Collision involving blocks and pulley
73 replies · 9K views
TSny said:
Let ##r## be the length of the string on the left and ##s## be the length of the string on the right. Let’s take downward as the positive y-direction for both A and B. The 2nd law is
##\sum{F_{A,y}} = M a_{A,y}## and ##\sum{F_{B,y}} = M a_{B,y}##
Then ##a_{A,y} = \ddot{r} - \frac{v_A^2}{r^2} ##. No assumption is being made about whether or not ##\ddot{r}## is a positive or negative quantity. Solving the equations will determine the value of ##\ddot{r}##.
##a_{B,y} = \ddot{s}##. No assumption is being made about whether or not ##\ddot{s}## is positive or negative. But ##a_{B,y}## and ## \ddot{s}## must have the same sign if positive y is downward.
We have the constraint that ##r + s## = const. So, ##\ddot{r} =-\ddot{s}##. Or, ##\ddot{r} =-a_{B,y}##.
So, the 2nd law equations are
##Mg-T = M \left (-a_{B,y} - \frac{v_A^2}{r^2} \right )## and ##Mg-T = Ma_{B,y}##
Solving gives ##a_{B,y} = -\frac{v_A^2}{2r^2} = -\frac{g}{18}##. So, B accelerates upward at g/18.
Any further questions and I guess you would surely kill me :oldtongue: .
Thank you very very much :oldsmile: . I really appreciate your help .
You are very welcome. Your questions are always good. If you or someone figures out why the answer should actually be g/9, then please post it.
I assume "plastic" collision means inelastic ?
I do not like this type of questions "what happens just after the collision" . One can not know when is the collision finished and what is everything at that instant.
Anyway, the process is not instantaneous, something happens earlier and implies the other things to follow.
Here the collision happens first, block A gains a horizontal velocity, and then the tension changes in the vertical rope, and block B starts to accelerate. .
We can imagine the collision with the pan happening in a very short time. The pan has no mass, so the speed of the particle is reduced as block A is set on motion by the string between the pan and the block. The tension is the same both in the vertical and the horizontal parts of the string (it is massless) and the the radial part of the forces of tension are absorbed by the normal force of the axis of the left pulley which is fixed to the support.
Block A is accelerated horizontally during the collision by the horizontal tension, and it gains a horizontal velocity of magnitude U which is the same as the vertical velocity of the particle and pan.
It is an inelastic collision. So the particle on the pan and the block A will move together after the collision with speed U, the pan downward, A to the left. The speed of the particle before collision is v. v2= gL. Conservation of momentum says that 3/2 MU = M/2 v -->U = v/3.
Before the collision happened, the tension in the other string was Mg.
At the first instant, there is no displacement yet. A hangs vertically, and has a horizontal velocity - this is circular motion at that instant. To maintain that motion, the tension had to change The tension in the vertical string is T. The centripetal force is MU2/L=T-Mg.
T=Mg+Mv2/(9L)=Mg+MgL/(9L)=Mg+Mg/9.. The acceleration of B is determined by the upward tension and the downward force of gravity.
The problem does not asks what happens afterwards.
It seems to me that the assumption ##r + s## = constant is generally made for these idealized problems. ##r## is the length of the string on the left side of the pulley and ##s## is the length on the right side. Then ##\ddot{r} = -\ddot{s} = a_B##, where ##a_B## is the upward acceleration of B.
So, at any instant when B has a nonzero acceleration, ##\ddot{r} \neq 0##. But, ##\ddot{r}## is part of the acceleration of A.
So, it seems to me that we must have ##M \left (U^2/L - \ddot{r} \right) = T - Mg##.
That is, ##M \left (U^2/L - a_B \right) = T - Mg## instead of ##M U^2/L = T - Mg##
B starts to accelerate when the collision is completed.
A gains speed during the collision, but its position does not change yet. The length of the left piece of string is still L, and the force from the other string is perpendicular to it.
The tension in the long strings builds up because of the motion of A.
So the collision causes the velocity of A. The motion of A causes the change of tension in the long string. The change of tension causes the acceleration of B and also the radial acceleration of A, but that is not relevant for the problem. There is a lot of guessing, that is why I do not like such problems.
I analyzed this problem independently, and ended up with the same analysis that TSny presented. To implement the analysis, I assumed that the radii of the two pulleys are very small compared to the lengths of the ropes, so that I didn't need to take into account the effect of the change in the wrap angle on the kinematics of the motion. I confirm TSny's result of g/18.
Chet
I find this to be correct, which means the answer is g/9.
Let ##r## be the length of the vertical string between the pulley and mass A. The point of disagreement seems to be with how one answers the following questions.
(1) If block B has an upward acceleration just after the collision, then does that mean that ##\ddot{r} \neq 0## at the same instant of time? If not, why not? If so, then proceed to question (2).
(2) Since ##\ddot{r} \neq 0##, then doesn’t that mean that ##\ddot{r}## should contribute to the acceleration of mass A? If not, why not? If so, then proceed to question (3).
(3). [Edited to correct typo] If ##\ddot{r}## contributes to the acceleration of A, then doesn’t that mean that the acceleration of A just after the collision is ##v^2/r - \ddot{r}## rather than just ##v^2/r##? If not, why not?
It seems odd to me to allow the effect of the velocity of A to be transmitted essentially instantaneously by the string to B (and causing B to accelerate) while not allowing the effect of the acceleration of B to be transmitted essentially instantaneously back to A.
If you allow any "time delays" due to elasticity of the string, then the question becomes ambiguous. I think this is ehild's point and why he doesn't like the question. You could then argue that the acceleration of B is zero immediately after the collision since there has not been enough time for the effect of the collision at A to propagate to B.
TSny said:
the acceleration of A just after the collision is mv2/r−r¨mv^2/r - \ddot{r} rather than just mv2/rmv^2/r? If not, why not?
Why is m in these expressions?
The mass should not be there. Thanks!
So, the effect of the string accelerating is that the radius of movement of mass A is actually twice as long (2xl)? This would halve my tension to also give a=g/18 for mass B.
No, just after the collision the length of the string on the left side of the pulley is still ##l##. So, the acceleration of mass A due to its circular motion is ##v^2/l##. However, I believe there is an additional acceleration of A due to the acceleration of the string (##\ddot{r}##) associated with the acceleration of B.
But wouldn't that immediate additional acceleration immediately start mass A on a path different from a circle of radius l ?
The equations I obtained for time zero were:
Radial Force Balance from upper pulley to mass A:
$$T-mg=m\left[r\left(\frac{dθ}{dt}\right)^2-\frac{d^2r}{dt^2}\right]$$
where r is the distance between the upper pulley and mass A, θ is the angle that the rope segment from the upper pulley to mass A makes with the vertical, and T is the tension in the upper rope.
Vertical Force Balance on mass B:
$$T = mg+m\frac{d^2r}{dt^2}$$
If we combine these equations, we get:
$$\frac{d^2r}{dt^2}=r\left(\frac{dθ}{dt}\right)^2-\frac{d^2r}{dt^2}$$
Solving for ##d^2r/dt^2##, we obtain:
$$\frac{d^2r}{dt^2}=\frac{r}{2}\left(\frac{dθ}{dt}\right)^2=\frac{v^2}{2r}$$
In my judgement, this confirms TSny's g/18 result.
Chet
I too have same doubt. This question came in test papers of some coaching institution. And in the solution they simply wrote ##a=v^(2) /l.## I asked same question about the radial acceleration of ##M_{a}## here:(https://brilliant.org/discussions/thread/please-help-18/?ref_id=771297) but I didn't get any convincing answer.
Mass A is not pivoted about a fixed point so here mass A will not have centripetal acceleration only. So I think it is not evident to consider centripetal acceleration of block only. I think the answer should be ##g/18##.
Yes, it is my point. Collision between two bodies can be solved by applying conservation of momentum and the condition for energy but the problem is undetermined in case of three or more bodies without knowing how the mechanical deformation propagates in them.
In this problem, the pan gets an impulse. Its mass is negligible, so the impulse is transmitted to the string around the left pulley to block A.Block A hangs on the other string, and the tension in it just compensates its weight, so A starts to move horizontally. That is the outcome of the first stage of collision.
I do not know how you would solve the problem if all bodies take part in the collision instantaneously.
A nice example for collision among more bodies is Newton's cradle. What we see is that after the first ball hits the next, the last ball emerges. http://en.wikipedia.org/wiki/Newton's_cradle. That result is obtained if we assume collisions happening one after the other, between a pair of balls as if the balls do not touch each other. But they do. So the true solution would consider elastic wave traveling in the balls.
Block A hangs on the vertical string around the right pulley. If the pulley had mass the block was able to start its motion along a circle. So its motion would not change the length L0 of the string, but changes the tension in it. Well, the pulley has negligible mass, but the situation could be the same.
Assuming A moves horizontally with speed u. With TSny notation, r he length of the left piece of the rope changes as ##r=\sqrt{L^2+(ut)^2}##.
If t=0, the rate of change is zero, and the acceleration is ##\ddot r = \frac{u^2}{L }##. It implies that the second derivative of the right piece is the negative of it, ## \ddot s = - \frac{u^2}{L } = a_B##.
But my opinion is that such problems can not be solved and should not be given to high-school students.
For collision among more bodies, Newton's cradle is a nice example. The simple solution assumes that collisions happen between two balls, one after other, as if the balls do not touch each other. But they do, and the exact solution should include the propagation of the elastic wave inside the balls. http://en.wikipedia.org/wiki/Newton's_cradle
It seems to me that your expression for ##r## as a function of time is equivalent to treating A as moving along a horizontal line with constant speed just after the collision. Thus, A would have zero vertical component of acceleration. Another way to see this is to use the standard expression for radial acceleration in polar coordinates to write ##a_{A,y} = r \dot{\theta}^2 - \ddot{r}## where y is taken as positive upward. According to your result, ##\ddot{r} = \frac{u^2}{L }##. Therefore, ##a_{A,y} = r \dot{\theta}^2 - \ddot{r} = \frac{u^2}{L } - \frac{u^2}{L } = 0##.
But if ##a_{A,y} = 0##, then ##T-Mg = Ma_{A,y} = 0##. So, ##T-Mg = 0## for A. But then ##T-Mg = 0## also for B if we assume the tension is the same throughout the string. Therefore the net force on B is zero and B would have zero acceleration, which is not consistent with ##a_B = \ddot{r}##
But if ##a_{A,y} = 0##, then ##T-Mg = Ma_{A,y} = 0##. So, ##T-Mg = 0## for A. But then ##T-Mg = 0## also for B if we assume the tension is the same throughout the string. Therefore the net force on B is zero and B would have zero acceleration.
That is what I assumed. B does not accelerate during the collision between the falling particle, pan and A, but starts to accelerate after as consequence of the motion of A.
Of course, it is an approximation. In reality, everything is involved but then you have to take elasticity of the strings and mass of the pulleys into account.
How do you make ##a_B = 0## consistent with ##a_B = \ddot{r} \neq 0##?
aB=0 during the collision, aB≠0 after the collision.
There is some time delay before B starts to move. The limit of it is zero when the string is ideal. See the video when a ball collides with two others, connected by a spring. The collision happens between the touching balls, and the other ball starts to move a bit later, when it feels the tension built up in the string.
One way to get a handle on all this is to see what a simple model of the inelastic collision between the mass and the pan tells you. I have done such a model, by inserting a small viscous damper between the mass and the pan, and allowing the mass to hit the damper at the initial contact velocity ##v_0=\sqrt{gl}##. The force exerted by the viscous damper is given by ##F=C(v-v_p)=C(v-v_A)##, where C is the damper constant, v is the velocity of the falling mass during the collision, vp is the downward velocity of the pan at time t during the collision, and vA=vp is the horizontal velocity of mass A during the collision. From force balances on the falling mass m/2 and on mass A (m), I obtain:
$$\frac{m}{2}\left(\frac{dv}{dt}\right)=\frac{m}{2}g-C(v-v_A)$$
$$m\frac{dv_A}{dt}=+C(v-v_A)$$
Initial conditions are v(0)=v0 and vA=0.
If we neglect the term representing the weight of the falling mass during the very short time interval of the collision, the solution for the horizontal velocity of mass A as a function of time is found to be:
$$v=\frac{v_0}{3}\left(1-e^{-\frac{3C}{m}t}\right)$$
So, based on what I presented in post #44, during the collision, we have:
$$\frac{d^2r}{dt^2}=\frac{g}{18}\left(1-e^{-\frac{3C}{m}t}\right)^2$$
This result indicates that, at the beginning of the collision, the acceleration of mass B is zero, but at times ##t>>\frac{m}{3C}## (i.e., by the end of the collision), the acceleration of mass B is g/18.
Chet
The left rope also exerts force on A. (And you have to take the radial component of mg.)
And you think that this is significant on the time scale of the collision, correct? If so, do you think you can provide us with an estimate of what that radial force would be at say time t =4m/3C (when the collision is effectively complete, and the lower mass and pan are now traveling at essentially the same speed) so that we can compare it with the value mg/18? If you don't think you can do it, I think that I can.
Chet
I think it significant. I tried but I failed.
OK. I know how to do this, but I won't be able to get back here until later today.
Chet
OK. The objective is to get an estimate of the effect of the mg/2 portion of the tension in the lower rope on the radial component of tension in the upper rope. I'm going to start out by writing down the force balance equations on mass A, including the angulation effect of the two ropes (which was neglected in the previous development):
$$T'cosθ'-Tsinθ=ma_x $$
$$-T'sinθ'+Tcosθ-mg=ma_y$$
The first equation is the force balance in the horizontal direction, the second equation is the force balance in the vertical direction, the x-direction is to the left, the y-direction is upward, T' is the tension in the lower rope, and θ' is the angle that the lower rope makes with the horizontal. If we multiply the second equation by cosθ and the first equation by sinθ, and then subtract the first equation from the second equation, we obtain the component of the force balance in the radial direction:
$$-T'sin(θ+θ')+T-mg\cosθ=-ma_r=m\left[r\left(\frac{dθ}{dt}\right)^2-\frac{d^2r}{dt^2}\right]$$
The focus of the present analysis is the first term on the left hand side of this equation. Our first objective is to obtain an upper bound to the angle θ+θ' at the end of the collision, effectively at t =4τ, where t = (m/3C). If we integrate our equation for the x-velocity over this time interval, we obtain $$δx=v_0τ$$where δx is the x displacement during the time period. From this, it follows that the angle θ is given by:
$$θ=\frac{v_0τ}{l}$$
We can obtain an upper bound to the angle θ' by assuming that the mass A follows a circular arc, rather than also including the outward radial component of velocity along the upper rope. This will result in an upper bound to the predicted vertical displacement δy of mass A. So,
$$δ_y=l-lcosθ=l(1-cosθ)=l\frac{θ^2}{2}=\frac{(v_0τ)^2}{2l}$$
From this it follows that the angle θ' is given by:
$$θ'=\frac{(v_0τ)^2}{2ll'}$$
where l' is the horizontal distance between the lower pulley and mass A.
If we now sum the angles θ and θ', we obtain:
$$θ+θ'=\left(\frac{v_0τ}{l}\right)\left[1+\frac{v_0τ}{2l'}\right]$$
Note that, if the length l' is on the same order as l, the contribution of θ' to the sum of the two angles will be considerably smaller than the contribution of θ. If we substitute the equation ##v_0=\sqrt{gl}## into the the equation for θ+θ', we obtain:
$$θ+θ'=\sqrt{\frac{g}{l}}τ\left[1+\frac{\sqrt{gl}}{2l'}τ\right]≈\sqrt{\frac{g}{l}}τ$$
From this it follows that the contribution of the lower weight mg/2 to the radial component of tension on the upper rope is given by:
$$δT=\frac{mg}{2}\sqrt{\frac{g}{l}}τ$$
If the length l is 1 m, and the characteristic collision contact time is equal to ~0.001 sec, this equation predicts that δT≈0.0016 mg. This compares with the total tension of T=mg/18 = 0.055 mg calculated without accounting for the angulation of the ropes. With these values for the data, the contribution of the weight of the falling mass to the tension on mass B is on the order of a factor of about 35 lower than mg/18.
Chet
Thank you Chet. I will think it over.
Why an horizontal acceleration on A makes vertical acceleration on B at t=0 ?
This is a multiple choice task and must be answered by few or non calculations.
Because it is not a horizontal acceleration on A, but a horizontal velocity given to A at t=0, which gives A a centripetal acceleration.
See figure. If A travels horizontally, the left piece of the string gets longer, so the vertical piece has to shorten by the same amount. You can get the vertical acceleration of B ## \ddot y_2 = \ddot r ## in terms of the horizontal velocity of A.
