Collision of Spheres: Equal Acceleration?
Point Conception
If 3 spheres have equal masses and the stationary object is in a collision
with a sphere with linear momentum . p= mv and linear speed 3m/sec
And in the second case the collision with the stationary object is with a sphere with angular momentum L = rxp
With angular speed 1 radian/ sec , radius = 3m.
Does the stationary object in these two collisions have the same acceleration ?
You'd want to try each case using conservation of momentum, and angular momentum.
In general, if angular, as well as linear, momentum is involved, the effects of the collision will not be the same as for linear momentum alone.
Case #1 is an object at rest in a collision with an object with linear momentum p= mv
Case #2 is the same object at rest in a collision with an object with angular momentum L = rxp
My question is whether the object at rest in both of these separate collisions is
accelerated equally . All three objects have same mass. Case#1, object with linear speed 3m/sec
Case #2, object with angular speed 1 radian/sec. radius = 3m.
note: the underlying question is whether the stationary object is accelerated more in
the collision with object with angular momentum ?
How do you define your angular momentum, in respect to what point?
In case A there is also angular momentum, in respect to any point which is not on the ball's trajectory. And in case 2 there is linear momentum as well.
What is different in case 2? Is the ball spinning?
It depends on friction and, in the case of nonzero friction, on the collision point.
Without friction, the rotation does not change anything.
Consider 3 non-spinning billiard balls of equal masses:
#1 is moving in translational motion on the x-axis , v = 3m/sec , p=mv
#2 is at rest on x-axis at x=3m
#3 is in uniform circular motion in xy plane on a frictionless track at 3m from the origin, x0y0 L = rxp
In collision #1 there is one dimensional elastic collision at x =3m
So after collision v2 = (2m1/m1+m2)v1 , v2 for billiard ball #2
In collision # 2 the orbiting billiard ball is in collision with stationary billiard at x=3m y = 0
The linear speed of billiard ball in circular motion , v = ωr, (1 radian/sec ) (3m) = 3m/sec
So I am asking if the acceleration of the stationary billiard ball after collision in these two separate cases is equal ?
I don't see the relevance of the historic trajectory of ball #3. In the case of non-spinning billiard balls and inelastic collisions, all that ever matters are the initial/final masses/velocities. The two collisions will produce the same effect since these conditions are identical (apart from the orientation). Acceleration is not usually considered because it gets tricky to define a time interval of the interaction, and most of the time, all we need to use is conservation of momentum.
I'd also add that when you discuss angular momentum in the context of collisions, it is commonly assumed that you're referring to an axis of rotation which passes through the centre of mass of the body, ie. it's spinning. From the replies so far it seems that this is what everyone has understood of your question.
