Circular Motion: Radial Distance vs. Period of Rotation
The discussion centers on the relationship between radial distance and the period of rotation in circular motion experiments. The user conducted an experiment using a string, a stopper, and a washer to measure the period of rotation at various lengths. They recorded data indicating that the period of rotation does not exhibit a linear relationship with radial distance, prompting the need for a calculated variant to approximate direct proportionality. The user seeks clarification on whether radial distance is directly proportional to the period of rotation and its implications for velocity.
  • Understanding of circular motion equations
  • Familiarity with experimental design in physics
  • Knowledge of direct proportionality and its mathematical implications
  • Basic skills in data analysis and interpretation
  • Research the mathematical derivation of the relationship between radial distance and period of rotation in circular motion.
  • Explore the concept of direct proportionality in physics and its application to rotational dynamics.
  • Learn about the effects of mass on circular motion and how it influences period and velocity.
  • Investigate graphical methods for analyzing experimental data to determine relationships between variables.
Students studying physics, particularly those focusing on circular motion, experimental design, and data analysis techniques.
Thereheis
This is not like a wheel where distance does not matter because a particular point will pass at the same time no matter how far down or up the wheel.
In this experiment, I used a string attached to a stopper (at the top) with a washer (on the bottom). There was a glass tube that I put the string through so I could place a piece of tape to indicate length. The piece of tape would help me keep a constant speed (if it moved I wasn't keeping a constant speed). I took down trials and recorded the period of rotation and the length that I had used.
Now what I am really getting to is this: Because my data wasn't completely linear, my teacher asked me to make a "calculated variant of my variable that best approximates a direct proportion." (Length vs. Period of Rotation)
and second
To derive the theoretical relationship between the period and my assigned variable (radial distance). Mass was constant
Period of Rotation and Length (cm)- .723 Length 31, .860 Length 41, .981 Length 45, 1.089 Length 57, 1.480 Length 62.
I am having trouble with the first one because we didn't use a mass. I've worked equations a lot to try and figure out what makes the Period directly proportional to the Radial Distance (I always end up with two unknowns, but I have to find the value for radial distance that makes it linear).
Circular Motion Equations
For my second part of the question I have it figured out i think:
M=mass of stopper m=washer
r=Mv^2/mg
Your description of your experimental setup is not at all clear to me. Perhaps a diagram would help.
Thanks for replying:
I think I've got it, the one thing I am stuck on is whether Radial Distance is Directly proportional to the Period of Rotation. If these two are directly proportional, does that mean they are each directly proportional to velocity as well? How do I figure the direct proportion?
