Combining high frequencies to get a large frequency
  • Context: Undergrad
  • Thread starter Thread starter kmarinas86
    Frequencies Frequency
8 replies · 4K views
kmarinas86
"Combining high frequencies to get a large frequency"
"Combining high frequencies to get a large wavelength"
Is this possible? There will be constructive and destructive interference, but can there be anything that increases the wavelength?
What is a "large" frequency?
I think he means "to get a low frequency" and "anything that increases wavelength".
Ya... that's what i meant ... don't know why i didn't see that =p
Yes it is and its quit common. Radios use this to bring rf frequencies down to audio f. Piano tuners use this to tell when they're approaching the right string tension. Pilots use it to sync up twin engines on boats and planes. It's call a beat frequency. I bet wikipedia.org has something on it. take a look.
alex
The technique is referred to as heterodyning.
Heterodyning is also beginning to be applied to microscopy, to move spatial frequencies beyond the classical resolution limit back into the exit pupil. One way is off-axis illumination, but there are several:
Proc Natl Acad Sci U S A. 2005 Sep 13;102(37):13081-6. "Nonlinear structured-illumination microscopy: wide-field fluorescence imaging with theoretically unlimited resolution.", Gustafsson MG.
Interesting..
When coupling a fiber-optic bundle image transfer block to a fibre-optic faceplate on an image intensifier, we used to rotate the part to a place where the Moire patterns and other effects were minimum.
I noticed once that as the planes of fibres came to line up with the faceplates (bundles of hexagons) structure, I could make in the interference patterns, a clear image of the boundaries, including broken interfaces and distorted joins. Also, I could get several versions of these, getting bigger as I approached "zero beat".
This was about 15 years ago. I wondered at the time whether the effect could be used for microscopy, and now, whether what I saw is part of this.
