Hakkinen
- 42
An electron is accelerated through a potential difference of 2.044 MV. (a) find the kinetic energy, energy, speed (in c), and momentum classically. (b) Do the same relativistically.
Charge of the electron is ## e = 1.6 \times 10^-19 C ##
Rest mass is ## m_o = 9.1 \times 10^-31 kg ##
Rest energy is ## E_o = 0.511 MeV ##
Classical equations
## u = c\sqrt{\frac{2eV}{E_o}} ##
## T = qV = \frac{1}{2}mv^2 ##
## p = mv ##
## E = T+U ## ?
Relativistic equations
## T = qV ##
## p = γm_0v ##
## E = T+E_0 = γm_0c^2##
My only question with this problem is calculating the energy in each method.
Classically the electron's speed is calculated as approx 2.83c, so simply substituting in the known quantities you have:
## T \approx 2.06 MeV ##
## p \approx 1.6 \times 10^-11 \frac{eV}{c} ##
Now the total energy the electron possesses classically is just the sum of the potential and kinetic energies correct?
## E \approx 4.104 MeV ?? ##
Now relativistically:
Kinetic energy can be calculated with the same formula ## T = qV \approx 2.06 MeV ##
I solved for γ in ## E = T + E_0 ##
## γ = \frac{T}{E_0} +1 = \frac{E}{E_0} ##
then ## β = \sqrt{1-\frac{E_0^2}{E^2}} \approx 0.98c ##
Now with the velocity we can find relativistic momentum and energy
## p \approx 2.8 \times 10^-11 \frac{eV}{c} ##
Now the relativistic energy is ## E = T + E_0 ## , is potential energy not included in the total relativistic energy? If the reasoning in the classical case is right, the electron would have more energy than in the relativistic case as the potential energy of 2.044 MeV would be added to it.
Relativistic E without U ## E \approx 2.571 MeV ##
with U ## E \approx 4.61 MeV ##
