"Classical Physics Is Wrong" Fallacy - Comments
142 replies · 17K views
Staff Emeritus
Homework Helper
Insights Author
Greg Bernhardt submitted a new PF Insights post
Continue reading the Original PF Insights Post.
Definitely worth saying. Asimov wrote an article in a similar vein (tip o' the hat to @Nugatory for introducing me to it): http://chem.tufts.edu/AnswersInScience/RelativityofWrong.htm
- "Classical physics is used in an overwhelming majority of situations in our lives." so what? do examples prove that a theory is correct? this argument makes no sense at all.
- "any new theory or description must somehow converge and look like the classical physics description under such ordinary conditions.". Who said this "must" be true? The point here is that SR and QM deal with different concepts of reality which are not accounted in classical mechanics. We are looking at the old theories with our "present" eyes. We can't interpret the past this way. The assumptions are totally diferent.
- "They have identical form!". Again: having the identical equation form proves what? that they have the same assumptions? that they work on the same space with the same properties? of course not!
It does not matter if you derivade classical physics from modern theories, they have different assumptions! they do not talk about the same thing!
If a new theory does not produce approximately same answers as the classical theory in the realm where the classical theory has been tested experimentally and demonstrated to be accurate then that new theory must not be correct.
Experiment is the final arbiter of correctness.
Of course the new theory will have to explain the old stuff, but it does not mean that it will "converge" at some point to the old one. there is no connection between the two things.
Apart from that:
- Newton considered space as an R³ euclidean and time as absolute.
- Mass and energy were not connected the way we know now.
- How would we explain the double slit experiment?
The assumptions can't be ignored.
I think you are rather missing the point. If you are traveling at 30mph down the road and a car passes you going 30mph faster, you can calculate its road speed using Newtonian or Einsteinian relativity. You will get the same answer to the precision you can plausibly measure. You need to take into account the velocity variation from flies crashing into the front of the car long before you need to care about Einstein. So simplifying the maths and using Newton isn't wrong. How can it be? Unless you're saying it's wrong to neglect the flies. And if you believe that then you will get nothing done ever.
I never said that Newtonian mechanics was wrong. never said that. I said that there is no such a thing as a convergence from a new theory to an old one based on some arbitrary limit as they start from different assumptions.
So your objection is to the term "convergence", taken as an indication that the new theory must, in the appropriate limit, be precisely identical to the old theory and not merely identical to within current experimental uncertainties.
Yes, that is certainly true. [Though precise agreement in the limit is what we have come to expect]
In Helen Quinn's essay in Physics Today, she emphasized the same issue:
We also know that they are not complete. Although they are well tested in some domains, in others uncertainties remain about their detailed application. Indeed, we expect that they will be modified or extended to explain new evidence. But they will not disappear; just as Newton's laws did not become invalid when we understood special relativity, but rather were seen to be a very accurate approximation under well-defined conditions. Theories such as those listed in the previous paragraph are strong enough that we can use them to say we know certain things - we know that protons and neutrons are composed of quarks and gluons, we know the relationship between mass and energy, we know that Earth's surface is not a single rigid structure. These are facts, but not just simple observational facts. They come from the amalgam of observation and theory development and testing that is the essence of scientific knowledge development. It diminishes the status of our understanding greatly to say that scientists "believe" these things. We know them!
When we seek to extend and revise our theoretical frameworks, we make hypotheses, build models, and construct untested, alternate, extended theories. These last must incorporate all the well-established elements of prior theories. Experiment not only tests the new hypotheses; any unexplained result both requires and constrains new speculative theory building - new hypotheses. Models, and in the modern world computer simulations too, play an important tole here. They allow us to investigate and formulate the predictions and tests of our theory in complex situations. Our hypotheses are informed guesses, incorporating much that we know. They may or may not pan out, but they are motivated by some aspects or puzzles in the existing data and theory. We actively look for contradictions.
There is an under-emphasis of the significance and importance of the claim that "it works!". Nothing is more powerful than having experimental evidence, and having it being verified and used every single day. Sure, as an experimentalist, I am probably very bias towards experimental evidence. However, this is what clearly separates science from non-science, and what makes acceptance in physics extremely difficult due to the requirement of having clear and convincing empirical evidence.
Zz.
Obtaining examples where a theory works or doesn’t work is the whole purpose of experiments in the scientific method. We don’t usually use the word “prove”, but examples do verify or falsify theories.
Thank you for an enjoyable, edifying read.
@ZapperZ great article! This is why, more than 100 years after Einstein, students still learn Newton. I have had discussions with people who are convinced that because Einstein proved Newton wrong someone will eventually prove Einstein wrong. But future generations of students will still need to learn relativity even if a Lorentz violating theory is eventually verified.
Well obviously Newtonian mechanics is "wrong" since it does include relativity or quantum mechanics but that does not imply that it "shouldn't be used". Newtonian mechanics is "wrong" in the sense that it is not the real Universe but that does not imply that it is wrong for you to use it because usually the error intrinsic to Newtonian mechanics is small enough that you can safely ignore it.
I am sorry, but this is just ignorant and the limit is not arbitrary. Obviously you will not recover classical mechanics in the ultra-relativistic limit, you will recover it in the classical limit where speeds are much smaller than the speed of light.
In physics and any empirical science, a theory is nothing else than the sum of its predictions. This is why discussions on quantum mechanics interpretations tend to degenerate and people either leaving upset or agreeing to disagree.
Apart from that:
The first of these follows directly in the classical limit of SR. The second also falls out of the theory as separate conservation of mass and kinetic energy at small velocities.
When it comes to light it is very well explained using Maxwell's theory. When it comes to particles such as electrons, it is not a prediction of the classical theory but your logic is completely flawed. You have taken one of the shortcomings of the classical theory that inspired people to QM and presented it as a counter argument to the quantum theory having to reduce to the classical theory in the limits where we know that the classical theory works. We already know that the classical theory does not work in this limit and so your argument is empty. Essentially you argument to the statement "A must give the same predictions as B when C is true" is to say "but it does not give the same predictions when C is not true". We come back to your assertion that the limit is arbitrary which, again, is not the case.
Obviously it is not wrong. It has been experimentally verified by a large number of experiments.
People tend to think of experimental falsification as much stronger than experimental verification. But it is not. The fact that a theory later produces incorrect results in some new domain does not change the fact that it does produce correct results in the previous domains.
So “wrong” would be a description for a theory that is never correct in any domain. Other than that theories are “applicable” or not to a given domain, or they are more or less “general” than another theory.
Great article @ZapperZ . I especially liked the part where you talk about the thought processes of the public as compared to physicists (I would use the broader term "technically trained" instead of physicist) .
We usually discourage talk about philosophy here on PF. But in the meaning of the word, "thinking about thought" it goes the heart of your point. I believe that you are correct; that fundamentally different thought processes forever divide the technical and liberal views of our world.
What difference does it make if you get the old theory from an upper limit or any other arbitrary direction? My point was that SR is considering space and time as completely different things comparing to old mechanics. This does not make any sense. If I say that the assumptions are: time is relative and space is Riemaniann and you say: time is absolute and space is euclidian, how can we be talking about the same theory?
No, you are wrong. What I said was that the assumptions are different! If you look at how we treat all the experiments and particles / waves in quantum world, we see that space, time, energy and whatever are all different from what we knew from classical mechanics, which means, we cannot start to say that there exists a derivation from one to another, as they were talking, ever, about the same thing. Again, if you start with different assumptions how can you end up with theories converging at a limit that has been chosen to find a connection between them?
I am not saying that Newtonian Mechanics is wrong. this has nothing to do with being right or wrong. I'm talking about how do we explain an theory evolution without wanting to find convergencies that were created just to make understanding easier.
Actually, it does! That's the whole point of my writing the article, that we frequently have members here claiming that Newtonian mechanics is wrong, and questioned why we continue to use it! If you make no such claim, then the article wasn't meant for you.
You also read WAY too much philosophical implication to what the article had said. First of all, I never said anything about any "proofs" that one theory equals the other. All I did was show that, in certain limits or situation, one theory can reproduce the mathematical form of the other. None of what I had shown should be a surprise, because we all saw this in undergraduate physics courses!
Furthermore, we do not have to go to wide extreme to see this. Even within classical mechanics itself, the Newtonian mechanics and the Hamiltonian/Lagrangian mechanics already have philosophically different approach and "world view". And yet, they both arrive at the same mathematical form in describing the kinematics of a system.
Being able to show that something can be derived into a familiar form is a powerful and extremely useful argument. This is done in mathematics all the time. The ability to reformulate a differential equation into something that we know the solution of is done often. So it is no different here in physics. It says that the new idea can reproduce all of the results of the old ideas, and also shows why and where the old ideas may fail or no longer accurate enough.
Zz.
Uhmmm ... Are you serious or just trolling? Obviously it matters that you recover the old theory in the limit where the old theory is known to be applicable or if you do so in the opposite limit.
We are not. We are only talking about the limit of one of the theories. In the classical limit you do recover the very same things as the classical theory. That SR is applicable to a larger set of situations is not the issue here.
No, you are wrong. What I said was that the assumptions are different! If you look at how we treat all the experiments and particles / waves in quantum world, we see that space, time, energy e whatever are all different from what we knew from classical mechanics, which means, we cannot start to say that there exists a derivation from one to another, as they were talking, ever, about the same thing.
This is just wrong. As already illustrated in the actual Insight. You can start from different assumptions, but in the end what it boils down to is to make identifications of what concepts in a theory that correspond to the concepts of the previous. A theory is not its underlying assumptions - which can never be tested, it is its predictions.
I am sorry but you are not making any sense here. The point is that the "old" theory typically has made a large number of verified predictions that are well studied enough that we know how experiments behave in a certain range - at least to within experimental uncertainty. Under the same type of conditions, the "new" theory must therefore reproduce exactly the same results up to corrections that are smaller than the experimental uncertainty. This is what it means having the "old" theory as a limiting behaviour. It has absolutely nothing to do with what "basic assumptions" have been made, just about predictions.
Well, that's where we don't agree. I guess we are going nowhere here. anyway, thanks for the chat. I will think about the insights you all gave. see ya.
Physics is an empirical science and what you can test are the predictions of a theory. If two theories make fundamentally different "assumptions" but give rise to the same observables, then there is no way of telling them apart and for empirical purposes the two are identical. You can never test assumptions (unless those assumptions are directly observable - but other assumptions could also lead to those testable assumptions being predictions as well).
I don't know how we separate assumptions from predictions. If I say that space-time is an entity and can be distorted, if we can't find a way to test it, the theory won't last. In my point of view the assumptions will direct affect what we are going to observe.
When I started to discuss ZapperZ's article, my point was: If we want to explain why Newtonian Mechanics is not wrong, why do we need to use the convergence of new theories for that? that's where I do not agree, as I said on previous arguments. it makes no sense to me.
Newton had a set of problems and variables to think of, which pushed him towards some thinking pattern. Of course we all know now that he explained the world. Einstein had a different set of problems and the change on the assumptions modified a lot (cosmology and QM) what we know about the universe. The fact that Newtonian Mechanics works on our daily basis establishes only its boudaries of usage. And inside those boundaries, its correct within necessary precision.
You cannot "measure" spacetime. You can make prediction of the consequences of a particular spacetime geometry and then measure those consquences. This is what @Orodruin was referring to.
When I started to discuss your article, my point was: If we want to explain why Newtonian Mechanics is not wrong, why do we need to use the convergence of new theories for that? that's where I do not agree, as I said on previous arguments. it makes no sense to me.
First of all, it was MY article.
Secondly, it was written in response to members who claim that Newtonian mechanics is wrong BECAUSE it has been superceeded by QM and SR/GR. Read it again! It was written clearly as the impetus for the article. That is why I made the connection between the two.
Zz.
ZapperZ said:
First of all, it was MY article..
Oops. Sorry for that. I will read it again! I confused the avatars!
Some fundamental assumptions of classical physics have been called into question by experimental observations.
By working the math. A lot of things that we may verbally or philosophically consider different are mathematically equivalent. You may think that you are drawing an important distinction between Newtonian and Relativistic mechanics, but in the v<<c limit this distinction is only in your mind and does not appear in either the math or experiment.
The incorrect idea being addressed is that Newtonian mechanics is wrong because it has been superseded by correct theories: relativity and QM.
The point @ZapperZ is making is that Newtonian mechanics is actually a part of those assumed correct theories. Those theories both converge to Newtonian mechanics in the appropriate limits, so Newtonian mechanics cannot be wrong if those other theories are right: it is part of them and implied by them.
I'm a bit puzzled by this discussion too. It is indeed true that most results of engineering are using classical physics to construct machines etc. making our lifes convenient. Obviously classical physics (i.e., all physics, including relativity, which is not using quantum theory) works very well in its range of applicability. This is ensured by the empirical method, i.e., that theoretical claims have to be tested in experiments and careful quantitative observations of Nature.
It is of course clear that any application of, e.g., classical electrodynamics uses relativity since classical electrodynamics is a relativistic classical field theory. The matter is treated phenomenologically in terms of continuum mechanics (entering the Maxwell equations in terms of charge-current densities) and using some phenomenological "transport coefficients" like electric conductivity, electric permittivity, and magnetic permeability.
Another question is, why this works so well, given the fact that indeed the most fundamental theory is Q(F)T. The answer is that in everyday-life we encounter macroscopic situations, where we don't need to describe the relevant degrees of freedom microscopically, which is not even possible because we cannot handle the about ##10^{24}## degrees of freedom of one mole matter anyway. The relevant degrees of freedom are the usually slowly varying collective observables like the center of mass (momentum) of a body or the thermodynamically averaged electromagnetic charge-current-magnetization distributions of matter and quantities like this. The usual constitutive phenomenological laws of electromagnetism, all involving transport coefficients that can be derived from quantum-many-body theory and the appropriate coarse-grained approximations leading to Boltzmann/BUU equations or viscous (or even ideal) (magneto-)hydrodynamics, are derived from linear-response theory or, if necessary, beyond.
This indeed implies that there is no contradiction between the fact that in many everyday situations classical physics is an excellent effective description of what's going on and it can very successfully be used in engineering.
By 'classical limit' do you mean the slow speeds for which we now regard classic physics as providing a good approximation? If so that appears to be a modern definition of 'classical'. Newton, for example, did not regard his theories as so limited.
That’s because he didn’t know any better. WE now know the limits where it is valid.
This is true for anything. We now know more than before on a lot of things.
Zz.
