Classifying ODE's: What Determines Linearity and Order?
  • Thread starter Thread starter Lengalicious
    Classification
Lengalicious
When classifying an ODE do I just say whether its linear / non-linear and what order it is?
EDIT: Example: x2x'' + e-xx = t3 where x is function of t.
is this 2nd order, non linear and heterogeneous?
Also, would dx/dt = logte-x be homogeneous because both terms contain the dependant variable 't'?
There are some more classifications for (second order) odes, mostly based on the fact that the ode is solvable (or not) when it is of a certain class. I like the choice of the Maple software, which is pretty classic. The online description of odeadvisor giving you a classification is here:
http://www.maplesoft.com/support/help/Maple/view.aspx?path=DEtools/odeadvisor
Your first order ode is homogeneous, because it does not have a term that only depends on t. dx/dt=a(t)*x+b(t) is not homogeneous, but dx/dt = a(t)*x is. Your example is also separable, which means it can be solved using separation of variables.
so if dx/dt = logte-1, would that now mean that this was no longer homogeneous? Thanks for the help by the way.
Your equation is not homogeneous because of the t cubed term.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
