Comments on Double Slit Experiment for Accurately measuring distances?
The discussion revolves around the feasibility of using a double slit experiment setup, involving a webcam and a laser, to accurately measure distances for a project. Participants explore various methods, potential sources of error, and the implications of using different optical techniques, including interferometry and structured light, within the context of experimental physics.
  • Experimental/applied
  • One participant proposes using a webcam and laser to measure distances based on the interference pattern created by two slits, suggesting that error analysis could achieve high precision.
  • Another participant questions the ability to calculate distances accurately due to potential non-parallel alignment of the slits and screen, which could affect measurements.
  • A later reply mentions mounting the setup on an XY table to account for tilt, aiming for micron-level measurements.
  • Concerns are raised about the limitations of using fringes for measuring distances on curved surfaces, as well as the practical challenges of achieving precise slit separations with a CNC mill.
  • Participants discuss the coherence of the laser and its impact on measurement accuracy, with some suggesting that wavelength stability is a more significant concern than coherence.
  • One participant suggests using a Michelson interferometer for high-accuracy distance measurements, while others explore the idea of varying brightness in the laser beam to calculate distances based on phase differences.
  • There is a discussion about the accuracy of time-of-flight measurements and the potential for using structured light techniques derived from the double slit setup to improve measurement precision.
  • Participants also consider the use of a laser non-contact Atomic Force microscope as a novel approach to maintaining consistent measurements while scanning an object.
Participants express a range of views on the effectiveness and practicality of the proposed methods, with no clear consensus on the best approach or the limitations of each technique. Multiple competing ideas and concerns about measurement accuracy remain unresolved.
Limitations include potential inaccuracies due to non-parallel slits and screens, challenges in achieving precise slit separations, and the dependence on the stability of laser wavelength. The discussion also highlights the need for effective reconstruction algorithms when using structured light.
kevin99
I'm thinking about using two slits, a webcam and a laser to calculate distances for a project.
Usually you measure the distances between maxima but this can be easily measured in a dark room using Matlab and it's image processing routines.
I can create the slits and accurately measure them using an optical microscope.
Is this a good or bad idea? Using error analysis, I think I can get the distance down to 1 part in 1000 so 1mm over 1 m away or .5mm over 2m away.
Maybe I can combine it with a cheap interferometer and make it super accurate. Problem with an interferometer is that you can only measure within 1 wavelength.
Any comments?
Science news on Phys.org
If you go to:
http://www.ub.es/javaoptics/applets/YoungEn.html
I would know the wavelength of light of my laser, the distance between the slits (optical microscope), distance between maxima (camera+matlab+image processing toolbox), therefore I can calculate the distance between the plates accurately?
You have to account for the slits and screen not being parallel. If they titl as they move the spacing on each side of the maxima will change, easy to calculate out but might be a S/N problem.
For very small distance using something like Newton's rings and counting fringes is very common. It's easy to interpolate the position of a fringe centre to very high order with simple quadrature detectors.
Actually I was going to mount it on an XY table and scan both X and Y directions so I can easily account for any tilt.
I'm trying to get it down to 1micron measurement so I can render a 3d surface.
I can engrave slits about .002 inches in thickness and separations in increments of .0001 inches with a CNC mill.
Are there any cheap supplies of highly coherent laser pointers?
What other sources of error are there that I should look at?
the trouble with using fringes for this is that you need a finite size flat surface to act as the screen, so you can't easily measure fringe width on a highly curved surface.
There are some practical problems, firstl although the CNC mill has 1 thou increments it doesn't mean it can cut slits 1 thou apart. It's like your inkjet printer having 2000dpi, doesn't mean it can print object 0.5thou across.
Coherence of the laser isn't a problem - you are only looking at the central (white light) fringe. a bigger problem is wavelength stability which varies with temperature and mode hopping as laser light is scattered back into the diode.
For measuring the distance to a single point with high accuracy, I would look at a michelson interferometer - assuming the surface is reflective enough.
The single wavelength isn't a problem if you have a smoothly varying surface since you can keep track of how many times you have wrapped around a new wavelength. It is a problem if you have abrupt steps in the object.
The other solution is to vary the brightness of the beam in a sinusoidal pattern and compare the brightness of the returned and outgoing light. You know the speed of light, the frequency of the variation and so you can calculate time and distance from the phase difference - this is how the DIY red dot distance meters ( eg Leica Disto) work.
I've tested the CNC and made some pcb traces that are 1 thou in thickness so don't see a problem making slits the same width.
Time of flight measurements are not very accurate with cheap electronics. Even high end are only good to a few mm over tens to hundreds of meters.
What I was thinking is if the object is against a wall, the fringes will tell me distance to the wall. If there is an object in the way, the fringes will be distorted and I can calculate from the separation the image separation.
Most 3d laser scanners work on triangulation of a few laser lines with a CCD.
I figure I can get better accuracy with sharp fringes from a double slit.
The brightness variation phase wants aren't time of flight. You are just comparing the relative brightness of outgoing and reflected light - and since you are doing this continually over many phases it can be very accurate. Cheap ones work at the mm level because of limitations in the laser and need to have a quick measurement.
Are you talking about measuring distance form the fringe angle - or a structured light scheme where you project a grid or series of lines and look at changes in the shape?
This is good for complex curved surfaces.
Or multiple cameras looking at the same scene + strutured light.
For some amazingly accurate ones see Faro's products.
Thanks for the helpful comments.
I'm thinking about structured light but the structured light comes from of a double slit.
That way a very linear grid can be made with double slit and I can scan it across the object to fill in the spaces.
On the cheap I can make the slit for next to nothing and a cheap laser pointer and webcam are also cheap.
The XY ball screw translation stage I picked up off ebay for $30 and added my own stepper motors.
The main probelm with slits as structuredlight is that the brightness falls off quickly so you can only really use the middle few.
A cheap laser pointer will come with a little holographic line generator that might be better. The challenge is probably the reconstruction algorithms.
The other option if you are using lead screws and stepper is to make a sort of laser non-contact Atomic Force microscope!
Keep the slit fringes the same size on the object my moving the screws, you keep the distance laser-object fixed and read the position from the steppers.
Slow but simple.
  • · Replies 30 ·
  • · Replies 33 ·
15K
