Clay falling onto a pan attached to a vertical spring
4 replies · 3K views
ultimateman
"A spring is hung from the ceiling. A pan of mass 100.0 g is attached to the end, which causes it to stretch 5.00 cm. Find the maximum distance the pan moves downward when a lump of clay of mass 120.0 g is dropped from a height of 40.0 cm onto the pan."
The correct answer, according to my teacher is 0.233 meters.
Conservation of momentum, perfectly inelastic collision.
m1v1i + m2v2i = (m1 + m2)vf
Conservation of mechanical energy.
MEi = MEf
PEg = mgh
PEe = 1/2 kx^2
KE = 1/2 mv^2
Work kinetic energy theorem.
Fnet d cosθ = 1/2 m (vf^2 - vi^2)
I tried a perfectly inelastic conservation of momentum + work-KE theorem approach.
m(ball)v0 + 0 = M(combined)v(final)
Fnet d cos(θ) = 1/2 M(vf^2 - vi^2)
where Fnet was the average spring force minus gravity, F = [k(0.05) + k(x)] / 2 - M(combined)g
d was (x+0.05)
and vf = 0, vi = root(2gh)
UPDATE:
OK so I tried conservation of mechanical energy after the collision to no avail. I did:
1/2 (.22kg) (1.53 m/s)^2 + (.22 kg)(9.81) x = 1/2 (19.62 N/m) (x+0.05)^2
Solving for x I got x = 0.225 m.
I still can't get x = 0.233m. I'm sure it's not a rounding error of some sort. What am I missing?
ultimateman said:
I have tried using a conservation of energy approach. This equation looked like:
PEg(ball) + PEg(pan) + PEe(spring) = PEe(spring, (x+0.05))
Mechanical energy is not conserved during the collision, so that won't work.
I also tried a perfectly inelastic conservation of momentum + work-KE theorem approach.
So far so good.
where Fnet was the average spring force, F = [k(0.05) + k(x)] / 2
d was x
You forgot about gravity.
Hint: After the collision, mechanical energy is conserved.
Actually I forgot to include gravity in my attempted solution post, but I did include it in my actual calculations already and I still got the wrong answer. : / But Fnet was the average spring force and gravity.
Thanks for pointing out that mechanical energy is not conserved during the collision. Obviously I should have seen that with it being perfectly inelastic.
Trying conservation of mechanical energy after the collision.
EDIT: OK so I tried conservation of mechanical energy after the collision to no avail. I did:
The left side of your equation is incomplete. You forgot the spring potential energy.
Derp...Ty!
