Complex analysis help please (just a quadratic proof)
17 replies · 3K views
nate9228
Let A be complex, B be real. Show [itex]\left|z^2\right|[/itex]+ Re(Az)+B=0 only has a solution if and only if [itex]\left|A^2\right|[/itex][itex]\geq4B[/itex]. Then, assuming the above condition holds, show the solution is a circle or a single point.
General quadratic equation I think?
Well, as above, I know the general quadratic equation for z, but I am not sure if the absolute value thing affects it and otherwise I am lost. My suspicion is that the solution will be a real number and since all of the coefficients are real, when using the quadratic equation, you need to have what's under the radical be positive. Something along those lines I think. I, however, have no clue how to prove it somewhat rigorously.
[itex]z = re^{i\phi}[/itex] and [itex]Re(z) = \frac{1}{2}(z+\bar{z})[/itex].
A little more explanation please?
Put z=x+iy and write the equation out in terms of x and y. Try completing some squares. B must be real. It doesn't look like they want you to assume A is real though. Write it as Re(A)+i*Im(A).
That is correct, A is complex, but only the real part of it is in the equation. One thing that is confusing me A LOT is that this is a quadratic, and I was under the impression quadratics ALWAYS have a solution which may be real or may be complex. For this problem I am to prove that the above equation has a solution if and only if the absolute value of (A^2) is greater than or equal to 4B. I don't even see how the absolute value of A comes into play. Oh and I am horrible at completing squares, I've never been formally taught how.
Start by writing down what |z^2|+Re(Az)+B is in terms of x and y. And Re(Az) will contain Im(A).
Hey Dick, hopefully I'm not making you feel like your having to baby me. I am essentially teaching myself this material, my professor does not do much. Anyways, letting z= x+iy I know the equation becomes (x^2)+(y^2)+Re(A)x+B=0 and then I tried completing the square and get (y^2)+(x+ Re(A)/2)^2= ((Re(A)^2)/4)-B. And now I am not sure where to go.
You are making great progress. Now since the left side is nonnegative then the right side must be too, right? But you need to fix up Re(Az). Az is (Re(A)+i*Im(A))*(x+iy). There's more to Re(Az) than just Re(A)x.
Ahhhh, I naively assumed Re(Az)= Re(A)*Re(z)= Re(A)*x. The thought to multiply out Az first, then look at the real part of that product simply evaded me...I shall fix that now
Alrighty. So now I have, after correcting the Re(Az) error and a little simplifying to get the 2's out of the denominators as well as producing the required 4B, (4y-2Im(A))2+ (4x+ 2Re(A))2= (ReA)2+ (ImA)2- 4B = [itex]\left|A^2\right|[/itex]-4B. Since the LHS is greater then or equal to 0 the RHS must be the same, hence the absolute value of A^2 must be greater then or equal to 4B. And now I just remembered this is an if and only if proof so now I assume I have to prove it the other way as well.
Ok, so? Looks to me like that equation describes a circle in the xy plane. What are the center and radius?
Oh yeah, definitely a circle and if I remember the rules properly it is centered at (2Im(A), -2Re(A)) and r= √[itex]\left|A^2\right|[/itex]-4B
Close but not quite. And your previous answer wasn't quite right either. You are handling that factor of 4 wrong. A circle looks like (x-x0)^2+(y-y0)^2=r^2. Try it again more carefully.
Can you be more specific in regards to which part of my previous answer was wrong? Just so I know which part to look at. I see that I gave the ordered pair for the center backwards i.e (y,x) when it should be (x,y). I am not sure what you mean by handling the factor of 4 wrong though.
Ahh is it that I improperly multiplied the 4 through the equations? I think I should have multiplied through before I made the terms into squares, which would change for example 4y into 2y, etc.
Yeah, the overall idea is fine. Just fix the numbers up a little.
nate9228 said:
Thank you
Very welcome. Glad to see you figured out the 'completing the square' thing. You can do stuff with it you can't really pull off just using the quadratic equation when you are dealing with multiple variables.
