Difference Between Subgroup & Closed Subgroup of a Group
The discussion clarifies the distinction between a subgroup and a closed subgroup within the context of topological groups, specifically referencing the general linear group GL(2, ℝ). A subgroup is defined as a subset that satisfies group operations, while a closed subgroup must also be closed in the topological sense. The example of rotations by rational multiples of π illustrates a non-closed subgroup, as sequences of these rotations can converge to irrational multiples of π, demonstrating that the limit point lies outside the subgroup.
  • Understanding of group theory and subgroup definitions
  • Familiarity with topological spaces and concepts of open and closed sets
  • Knowledge of the general linear group GL(n, ℝ) and its properties
  • Basic grasp of sequences and limits in topology
  • Study the properties of topological groups and their subgroups
  • Explore the concept of limit points in topological spaces
  • Learn about the implications of open and closed subgroups in group theory
  • Investigate the structure of Lie groups and their representations
Mathematicians, particularly those specializing in algebra and topology, students studying group theory, and researchers interested in the properties of Lie groups and their applications.
LagrangeEuler
What is difference between subgroup and closed subgroup of the group? It is confusing to me because every group is closed.
In a book Lie groups, Lie algebras and representations by Brian C. Hall is written
"The condition that ##G## is closed subgroup, as opposed to merely a subgroup, should be regarded as technicality, in the most of interesting subgroups of ##GL(n,\mathbb{C})## have this property."
- Subgroup = subgroup in the group theoretic sense.
- Closed subgroup = subgroup in the group theoretic sense and closed in the topological sense.
I don't know if the author means "Lie subgroup" with "subgroup" though.
We are speaking about topological groups here, i.e. they are topological spaces. Now a subgroup is a subset, in this case a subset of a topological space. Hence this set can be open, closed, or neither. E.g. ##GL(n)\subseteq \mathbb{M}(n)## is not closed.
Edit: ... but neither a subgroup.
##GL(n)## is not a subgroup of ##M(n)## (think about which group operations you're using).
An example of a non-closed subgroup of ##GL(2,\mathbb{R})## is the subgroup of rotations by rational multiples of ##\pi##.
Thanks, yes. I only thought about the topology and forgot the group. Silly me.
Sorry, could you please explain that. Why this subgroup is not closed?
Because you can define a sequence of rotations by rational multiples of ##\pi## which converge to a rotation to an irrational multiple of ##\pi##: ##R_\varphi \circ R_\psi = R_{\varphi +\psi}\,.## You can add rational numbers to get an irrational number as limit.
If ##X## is a topological space, a subspace ##F## is said to be closed if the complement ##X\setminus F## is open.
Let ##S## be the subgroup I defined. Let ##A## be a rotation by a irrational multiple of ##\pi##. Then ##U:=X\setminus S## is not open because even though ##A\in U##, every neighborhood of ##A## contains rotations by rational multiples of ##\pi## (since irrational numbers can be approximated to arbitrary accuracy by rational numbers).
A little remark: Open doesn't imply not closed. Some connection components which occur often in those groups as covering are both, open and closed.
I did not say "open implies not closed". I said that its complement of ##S## is not open, so by definition ##S## is not closed.
I know, I just mentioned it as the OP explicitly has asked for not closed.
I understand the point but I am not able to see that. Why if you rotate for rational multiply of ##\pi##, you will get at one point rotation for irrational multiply of ##\pi##?
This is probably not related, but just to point out that in a topological group an open subgroup is always closed as well.
No, that is not the argument. The reasoning goes:
There are rotations ##R_{q_n \pi}## with ##q_n\in \mathbb{Q}## such that ##\lim_{n \to \infty} \prod_{n=1}^\infty R_{q_n \pi}= R_{\sqrt{2}\,\pi}##. That is, there is a sequence of rotations in the subgroup which converges to a point outside the subgroup, hence it cannot be closed as we have a found limit point outside.
What do you mean here? Why should ##SO(2, \pi \mathbb{Q}) \subseteq SO(2,\mathbb{R})## be closed (see example above)?
The claim was that open subgroups are also closed, ##SO(2,\pi\mathbb{Q})## is not open. For a proof, if ##H\subset G## is an open subgroup, and ##g\in G\setminus H##, then ##gH## is an open neighborhood of ##g## disjoint from from ##H##.
  • Poll Poll
  • · Replies 18 ·
