
Thanks for any help you can provide! :smile:
Hmm... If they are in phase then that looks right. You will get an oscillation back and forth along a single axis. The radius will oscillate. Check \theta(t), you will see it not depend on time.
Thanks for your help! Two questions, though. Why will it oscillate along a single axis? Do you mean the "radial" axis (i.e. staying at a constant radius?). Further, the tough part about this whole problem set is getting it in polar coordinates. That implies that I don't have explicit dependence on time, but rather on angle. I can't seem to get time out of the equation.
Thanks again!
Since the x and y are in phase, then they will have the same magnitude at all times, even though their magnitude is time dependent. So you can imagine a mass oscillating along the +x,+y axis through the origin and along the -x,-y axis, and finally back again. No circular motion, just a simple 1D oscillation with A\sqrt{2} amplitude.
I see that you're right. I think I may be going about describing it in polar coordinates the wrong way. I don't think I'm understanding that part correctly.
Your polar coordinates are right. Although you never did solve for theta. You only solved for 'r'.
I suppose solving for theta is where I'm confused (plus it's still time-dependent). As a function of time, my guess is that
\theta - \tan^{-1}\frac{y(t)}{x(t)} = \tan^{-1}(1) = \pi/4
Where would that go in the equation? And is it okay to have explicit time dependence as well as implicit?
Edit: Or would it simply be z = A\sqrt{2}\cos(\omega t - \phi)e^{i\pi/4}? But there's still that time dependence...
In polar coordinates you have two coordinates, 'r' and 'theta'. So you always need to solve for both. You just solved for theta and showed it is time independent. So basically your mass will oscillate along the Pi/4 angle, since the angle is fixed.
When they are out of phase, then theta will become time dependent.
Right. I guess that's why it's bothering me that I have the time component that I can't seem to get rid of.
At least one of the coordinates need a time component. If they didn't, then the mass wouldn't be moving at all.
Oh right. Silly me. Thanks so much for your help!
