Complex Integral Along a Path with Residue Theorem
The discussion revolves around evaluating a complex integral along a specified path using the Residue Theorem. The integral involves a function with simple poles at specific points in the complex plane.
  • Participants explore the identification of poles and the application of the Residue Theorem. Questions arise regarding the explicit calculation of residues and how these relate to the evaluation of the integral.
Participants have identified the poles of the function and discussed the implications of the Residue Theorem. There is ongoing exploration of how to compute the residues, with some guidance provided on the calculation process.
The integral is defined along a circular contour, and there is an acknowledgment that the poles lie within this contour. Participants express uncertainty about the calculation of residues, indicating a need for further clarification on this aspect.
Metric_Space
Evaluate the integral along the path given:
integral(along a(t) of (b^2-1)/(b^2+1) db ) where a(t)=2*e^(it) , 0 <= t <= 2*pi
none
I am thinking of using the Residue Theorem.
I think there are poles at -i and +i.
But not sure what to do to show this explicitly.
Yes, the function
[tex]\frac{z^2- 1}{z^2+ 1}= \frac{z^2- 1}{(z+ i)(z- i)}[/tex]
has simple poles at z= i and z= -i.
That is true because
[tex]\lim_{z\to i}\frac{z^2- 1}{(z+i)(z-i)}[/tex]
does not exist while
[tex]\lim_{z\to i}(z- i)\frac{z^2- 1}{(z+i)(z-i)}= \lim_{z\to i|}\frac{z^2- 1}{z+ i}= i[/tex]
and similarly at z= -i.
How can I use these facts to evaluate the integral?
You do know Cauchy's residue theorem right?
[tex] \oint_{\gamma}f(z)dz=2\pi i\sum\textrm{Res}(f(z);\gamma )[/tex]
Calculate the residues and you have your answer.
so the integral would be zero in this case since the residues are -i and i?
The contour is a circle of radius 2 centred on the origin, these poles certainly lie within that contour. Have you calculated the residues for the poles?
No, not sure how to...
To calculate the reside at i for example, compute:
[tex] \textrm{Res}(f(x);i)=\lim_{z\rightarrow i}(z-i)f(z)[/tex]
Thanks...I think that helps!
