Undergrad Commutator of Parity operator and angular momentum
The discussion revolves around the commutation relations between the parity operator in the x-direction (Px) and angular momentum in the z-direction (Lz). The initial calculation of the commutator yields conflicting results, but further analysis reveals that the two answers are indeed equivalent, confirming that [Px, Lz] = -2LzPx. The implications of these commutation relations suggest that energy eigenstates must be degenerate, as the presence of common eigenstates for both Px and Lz leads to a contradiction if they are non-degenerate. The conversation also touches on the nature of the parity operator as a Hermitian observable, with participants questioning the practical measurement of parity and its significance in quantum mechanics. Ultimately, measuring parity is complex, as it is a discrete quantum number related to conservation laws rather than a directly observable quantity.
dyn
Hi
I have seen an example of commutator of the Parity operator of the x-coordinate , Px and angular momentum in the z-direction Lz calculated as [ Px , Lz ] ψ(x , y) = -2Lz ψ (-x , y)
I have tried to calculate the commutator without operating on a wavefunction and just by expanding commutator brackets and I get [ Px , Lz ] = 2PxLz
Are these 2 answers equivalent and if so how do I get from my answer to the given answer ?
Thanks
With $$
P_x L_z = P_x (xp_y) - P_x (yp_x) = -x p_y P_x + yp_x P_x = - L_z P_x \Rightarrow P_x L_z + L_z P_x = 0
$$you get $$
[P_x, L_z] + 2 L_z P_x = 0 \Rightarrow [P_x, L_z] = - 2 L_z P_x
$$So indeed your ##-2L_zP_x = 2 P_xL_z##
Likes dyn
Thanks for that. The example then goes on to state that [ H , Px ] = 0 , [ H , Lz ] = 0 and [ Px , Lz ]≠ 0 implies that energy eigenstates must be degenerate. Any ideas why ?
The parity operator always confuses me. As a Hermitian operator I presume it is related to an observable. I understand (hopefully ! ) that when dealing with eg. the momentum operator and I take a measurement I get an eigenvalue giving me the momentum. But what does the parity operator give me ? can parity be measured ? Is it an observable ?
Thanks
If ##\ [H,P_x]=0\ ##, there exists a common set of eigenstates for these operators. Idem ##\ [H,L_z]=0\ ##. If energy eigenstates are nondegenerate, the common set for e.g. ##\ [H,P_x]=0\ ## with energy eigenvalue En would be one single state ##\ \left | n \right > \ ##. Since there is only one eigenstate of H, the common set of eigenstates for ##\ [H,L_z]=0\ ## with energy En would be that same state ##\ \left | n \right > \ ##.
So ##\ \left | n \right > \ ## would be a common eigenstate for ##\ P_x\ ## and ##\ L_z \ ## and therefore you would have ##\ [P_x,L_z]=0\ ## , a contradiction.
Likes dyn, PeterDonis and vanhees71
thanks for that clear explanation.
Can anyone help with the last bit ? I see the point of measuring observables to get eg. position , momentum , energy etc. I presume if you measure parity you get the eigenvalue +1 or -1. Is there any point to measuring the parity observable ?
Don't have the easy answer: you can't just look at parity on its own. @mfb ?
It's not so clear, what you mean by "measuring parity". At least, I don't know, how to measure parity for a given system. It's a discrete quantum number of states for a discrete quantity that's conserved under the electromagnetic and the strong interaction (but not by the weak interaction). You can only analyse, e.g., reactions concerning the conservation or non-conservation of the corresponding quantum number of the system, but there's no measurement device, just measuring parity.
Likes dyn
  • · Replies 57 ·
  • · Replies 32 ·
  • · Replies 33 ·
