Closed flat space twin paradox
29 replies · 5K views
I'm not sure if this belongs here or in Cosmology - possibly either would do, I think. I was reading the thread about open/closed/flat universes that's currently ongoing in Cosmology, and a related question occurred to me.
According to post #7 you can have geometrically flat universes that are finite and unbounded if they have a non-trivial topology, such as a torus. Fair enough. Could someone explain the resolution to the twin paradox in this environment? It seems to me that I could sync watches with my twin as I pass him at constant velocity, circumnavigate the closed universe and return without having accelerated in either a proper or coordinate sense, since the geometry is flat.
Appreciating that there's ten thousand twin paradox threads here I had a quick search. This one seems to me to be saying that a flat FLRW spacetime is not a flat spacetime in the Minkowski sense of the word. I'm not sure if I've understood that right, though.
What don't I understand? For some context, I took a course in GR about fifteen years ago and remember not a lot and I'm currently on my second time through the first chapter of Carroll's lecture notes. "A lot" is a correct answer, but some precision would be appreciated.
on Phys.org
The resolution of the twin paradox in any environment is to calculate the proper length τ of the worldlines of the twins between the first and second meeting. The one with the longest proper interval has aged more. In fact the proper interval is exactly the time elapsed on the clocks.
c22 = c2dt2 - dx2 -dy2 - dz2
Simple innit ?
Interesting problem. I have never thought of this. I don't immediately see the solution. I don't have a problem with the existence of two timelike geodesics between the same two events, but I can make a naive argument for why each of them has a greater proper time than the other. I don't have time to think it through now. I will return later to see if someone else has posted the resolution.
I think it's sufficient to consider 1+1-dimensional flat spacetime ##\mathbb R\times [-1,1]## with -1 and 1 identified. The spacetime diagram from one twin's point of view would look something like this:
The vertical line is his own world line. The other two lines are actually just one line, because of the identification of 1 and -1. That line is the other twin's world line.
It's flat, but it's expanding.
Simple innit ?
But isn't the other twin's spacetime diagram just a reflection of the one I drew? Then this argument gives the same proper time for both.
I'm not sure what you mean, because you said both worldlines are shown on your diagram. But I don't see a problem with the twins having equal proper time.
Mentz - my problem is that, by my understanding, that if you transform Fredrik's spacetime diagram into the frame of the moving twin, you get an identical diagram, mirror-reversed. This is not the case in the regular twin paradox.
Put another way, since neither twin changes frame, both can claim proper time T and expect the other twin to have a lower proper time T', [itex]T'=\sqrt{T^2-D^2}[/itex], where D is the circumference of the universe.
Obviously something's wrong with that reasoning, but I don't know what.
Both lines are drawn in the diagram that shows the first guy's point of view, but I didn't draw the diagram showing the other guy's point of view.
I think I do, but the naive argument doesn't suggest that they're the same. It suggests that both are strictly greater than the other, i.e. ##\tau_A>\tau_B## and ##\tau_B>\tau_A##.
I think this shows that a flat spatially closed universe can't be locally Minkowskian if the principle of relativity is to be preserved. Or it can be locally Minkowskian but with a special frame of reference in which the closed dimension's length is maximum.
Off the top of my head, maybe both principles could be maintained if the closed dimension's length is not constant?
Simple innit ?
So, we calculated the proper intervals. It was easy, wasn't it.
I still can't make sense of this, and this
They seem contradictory.
This problem, having a twin move away and back along a curved geodesic, so that he does not accelerate, is called the "cosmic twin paradox". Of course, to have a curved geodesic- and especially a closed geodesic so that the twin can return- requires so very strong gravitational fields. It is the "equivalence" of gravitational fields and acceleration that resolves the paradox.
The resolution in the case of a torus is that space is only a torus in one particular rest frame.
If the universe is cylindrical in the x-direction, that means that looking out at the universe with a telescope, you see the Earth at x=0, and then it looks like a second, identical Earth at x=L (where L = the distance "around" the universe), and another one at x=2L, etc. So there is no observable difference between having a "cylindrical" universe and having a universe with repeating pattern of objects.
Now, let's consider what things look like in another reference frame. An observer in this frame will also see a repeating pattern of copies of the Earth. However, because the Lorentz transformations mix up space and time, the second observer doesn't see exactly identical Earths. (I actually shouldn't say "see" here, because what you "see" is light that left a long time ago. So I should really say "deduces", because what's relevant is what the observer deduces taking into account the transit time of light.) In the new reference frame, there appears to be:
  • One copy of Earth that is at [itex]x'=0[/itex]
  • A second copy of Earth at [itex]x'=\dfrac{L}{\gamma}[/itex] that is older than the first copy, by an amount [itex]\dfrac{vL}{c^2}[/itex]
  • A third copy of Earth at [itex]x'=\dfrac{2L}{\gamma}[/itex] that is older than the first copy, by an amount [itex]\dfrac{2vL}{c^2}[/itex]
  • etc.
How do I know this? Well, let [itex](x_1',t_1')[/itex] be the coordinates of some event at the first copy of the Earth. Let [itex](x_2',t_2')[/itex] be the coordinates of some event at the second copy of the Earth. By the Lorentz transformations:
[itex]\delta x' = \gamma (\delta x - v \delta t)[/itex]
[itex]\delta t' = \gamma (\delta t - \dfrac{v}{c^2} \delta x)[/itex]
where [itex]\delta x' = x_2' - x_1'[/itex], [itex]\delta t' = t_2' - t_1'[/itex], [itex]\delta x = x_2 - x_1[/itex], [itex]\delta t = t_2 - t_1[/itex]
Since the distance between copies of the Earth in the unprimed frame is [itex]L[/itex], we have
[itex]\delta x = L[/itex]
If the events are simultaneous in the primed frame, then that means
[itex]\delta t' = 0[/itex]
So that implies
[itex]\delta t = \dfrac{v}{c^2} \delta x = \dfrac{vL}{c^2}[/itex]
So from the point of view of the traveler, there appears to be a line of Earths, where each one is older than the last, and each one is a distance of [itex]\dfrac{L}{\gamma}[/itex] from the next. The people on these copies of the Earth appear to age slower by a factor of [itex]\gamma[/itex].
So to the traveler, it takes time [itex]T' = \dfrac{L}{v \gamma}[/itex] to travel from the first Earth to the next. The people on this second Earth start off older by an amount [itex]\dfrac{vL}{c^2}[/itex]. During the trip, the people on this second Earth age by amount [itex]\dfrac{T'}{\gamma} = \dfrac{L}{v \gamma^2}[/itex], which means that by the time the traveler reaches the second copy of the Earth, the people will be older than the people on the first copy when he left by an amount:
[itex]\dfrac{vL}{c^2} + \dfrac{L}{v \gamma^2} = \dfrac{vL}{c^2} + (1-\dfrac{v^2}{c^2})\dfrac{L}{v} = \dfrac{L}{v}[/itex]
(where I used [itex]\dfrac{1}{\gamma^2} = 1 - \dfrac{v^2}{c^2}[/itex])
So when the traveler goes from one Earth to the next, he ages by [itex]\dfrac{L}{v \gamma}[/itex] while the people on the second Earth end up older than those on the first Earth by an amount [itex]\dfrac{L}{v}[/itex]. So the traveler ends up younger than the people on the second Earth.
I don't understand why. A diagram shows the coordinate assignments made by one coordinate system. There are two twins, and therefore two comoving inertial coordinate systems. So there are two diagrams to be drawn, and I only drew one.
Nice, but I think I prefer the paradox.
I thought your diagram is a space-time plot. In which case one can put as many worldlines as as needed.
You've really baffled me now, we must be talking about different things.
OK, 'Stationary' frame
OK...
You just described a diagram with 2 worldlines on it . Unless 'that' line is somewhere else.
Yes, of course.
I'm just as baffled.
Mentz114 said:
You just described a diagram with 2 worldlines on it.
So? There's still another diagram to be drawn.
This is the point of the Barrow & Levin paper I just linked to. It also means that that particular rest frame is the only one where Einstein clock synchronization can be done between objects at rest in the frame. The difference in apparent age of the copies of Earth that you describe is due to a failure of clock synchronization in any frame moving relative to the "preferred" frame that is picked out by the topology of the spacetime as a whole.
Thanks to all for your answers. I'm a little annoyed I didn't spot the thread A.T. linked to, since the title is practically the same as the title of this one.
I had actually thought of a preferred reference frame as a solution, from a length-contracted circumference angle. I discarded it because it seemed such an anathema to Relativity. The "Hall of Mirrors" approach is a compelling argument that I hadn't quite clocked. A regular grid like that can't be invariant under Lorentz transformation, is the short way of putting it, I think.
Thank you all.
I don't see why. I'm impressed with the speed you put up your diagram, and I understand it represents an observer at rest and one looping around the closed dimension. Surely that's enough to read off the proper times of both observers ?
Relativity says there can't be a preferred frame built into the laws of physics. It doesn't say there can't be a preferred frame in a particular *solution* to the laws. That's what we have here: the particular solution we're considering has a preferred frame because of the closed spatial topology. It's really the same as the "hall of mirrors" view: the "grid" you speak of, which is not invariant under Lorentz transformations, is the preferred frame. But that frame doesn't appear in the laws: it only appears in the particular solution.
In the diagram I drew, twin A is stationary and twin B loops around the universe (to the right). A naive interpretation of that diagram is that it proves that ##\tau_B<\tau_A##. In the diagram I didn't draw, twin B is stationary and twin A loops around the universe (to the left). A naive interpretation of that diagram is that it proves that ##\tau_A<\tau_B##.
That is correct; flat FLRW universes are not flat spacetimes,
No, they are not flat spacetimes, i.e., flat FLRW universes have non-zero curvature tensors. In the context of FLRW cosmology, "flat universe" means the following.
Fix a moment of cosmic time, and consider the 3-dimensional space that results. This 3-dimensional space inherits a spatial metric (i.e., positive-definite) from the metric for 4-dimensional spacetime. The spatial metric can be used to construct a curvature tensor for the the 3-dimensional spatial hypersurface, and it is this curvature tensor that is zero for flat universes, not the curvature tensor for spacetime.
Further roiling the waters, it is possible to have a flat spacetime that is a non-flat FLRW universe (zero spacetime curvature tensor, non-zero spatial hypersurface curvature tensor; Milne universe)!
But you can't draw that diagram, because the surfaces of simultaneity aren't closed. That's what the failure of clock synchronization means. The only frame in which you can have closed, compact surfaces of simultaneity is the "preferred" frame. In any other frame, once you go out to a certain spatial distance from any given object that's at rest in the frame, you have multiple "copies" of that object with different clock readings. So you don't have a valid global inertial frame.
OK, I see what you mean. I also see that there is an asymmetry because of the closed dimension. It's not like one body orbiting another so the reciprocal diagram can't be drawn.
Thanks for the correction. I guess I was a bit quick on the keyboard there. A flat FLRW spacetime is called "flat" because space is flat (and expanding).
I knew it would pay off to be lazy and not think about this until someone just explains it to me. :smile:
