Railway Engineering Curve Design Through Hallade Method
The discussion revolves around the Hallade method for railway curve design, specifically focusing on the derivation and understanding of certain equations related to angles and lengths in the context of railway engineering. Participants explore the mathematical relationships involved, including sine functions and their applications in curve design.
  • One participant seeks clarification on the derivation of equations related to angles in the Hallade method, specifically equations involving sine functions.
  • Another participant explains that the chord length is approximated as 2R sin(α) and the arc length as R * 2 * α, noting that this approximation holds for small angles.
  • There is a discussion about the relationship sin(β) = sin(2α) and its derivation using the double angle formula, with some participants questioning the assumptions behind the approximations used.
  • Participants discuss the importance of using radians instead of degrees in calculations, highlighting potential errors in earlier computations.
  • One participant presents an example involving an isosceles triangle to illustrate the concepts but is cautioned that it may not effectively verify the equations due to angle size limitations.
  • Clarifications are sought regarding the derivation of specific terms in the equations, including the factors of 2 and approximations involving cosine values.
Participants express varying levels of understanding regarding the derivations and approximations involved in the equations. While some explanations are accepted, there remains uncertainty about the correctness of certain assumptions and the applicability of the equations in specific scenarios.
Participants note that the approximations used in the equations are valid primarily for small angles, and there are discussions about the implications of using radians versus degrees in calculations.
Individuals interested in railway engineering, curve design methodologies, and the mathematical principles underlying these concepts may find this discussion beneficial.
tomtomtom1
Hello all
Please note: This is not a homework question. I work in Engineering.
Firstly Thank you for reading my post.
I am trying to learn a technique called Hallade which is used on the Railway to design curves.
I have some notes (attached).
The bit I fail to understand is on page 8.
Three equations are presented:-
1) Sin (Alpha) = 4V/C
2) Sin (Beta) = Sin(2Alpha)
3) Sin (Beta) = 8V/C
I understand how equation 1 was derived but I do not understand how equation 2 & 3 was derived?
I was wondering if anyone could help shed some light into how equation 2 & 3 was derived, please do not miss any steps.
I have been working on this for the last few weeks and got nowhere so I really appreciate any help you can give me.
Thank you for your help.
Please note: i have been informed by a few people that equation 2 could actually be wrong and should be Sin(Beta) = 2Sin(Alpha) but either way i still don't undertsand how its dervied.
Welcome to PF, tomtomtom1! :smile:
Your text says: "the versine is small in relation to the chord, therefore there is no practical difference between the arc and chord lenghts."
It also says this was previously stated, but I don't see that, and anyway, it is only true for angles alpha that are "small enough".The chord length is [itex]2 \cdot R \sin \alpha[/itex].
The corresponding arc length is [itex]R \cdot 2 \alpha[/itex].
So what they are saying is that [itex]2 \cdot R \sin \alpha \approx R \cdot 2 \alpha[/itex].
From this follows the approximate equality that you asked about.Alternatively you can see it this way:
[tex]\sin \beta = \sin 2\alpha = 2 \sin \alpha \cos \alpha = 2 \cdot {4v \over C} \cdot \cos \alpha \approx {8v \over C} \cdot 1[/tex]
You were kind enough to reply to my post on Railway Engineering Curve Design Through Hallade Method, thank you for this.
I was hoping you could explain your response a little as I am struggling to understand it.
You said “The chord length is. “ but you have not gone any further. Am I correct in thinking that the chord length is C?
Secondly you went onto say that “Arc Length = R * 2 * alpha”
Am i correct in thinking that R = Radius?
If that is the case then using an example where:-
R = 100000
Alpha = 5.739170477
Then Arc Length = 100000 * 2 * 5.739170477 = 1147834.095
Is this correct?
(I got 5.739170477 from a right triangle where the opposite = 10,000 and hypotenuse = 100,000)
You then said that “ 2 * R * Sine Alpha approx equal R * 2 * Alpha”
Using the same R and Alpha above, 2 * R * Sine Alpha = 20000
So 20000 does not approx equal 1147834.095
Could you shed some light on this?
If you can reply then I would be very grateful.
Thank you for you time and support.
Yes.
R = 100000
Alpha = 5.739170477
Is this correct?
(I got 5.739170477 from a right triangle where the opposite = 10,000 and hypotenuse = 100,000).
Yes. R = Radius.
But when you calculate with angles, you should use radians instead of degrees.
So you should use Alpha = 0.099668652.
Thank you for your reply.
You said that “ Sin Beta = sin 2 Alpha “
Where does Sin 2*Alpha come from, how do you derive it?
I must admit i am struggling a little with understanding the intuition, so I was wondering if we could use an example.
If we consider an isosceles triangle with the longest sides being 5 and the base being 8, the height being 3.
The angle that is made by the two longest intersecting lines (Beta) is:-
Beta = 1.854590436 (In radians)
What would Sin (1.854590436) = ?
Thank you for you help.
Let's take your isosceles triangle with the definitions for alpha and beta as given in your pdf file (that I can't seem to open any more btw).
Beta is the angle between the long lines of length 5.
Alpha is defined as half of that, the angle between the length 5 line and the length 3 line.
So beta = 2 alpha, and so sin(beta)=sin(2 alpha).
In your example, from the definition of the sine (sine = opposing / hypotenuse), you get: sin(alpha) = 4/5
Note that your example won't work very well to verify your equation (3), since it's only approximately true for reasonable small angles of beta.
Thank you for your reply it is starting to make senseand yes i am very slow (lol).
You mentioned the following:-
sin(beta) = sin (2alpha) = 2 sin(alpha) * cos(alpha) = 2 * {4v \over C} * cos (alpha)
approx {8v \over C} * 1
I know that 2 sin(alpha) * cos(alpha) was dervied from the double angle formula but could you explain the rest of it:-
Where does the 2 come from, from 2 * {4v \over C} * cos (alpha) ?
Where does the *1 come from, from {8v \over C} * 1?
And finally why can't we use cos instead of sin?
BTW i have attached the PDF notes again, hopefully you should be able to open it.
Thank you.
[tex]\sin(\beta) = \sin (2\alpha) = 2 \sin(\alpha) * \cos(\alpha) = 2 * {4v \over C} * \cos (\alpha) <br /> \approx {8v \over C} * 1[/tex]
tomtomtom1 said:
Where does the 2 come from, from [itex]2 * {4v \over C} * \cos (\alpha)[/itex] ?
The 2 that was already there (before the equal sign).
I only replaced sin(alpha).
tomtomtom1 said:
Where does the *1 come from, from [itex]{8v \over C} * 1[/itex]?
It's an approximation.
The cosine of a small angle is approximately 1.
For reference: cos(10°)=0.985.
Huh? :confused:
I don't understand your question.
Thanks serena i finally understand thanks to you.
You're welcome! :smile:
  • · Replies 29 ·
