Circular motion of a rollercoaster car on a loop-the-loop
  • Thread starter Thread starter Jolene
    Circular Motion
The discussion revolves around the physics of a rollercoaster design, specifically focusing on the circular motion of a rollercoaster car in a loop-the-loop. The original poster is attempting to calculate the maximum radius of the loop based on a given top speed of the rollercoaster cars.
  • Participants discuss the equations of motion involved, particularly the forces acting on the rollercoaster at the top of the loop. There are questions about the realism of the calculated radius and the assumptions made regarding speed and forces.
There is an ongoing exploration of the assumptions behind the calculations, with some participants questioning the validity of using the top speed for the analysis. Guidance has been offered regarding the implications of speed at different points in the loop, and the discussion reflects a mix of interpretations about the problem's constraints.
Participants note the unrealistic nature of a calculated radius of approximately 240 meters, comparing it to real-world rollercoaster dimensions. There is also mention of potential friction losses and the need for clarity on the assumptions made in the problem statement.
Jolene
You are designing a rollercoaster and want to add an upside loop to it (a vertical circle). If the top speed that the rollercoaster cars can generate is 175 km/h, what is the maximum radius that you can make the loop so that the roller coaster does not fall off the track during the loop?
Fy= N + Fg = mac
Can someone please check if I got the correct answer. Thank you!
I got:
Fy= N + Fg = mac
N + mg = mv^2/r
g = v^2/r
r = v^2/g
r = (48.61)^2/9.8
r = 241.1 m
Jolene said:
Homework Statement: You are designing a rollercoaster and want to add an upside loop to it (a vertical circle). If the top speed that the rollercoaster cars can generate is 175 km/h, what is the maximum radius that you can make the loop so that the roller coaster does not fall off the track during the loop?
Relevant Equations: Fy= N + Fg = mac
I got:
Fy= N + Fg = mac
N + mg = mv^2/r
g = v^2/r
r = v^2/g
r = (48.61)^2/9.8
r = 241.1 m
:welcome:
Just typing in some formulas without saying what you are doing or what your assumptions are is not a good solution. Note that a radius of approx 240m is huge. The height of a tall skyscraper and 480m long. Does that answer sound realistic?
Show me a rollercoaster that reaches 175 kph … without any friction losses that in itself would require a height drop of over 100 m … The unrealism is already present in the problem statement.
The fastest rollercoaster gets to 240 kph. And the highest loop is about 50m. The problem is not that unrealistic, despite not taking mechanical energy loss into account.
A 480m high loop, however, is unrealistic.
@Jolene Can you figure out what you're missing here?
The point is that - given only the constraint of no negative g-force - that’s what you get if it travels at 175 kph at the top of the loop.
If it's 175 km/h at the top, it won't be the maximum speed it "can generate". Unless it is a powered car, with an engine.
Well, you already stated the obvious exception. We do not know what is actually assumed by the problem.
PeroK said:
:welcome:
Thank you for the quick respond and sorry for not being specific. Here's what I did:
I considered the total force of the rollercoaster at the top of the loop: Fy = N + Fg = mac
Then, I re-write the equation as: N + mg = mv^2/r
As N approaches 0 (at the top of the loop), v goes to v max (when n=0), , the equation becomes: mg = mv^2/rI Rearranged the equation to solve for r r = v^2/g
Lastly, I plugged in the numbers to find the radius when the speed is at its top speed. r=241.1m
If you read the other posts, you might see why that's an unrealistic analysis. Do you think the rollercoaster might slow down as it ascends the loop?
I'm so confused, isn't that why I used the rollercoaster's top speed for my calculation? So, is my starting equation Fy=N+Fg=mac incorrect?
Your equation is correct. However, "top speed" does not mean "speed at the top of the track." It means "the fastest the roller-coaster can ever move."
As an aside and for those interested, I found here an interesting little article about "real" roller coaster design.
Your equations are not wrong in themselves. But, they do not realistically model the motion of a rollercoaster.
I looked up on the Internet the fastest rollercoaster (which is faster than your one) and the highest loop, which is about 50m. That tells you that something has gone wrong somewhere in your calculations. Your loop is higher than the Empire State Building!
If a rollercoaster is doing 175 kph at the highest point, then won't it be going even faster when it comes back down?
PeroK said:
If a rollercoaster is doing 174 kph at the highest point, then won't it be going even faster when it comes back down?
That would depend on if it slams the breaks or not! 😉
  • Haha
