Complex analysis - argument principle
The discussion centers on the argument principle in complex analysis, specifically regarding the change in the argument of a function h(z) as z traverses a closed contour. A participant expresses confusion over obtaining a change of 9π/2 in the argument, questioning how this could yield a non-integer multiple of 2π. Clarification is provided that the calculation should account for the entire contour, including the segment from iR to 0, which affects the total change in argument. After reevaluating, the participant realizes that the correct total change is 4π, leading to a better understanding of the argument principle. The conversation highlights the importance of carefully analyzing each segment of the contour in such calculations.
sweetvirgogirl
(changes in arg h (z) as z traverses lambda)/(2pi) =
# of zeroes of h inside lambda +
# of holes of h inside lambda
now the doubt i have is what happens when the change i get in h (z) is say 9 pi/2 ... because then i would have a 2.5 on left side of the eqn ... so do i round it up and and say the function will have 2 zeros? (assuming it has no holes)
Can you come up with an example where the change in arg h(z) around a closed curve is 9pi/2? Or anything that isn't an integer multiple of 2pi?
how can the change in argument, i.e. angle, be other than an integral multiple of 2pi, when you go around a closed loop?
okay ... so i believe i am doing something wrong then ...
f(z) = z^9 +5z^2 + 3
(i have to determine number of zeroes in the first quadrant)
i came up with the 9pi/2 ... i am sure i am doing something wrong ... i should be getting 8 pi/2, right?
It would help if you show your work, but I have a guess where the problem is. You are probably looking at the contour from 0 to R, then along the circle of radius R centered at the origin to i*R, then back to zero, (for some R sufficiently large). I don't think you took into account what happens to the argument from i*R to 0. What is f doing along this segment?
uhh ... sorry ...
now i am getting the answer quite fine ... just want to make sure what i am doing is right ...
so it travels 9pi/2 counting 0 to R and along the radius of R centered at origin... to iR ... but when it reaches iR, it travel clockwise to land on the positive real axis ... so i subtract that from 9 pi/2 ... which means in total... it has traveled 4 pi
That's essentially it. I'd expect more detail on the changes over the pieces of the contour, I assume you have but haven't posted (which is fine if you're happy with that part!).
sweetness and light, are you actually thinking about these many questions before asking them? it just seems that is unlikely given how many questions you are asking per day on different topics.
just a suggestion.
