Classical two-body problem-understanding
  • Thread starter Thread starter neelakash
    Classical
In the classical two-body problem, when one particle's coordinates are fixed, the other particle's motion is described using reduced mass and Newton's second law. The discussion raises questions about the inertial nature of the reference frame, particularly due to the interaction between the two particles, which may introduce radial acceleration. The concept of centrifugal energy is introduced, suggesting that the analysis may involve a rotating frame, complicating the understanding of forces at play. It is noted that while transforming to a center of mass frame can simplify two-body problems, this approach becomes inadequate in many-body scenarios where additional forces must be considered. The inquiry emphasizes the need to clarify the frame of reference when analyzing the two-body problem in the context of external forces.
neelakash
In a classical two body problem,when we superpose our origin of co-ordinates on anyone of the two particles,the other particle(now we see it to have reduced mass [mM/(m+M)],moves w.r.t. me...
I saw in a book #Central Force Motion, that the particle is treated by 2nd law of motion...
i.e. [mM/(m+M)]*a=F where a and F are accelen. and force term.
My question is how do we know that this is indeed an inertial frame?After all the two particles are interacting among themselves and there may well be a radial accelen.(Like in the case of Binary stars).
Another point is that we invoke the concept of centrifugal energy...
(=L^2/(2*mu*r^2)) where mu denotes the reduced mass.
Atam P Arya says that here we are working from a rotating frame as a penalty of eliminating theta from the equations...i.e. we are being bound to put this centrifugal force term(and hence a centrifugal energy) as we are working from a rotating frame...
I am having the fragrance...But cannot see the reality...
Please highlight on this topic.
If the entire universe is just these two bodies, and there are no external forces whatsoever, then there are no external forces. If you transform into a reference frame with the center of mass then with no external forces it is by definition an inertial reference frame.
However, this trick doesn't work if you're truly working with a many-body problem -- for example, if you wanted to calculate the effect of Jupiter's gravity on the Earth's orbit then transforming to center of mass only reduces your system by one degree of freedom but you're still left with too many degrees of freedom.
So what?
I want to know why do not we cansider that we are working from a non-inaetial frame while describing the 2 body problem interms of centre of mass.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 30 ·
  • · Replies 75 ·
  • · Replies 84 ·
  • · Replies 67 ·
  • · Replies 16 ·
