Commutation of Vector-Potential and Field-Operator
  • Level: Graduate
  • Thread starter Thread starter Abigale
    Commutation
3 replies · 4K views · last reply
Abigale
Hello,
I am thinking for some hours about the commutation of the field-Operator/(annihilation-Operator): [itex]\Psi[/itex] and the vector-potential: [itex]\vec{A(\vec{r})}[/itex].
I have noticed in my lecture notes that [itex]\vec{A(\vec{r})}\Psi = \Psi\vec{A(\vec{r})}[/itex].
But I don't understand why they commute?
Thank u!
Abby
What is [itex]\Psi[/itex]? If it is a different field than [itex]\vec A[/itex] (such as a Dirac field or a scalar field), then it commutes with [itex]\vec A[/itex] by the usual quantization rules.
So this field-operator [itex]\Psi ^{\dagger}[/itex] creates a particle located at point [itex]\vec{x}[/itex]:
$$\Psi ^{\dagger} (\vec {x}) :=\sum_{\lambda} <\lambda|\vec{x}> a^{\dagger} _{\lambda}$$
And this Operator [itex]\vec{A(\vec{x})}[/itex] (Vector-Potential) creates a photon with momentum [itex]\hbar \vec K[/itex] an polarisation [itex]\hat{e_{\vec{K},\lambda}}[/itex]:
$$\vec{A(\vec{x})} :=\sqrt{\frac{2 \pi \hbar c^2}{r}}
\sum_{\vec{K},\lambda}
\frac{\hat{e_{\vec{K},\lambda}}}{\sqrt{c |k|} }
\cdot
\lbrace e^{i\vec{K} \vec{x}} a^{\dagger} _{\vec{K},\lambda}
e^{-i\vec{K} \vec{x}} a _{\vec{K},\lambda}
\rbrace
So why can I say that both operators commute?
Thank u!
Is the particle created by [itex]\Psi^\dagger[/itex] a photon, or is it some other kind of particle?
