Solving Complex Integral: Cauchy's Formula
The discussion focuses on solving complex integrals using Cauchy's Integral Formula. The first integral, z²/(z⁴-1), is evaluated around the contour defined by x² + 16y² = 42, identifying poles at z=1, -1, i, and -i, with only z=1 and z=-1 inside the contour. The calculation shows that the integral evaluates to zero due to the residues at the poles canceling each other out. The second integral, sinh²z/z⁴, is computed around the unit circle, yielding a result of (8/3)π after differentiating sinh²z three times. The discussion highlights the application of residue theorem in both cases, confirming the results through careful analysis of the poles.
zenite
1. Integrate z2/(z4-1) counterclockwise around x2 + 16y2=42. Cauchy's Integral Forumula3. Solution
I found the points z=1,-1,i,-i where the function is not defined. Using partial fractions to split them up, and integral them separately.
Only points z=1,-1 lies in the contour, so...
\oint0.25/(z-1) + 0.25/(z+1) + 1/(z^2+1) dz
= 0.25(2Pi I + 2Pi I) + 0 = Pi I
Ans is 0. can anyone find my mistake?
1. Integrate sinh2z/z4 counterclockwise around the unit circle.2. Cauchy's Integral Forumula3. Solution
\oint sinh2z/z^4 = \oint sinh2z/(z-0)^4
= 2*PI*i/3! * (sinh2z)'''
Differentiating sinh2z thrice gives 8cosh2z
Hence, integral at z=0 = (8/3)*PI*i
Ans is (8/3)*PI. Again, can anyone spot my mistake.
for the first question:
the residue at z=1 is the limit as z goes to 1 of:
(z-1) \left( 0.25 / (z-1) + 0.25 / (z+1) + 1 / (z^2+1) \right)
put that in and you get 0.25 + (-0.25) = 0
i imagine this will also happen at the z=-1 pole
then just use Cauchy's residue theorem that
\int_\gamma f(z) dz = \displaystyle \sum_i Res(f, c_i) where c_i are the poles of f(z) and you'll get the whole thing to integrate to 0+0=0
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
