Class 3 Lever: Non-perpendicular Effort
4 replies · 2K views · last reply
Jimbo86
Hi,
We have a machine in our workshop in which we are modifying to relieve the amount of lifting force required by the hydraulic ram. This will subsequently reduce hydraulic system pressure which is the main goal. I'm trying to calculate the current configuration. It consists of a class 3 lever, with the effort applied at a 30 degree angle to the horizontal plane.
Handwritten lever diagram: a fulcrum at left, a vertical effort of 18,245 N applied at 90 degrees, a 5,150 N load at right, distances 0.35m and 1.24m, and a ? N effort at 10 degrees to the plane.
I've tried the following equation:
5150 * 1.24 * sin(10) / 0.35 = 3168N
I know the above is incorrect. At sin(90) perpendicular effort I need 18,245 N to lift the load. I would expect an answer of 3 to 4 times this with the effort applied at 10 degrees.
Please can someone point me in the right direction.
Many thanks
  • Handwritten lever diagram: a fulcrum at left, a vertical effort of 18,245 N applied at 90 degrees, a 5,150 N load at right, distances 0.35m and 1.24m, and a ? N effort at 10 degrees to the plane.
Hint..
N*Sin(10) must equal 18245
Rearrange to give N.
How about:
((5150 * 1.24) / sin(10)) / 0.35
This gives me 105,072.9 Newtons which equals 10.71 tonne.
Have I hit it?
Yes.
Although I'd work slightly differently it as...
Vertical component (Nv) of N =
(5150*1.24)/0.35 = 18245
Then
Nv = N Sin(10)
so
N = Nv/sin(10)
= 18245/sin(10)
= 105,068 Newtons
