master_coda
- 591
- 0
Well, before you can find x0 and x2, you need to define an ordering. Given two infinite sets of sequences (call them a and b), how do you determine if [itex]a<b[/itex]?
Originally posted by Organic
a XOR b, don't you see?
a XOR b can be defined as Rseq=[a,...111)XOR(...000,b]
Rseq cunstructed by:
http://www.geocities.com/complement...iagonalView.pdf
yeah, the left endpoint. or do you mean mapped into by some kind of natural map rather than "is some member of."Let's make it simpler.
a is some arbitrary member (an infinitely long 01 sequence) of Rseq=[a,...111)
that goes without saying. in any interval G=(a,b), if x is in G, then x is not b.Therefore a cannot be ...111
doesn't b complete my interval G? you may want to go through either the dedekind cut or cauchy sequence of rational numbers construction of real numbers and tell us where the flaws in those proofs are.therefore Rseq cannot be completed
well, since ...111 completes the interval [a,...1), the premise above doesn't hold and so this conclusion doesn't follow., and therefore no transfinite number can use Rseq as its building-block.
this doesn't follow from the past premise even if it were true. your statement "no transfinite number can use Rseq as its building-block" doesn't mean that there is no building block for transfinite universes, just that Rseq isn't one. this is what the previous poster was saying.Therefore tranfinite univereses does not exist.
You're a little new here - have you seen all of the threads Organic started in the general math forum? You are right, but the only thing you'll accomplish by trying to explain it is headaches from banging your head against the wall. Organic is not interested in math - only in making up his own new math as he goes along.Originally posted by master_coda
No. Your argument is based upon your concept of infinity, not the mathematical one. Whatever contradictions you find in your concept have no bearing on mathematics.
No dear master_coda,
My last post clearly shows the problems that existing in Standard Mathematics about the transfinite definition.
Your last response is too weak.
NOW, YOU HAVE TO PROVE THAT MY CLIMES DO NOT HOLD.
You have no other choice, otherwise any response that can't clearly show why my argument does not hold, is meaningless.
And so far, I haven't even seen his point - math (to me) is a tool for use in science/engineering. I haven't seen where he's said what he wants to do with his new math once he's finished inventing it.
so if R=Rseq=N, then R=N. this can't be because not every element of R is an element of N. 1/2, for example, is an element of R but not N.Rseq is actually both R and N
english question: do you mean "My goal is to find a theory that can associate between a list two opposite descriptions or characterisitics?"My goal is to find a theory that can associate between at list two opposites.
