[complex analysis] differentiation w.r.t. complex conjugate; does it make sense?
The discussion revolves around the concept of differentiability in complex analysis, specifically regarding the differentiation with respect to the complex conjugate. Participants explore the implications of using the partial derivative with respect to the conjugate variable and question the consistency of this approach within the framework of complex functions.
  • Some participants assert that differentiability of a function f: \mathbb{C} \to \mathbb{C} is characterized by the condition \(\frac{\partial f}{\partial z^*} = 0\), questioning the consistency of this characterization.
  • One participant suggests that the chain rule is applicable only if the functions involved are differentiable, indicating that the function g defined as \(g: \mathbb{C} \to \mathbb{C}: z \mapsto z^*\) is not differentiable.
  • Another participant raises a concern about treating z and z* as independent variables, suggesting that this only holds under certain conditions.
  • Some participants discuss the implications of Wirtinger calculus, noting that it allows for treating z and z* as independent, which leads to the Cauchy-Riemann equations being expressed in terms of these variables.
  • There is a contention regarding the validity of defining functions that map between independent variables, with some arguing that it leads to inconsistencies.
  • One participant proposes that while the function g is acceptable in a general sense, it should be treated carefully within the context of Wirtinger calculus, suggesting a distinction between the function g and its representation in terms of independent variables.
Participants express differing views on the treatment of z and z* as independent variables and the implications for defining functions. The discussion remains unresolved, with multiple competing perspectives on the validity and consistency of the arguments presented.
Limitations in the discussion include the dependence on the definitions of differentiability and the assumptions made regarding the independence of variables in the context of complex analysis.
nonequilibrium
Hello,
Differentiability of [itex]f : \mathbb C \to \mathbb C[/itex] is characterized as [itex]\frac{\partial f}{\partial z^*} = 0[/itex].
More exactly: [itex]\frac{\partial f(z,z^*)}{\partial z^*} := \frac{\partial f(z[x(z,z^*),y(z,z^*)])}{\partial z^*} = 0[/itex] where [itex]z(x,y) = x+iy[/itex] and [itex]x(z,z^*) = \frac{z+z^*}{2}[/itex] and analogously for y.
But anyway, does this make sense? More specifically, is it consistent? The thing I'm having trouble with is that it looks like that we can always make the differentation w.r.t. z* zero. For example, for clarity of my argument, define
[itex]g : \mathbb C \to \mathbb C: z \mapsto z^*[/itex]
then for the modulus function [itex]\frac{\partial |z|}{\partial z^*} = \frac{\partial \sqrt{z g(z)}}{\partial z^*} = 0[/itex] as g is a function of z and not z*.
Where is the mathematical error in this reasoning?
One possible answer is that the technique uses the chain rule, which only works if the functions are differentiable.
Concretely in my example g is not differentiable, so the ``[itex]\frac{\partial f}{\partial z^*} = 0 \Leftrightarrow f[/itex] is differentiable'' technique doesn't strictly apply.
But if that is the explanation, then you can never use the ``[itex]\frac{\partial f}{\partial z^*} = 0 \Leftrightarrow f[/itex] is differentiable'' technique to prove differentiability (as is often done and as is the sole purpose of the characterization), as you need to assume the differentiability for the requirements... (because if you don't, then you can construct examples as I did in the OP)
Any thoughts?
I'm a bit confused when you say that g is a function of z and not its conjugate, hence the partial must be zero. Doesn't that only work when the variables are independent?
The variables [itex]z[/itex] and [itex]\bar{z}[/itex] are linear combinations of x and y, so they can be treated as independent. This way of viewing things is called "Wirtinger calculus", and it is in this formalism in which the Cauchy-Riemann equations become [itex]\partial f(z,\bar{z})/\partial \bar{z} = 0[/itex]. See here.
However, I think that may have hit upon the error. The variables [itex]z[/itex] and [itex]\bar{z}[/itex] are independent, so the function g(z) is taking in z and returning the independent variable [itex]\bar{z}[/itex], which isn't possible.
Mute, I don't understand your exact objection. Are you saying that I'm not allowed to define such function g?
Yes. Your function takes in one independent variables and returns another independent variable. I don't think that's possible. If you want to treat z and z* as dependent, then the [itex]\partial f/\partial z^\ast[/itex] version of the Cauchy-Riemann equations just reduce to the usual form expressed in terms of x and y.
That doesn't really make sense though? How can there be a constriction on the functions that I'm allowed to define? So according to you, it's also illegal to use something like Re(z)? Where does it end?
The heart of the issue isn't even a complex-variables issue. Consider a function [itex]h: \mathbb{R}^2 \rightarrow \mathbb{R}[/itex]. If you have a function q = h(x,y), where q is the dependent variable and x and y are independent variables, how can you define a function p(x) that returns y (i.e., y = p(x))? If the variable y is independent from x, you can't - the two variables are independent, so you can choose the value of y regardless of the value of x, so x doesn't determine y at all, which contradicts the assumption that you can write y = p(x). That inconsistency is what prevents you from defining such a function.
When applied to the complex variable case, you have made a (formal) change of basis from x and y to z and z*, rendering z and z* independent variables. This is the Wirtinger calculus in which the Cauchy-Riemann equations take the form
[tex]\frac{\partial f(z,z^\ast)}{\partial z^\ast} = 0.[/tex]
If you are using this definition of the CR equations, then you are treating z and z* independently, which means you cannot define a function g(z) which returns z*. (A function like Re(z) could still be defined by (z+z*)/2).
Perhaps the confusion arises because we normally don't consider z and z* to really be independent, but when using the Wirtinger calculus, you are formally treating them that way. I myself am a bit foggy on why the Wirtinger calculus works, but if I recall correctly, it is in part because when you define a complex function as
[tex]f(z) = u(x,y) + iv(x,y),[/tex]
the functions u and v (presumably) have convergent taylor series for which you can formally let x and y themselves be complex variables, which allows you to treat z and z* independently. This is as far as my memory goes on this topic, though, so if you want exact details you will have to seek them out for yourself.
Okay I think I'm starting to see your point... It does seem really fishy to say that z and z* are independent variables, it doesn't make a lot of sense, but I suppose it's allowed if one can make it mathematically consistent...
But may I try to correct your point a bit more? You say I'm not allowed to define g as [itex]g : \mathbb C \to \mathbb C: z \mapsto z^*[/itex]? I don't think this can be correct, after all the CR characterization [itex]\frac{\partial f}{\partial z^*}=0[/itex] is used to show that functions such as g aren't complex differentiable. A more correct objection (correct me if you think I'm wrong) would seem to me to say that g as defined above is okay as a normal function, but in this Wirtinger calculus, complex functions now depend on both z and z*, and the corresponding function is now [itex]\tilde g : \mathbb C^2 \to \mathbb C: (z,z^*) \mapsto z^*[/itex] and for brevity one says, for obvious reasons, that [itex]g = \tilde g[/itex], which can be dangerous because you shouldn't apply the ``[itex]\frac{\partial f}{\partial z^*}=0[/itex]'' test to the LHS (i.e. g), but to the RHS (i.e. [itex]\tilde g[/itex]). Do you agree?
