- 150
Just like your original question about Point of View can have different meanings depending on context, the term "rest frame" can have different meanings and I'm not sure what you are asking about so I will try to give a bunch of different answers and you can figure out which one applies.whosapopstar? said:I might need to add some kind of 'intergalactic dust' to my diagram, in order to be able to ask what i want to ask, but still there is probably a distance to make, before i am sure, the scenario i want to represent, is coherent.
In order for that to happen, what i want to ask now, is this:
Regarding slow transport:
I do not understand how to separate into categories three 'kinds' of 'explanations' or 'terms' which are: 'slow transport', 'coordinate system', 'proper time' and 'rest frame':
1.It is a mathematical error to assume there is a rest frame.
2.There is no mathematical problem assuming a rest frame, but experimentally this rest frame never appears.
3.Under the mathematical description used by SR, which interprets experimental results, the term 'rest frame' has no meaning.
The biggest problem i might have, when trying to understand this, is related with number 3 and with the notion (that is probably an error of understanding on my side), that there is a legitimate situation where one can say: this or that question has no meaning, under such and such terms, conditions or situations.
I am saying all that, because i want to ask: under what 'kind' of explanation (1,2,3 or another or a combination) would this question fall:
Is the speed of light the same or is it not the same when moving 'between' the frames or reference? Does the speed of light change or does it not change when it is moving from one FOR to another?
Somehow, i had the notion, that the answer to that question is number 3: 'This question has no meaning', since a rest frame does not appear in experiments, or for other reasons. If this is the case, i don't understand what 'has no meaning' means, and i have to put some intergalactic dust in my diagram, so i can ask the question in more coherent terms.
These more coherent terms, are supposedly relevant, since they are, supposedly (and probably by error) able to bring up a scenario that proves, that you can only say: 'Yes light speed changes when moving between FORs' or you can say: 'No, light speed does not change when moving between FORs', and most important, that there is no 'middle' possibility e.g. to say that there is 'no meaning' to this question.
Between the time of Maxwell's equations and Einstein's theory of Special Relativity, scientists believed that light traveled at c only in a single rest frame that they assumed was fixed in space and absolutely at rest and they developed the Lorentz Ether Theory around this idea. There is nothing mathematically or experimentally wrong with this theory except, as you point out, it's impossible to identify that state of absolute rest but, almost assuredly, we are never at rest in it.
Einstein turned this all around and said you could consider any inertial state to be just like the elusive ether rest frame in which light propagates at c. This enables him to build up a consistent coordinate system involving both time and distances in which to describe and analyze any scenario we desire. As a result of this, it has become common practice to use the term "rest frame" to mean a frame in which an inertial observer is at rest. Nowadays, when someone uses that term, that is what they mean. So you will see people say, "In Alice's rest frame, Bob is moving at 0.5c," for example. Then they might say, "In Bob's rest frame, Alice is moving at -0.5c." But note that Alice and Bob are in both frames. We don't mean that Alice's rest frame is owned by Alice or exclusive to Alice in any way or that it gives her more insight into what she can see or measure.
Einstein also established a way to calculate how the coordinates for events in one inertial frame can be transformed into the coordinates for the same events in a second inertial frame moving with respect to the first frame but you only use one frame at a time. This process is called the Lorentz Transformation. You shouldn't think of an observer starting out in one inertial frame and then moving to another inertial frame. An observer can start out at rest in one inertial frame and then accelerate up to some speed, but he is still in that same frame.
So now getting to your questions about the speed of light in different frames. Just like you shouldn't think of an observer moving from one frame to another frame just because he accelerates, you shouldn't think about light moving from one frame to another frame. Remember, Einstein's concept of a Frame of Reference is one in which light is defined to propagate at c. So there is no question about the speed of light in any frame, it is c by definition. So when you start with one FoR to describe and analyze a bunch of events in a scenario, light is traveling at c in that FoR. If you use the Lorentz Transformation to transform the coordinates of all those events into a second FoR moving with respect to the first one, the speed of light is c in that second FoR.
The bottom line is that in Special Relativity, the speed of light in a frame has meaning because we give it meaning through a definition and, as such, it is not subject to experimental proof. Of course, if it didn't comport with reality, then it would be a useless theory, but that hasn't happened.
