How to Calculate Maximum Angular Frequency for Blocks on a Spinning Turntable?
The maximum angular frequency for two blocks tied together on a spinning turntable is calculated to be approximately 1.81 rad/s. The inner block is positioned 4 cm from the center, while the outer block is 6 cm away. The coefficient of static friction between the turntable and the blocks is µs = 0.71. By analyzing the forces acting on both blocks and applying the equations of motion, the solution is derived using the relationship ω = √(µs(9.8 m/s²) + (1-µs)(9.8 m/s²)) / (6 cm).
  • Understanding of circular motion dynamics
  • Knowledge of static friction and its coefficient
  • Ability to draw and interpret free body diagrams
  • Familiarity with centripetal acceleration equations
  • Study the principles of circular motion and centripetal force
  • Learn about static friction and its applications in physics problems
  • Explore free body diagram techniques for complex systems
  • Investigate the effects of varying coefficients of friction on angular frequency
Physics students, educators, and anyone interested in understanding the dynamics of rotating systems and the application of friction in circular motion scenarios.
justagirl
Circular Motion - please help ASAP!
Two identical blocks are tied together with a string and placed along the same radius of a turntable that is spinning about its center. The inner block is 4 cm from the center and the outer block is 6 cm from the center. The coefficient of static friction between the turntable and the blocks is µs = 0.71, and the string is taut.
a) What is the maximum angular frequency such that neither block slides?
I've spent like 3 hours on this problem - drawing free body diagrams for both blocks, and trying to solve for angular frequency... no luck...please help!
When you read the problem it sounds like there is some complicated physics going on. However, drawing a correct free body diagram for both blocks simplifies the problem. The key here is that the blocks are connected with a string that is aligned along the diameter (or radius in other words) of the turntable. Therefore, we know that the tension in the string is in the radial direction.
The next problem is to determine in which direction the frictional force acts on the blocks. To do this pretend for a second that the two blocks each of mass m are really one big block of mass 2m. We know that the big block is rotating along with the turntable at angular frequency \omega (which is unkown obviously). Therefore, we know that there must be a radial inward force that is preventing the big block from slipping off the turntable. The only possible force at this point is the static frictional force. Thus, for the big block we have F_{radial} = -\mu_{s}2mg where the negative sign indicates that this force is radially inward.
Let's go back to the picture of the two blocks connected with a string. Let's draw a free body diagram for one of them (say, the inner block). We know from the previous paragraph that the frictional force will be radially inward. Since the string is connected to the outer block, we also know that the tension in the string is acting radially outward. Thus, the sum of forces on the inner block reads F_{radial, inner} = -\mu_{s}mg + T = -mr\omega^2 where T is the tension and r = 4 cm. Similarly, for the second block F_{radial, outer} = -\mu_{s}mg - T = -mR\omega^2 where this time T has a minus sign because it is acting radially inward on the outer block and R = 6 cm. You now have two equations with two unkowns: T and \omega. You can eliminate T by adding the two equations together. Then simply solve for \omega. The answer I got was \omega = \sqrt{\frac{2\mu_{s}g}{r + R}}.
Note that throughout this problem there are NO tangential forces on the blocks because the blocks are moving at the constant angular frequency \omega.
First, let's draw a free body diagram for both blocks. The inner block will experience a centrifugal force, Fn, directed away from the center of the turntable. The outer block will experience a combination of the centrifugal force and the tension force from the string, T. The friction force, Ff, will act in the opposite direction of the motion of the blocks.
Now, to find the maximum angular frequency, we need to consider the forces acting on each block. For the inner block, the maximum static friction force, Fs,max, will be equal to µsFn. Since the block is not sliding, this force must be equal to the centrifugal force, Fn. Therefore, we can set up the following equation:
µsFn = Fn
Solving for Fn, we get:
Fn = mg
Substituting this into the equation for the maximum static friction force, we get:
Fs,max = µsmg
Now, for the outer block, the maximum static friction force will be equal to the sum of the tension force and the centrifugal force. Setting up the equation, we get:
µsFn + T = Fn
Substituting in the value for Fn, we get:
µsmg + T = mg
Solving for T, we get:
T = (1-µs)mg
Now, we can use the equation for centripetal acceleration, ac = ω²r, to find the angular frequency, ω. Since the blocks are tied together, they will both have the same angular frequency. Setting up the equation for both blocks, we get:
ω²r = µsmg + T
Substituting in the values for r and T, we get:
ω²(6 cm) = µs(9.8 m/s²) + (1-µs)(9.8 m/s²)
Solving for ω, we get:
Plugging in the value for µs, we get:
ω ≈ 1.81 rad/s
Therefore, the maximum angular frequency such that neither block slides is approximately 1.81 rad/s.
