Classical physics Time dependent vector calculation
2 replies · 3K views
wavecaster
If A is a time dependent vector, calculate
[itex]\int_{t1}^{t2} dtA(t) \times \frac{d^2A}{dt^2} [\itex]<br /> <br /> <h2>Homework Equations</h2><br /> <br /> <br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> I think we should somehow relate it with something's derivative.<br /> <br /> \int_{t1}^{t2}A(t)\frac{d^2A(t)}{dt^2}dt=<br /> A(t)\int_{t1}^{t2}\frac{d^2A(t)}{dt^2}dt-\int_{t1}^{t2}\frac{dA(t)}{dt}\left ( \int \frac{d^2A(t)}{dt^2} \right )dt=<br /> A(t)\frac{dA(t)}{dt}\left.\right|_a^b\int_{t1}^{t2}\left ( \frac{dA(t)}{dt} \right )^2dt=<br /> A(t2)\frac{dA(t)}{dt}\left.\right|_t_{2}-A(t1)\frac{dA(t)}{dt}\left.\right|_t_{1}-\int_{t1}^{t2}\left ( \frac{dA(t)}{dt} \right )^2dt[/itex]
$$\int_{t1}^{t2}A(t)\frac{d^2A(t)}{dt^2}dt=
A(t2)\frac{dA(t)}{dt}\left.\right|_{t_2}-A(t1)\frac{dA(t)}{dt}\left.\right|_{t_1}-\int_{t1}^{t2} \left ( \frac{dA(t)}{dt} \right )^2dt$$
Your notation is a bit horrible, you really should not write ##A(t)## outside of the integrals and you are missing the ##\times## from the original expression - making it unclear whether or not it is a cross product or a scalar product. The approach with using partial integration does make sense (and in case of a cross product, what is ##\dot A \times \dot A##?). However, it is not necessary to use partial integration as you can rewrite ##A\times \ddot A## directly as the total derivative of something. What total derivative would have the given term as one of its terms? What would be the value of the other term?
