Finding Domain for Complex Numbers: |y-x|<=2, |x|<=2
The discussion focuses on finding the domain for complex numbers defined by the inequalities |y-x|≤2 and |x|≤2. Participants clarify how to interpret these inequalities in the context of complex variables, emphasizing the importance of correctly identifying x and y as real and imaginary parts of a complex number. The conversation highlights the need to express the conditions geometrically, leading to the conclusion that the region defined by |y-x|<2 is bounded by the lines y=x+2 and y=x-2, superimposed with |x|<2. Ultimately, the original poster resolves their confusion after discovering a calculation mistake made by their instructor. The discussion effectively illustrates the process of analyzing complex inequalities and visualizing their geometric implications.
DottZakapa
i have to find this domain
complex numbers
i have to find such domain
z=x+iy , y,x∈ℝ , |y-x|<=2, |x|<=2
i'm confused with |y-x|<=2, how should i proceed ? with abs of x i am ok.
Have you tried to write ##x,y## is polar coordinates? Or start with reals: What does ##|x|<2## mean for real numbers?
##e^{-x}*e^{iy} = e^{-x+iy}## this?
No. You have to resolve the norm, so you must represent the complex numbers ##x,y## somehow. Do you know how we can write them, in order to calculate ##|x|##?
i know that |z| = ##\sqrt {x^2+y^2}##
but i don't know how to handle this |y-x|
O.k. Polar coordinates would have been ##z=r\cdot e^{i\varphi}## and ##|z|=r##.
Anyway. In order to write ##|z| = \sqrt {x^2+y^2}## you had to write ##z=x+iy## first. This was a bad choice, as ##x,y## will be needed as complex numbers, so the letters are already occupied. You should have written ##z=a+ib## and ##|z|=\sqrt{a^2+b^2}.##
Now we have two complex variables ##x,y##. We first write them as ##x=a+ib## and ##y=c+id##. Can you calculate ##x-y## and ##|x-y|##? And you still have to answer post #2: Which domain is ##|a|<2## if ##a## is real?
so if x = a+ib and y= c+id then
y-x would be (c-a)+i(d-b) then the |y-x|= ##\sqrt {(c-a)^2+(d-b)^2}##
then
##\sqrt {(c-a)^2+(d-b)^2}<=2##=> ##(c-a)^2+(d-b)^2<=4##
then
Yes, but you must be careful with squaring inequalities. You cannot go back easily. That's why I asked for the meaning of ##|a|<2##.
a is comprised between -2 and 2. isn't it?
Yes, and the same is true if ##Z=a+ib## is complex. However, the complex norm is defined to be positive, so here we get for ##z=a+ib## from ##|z|=|a+ib|=\sqrt{a^2+b^2}## that ##0\leq \sqrt{a^2+b^2}<2## must hold. Try to draw the points ##\{(a,b)\in \mathbb{R}\}^2\,|\,0\leq\sqrt{a^2+b^2}<2## in a coordinate system with axis ##a## and ##b##. And then figure out where ##z## has to be, if the coordinates were ##a## and ##ib##.
I disagree. x \in \mathbb{R} and y \in \mathbb{R} are defined by the OP's question as being the real and imaginary parts of z \in \mathbb{C}, and conditions are then placed upon x and y in order to restrict z to a particular subset of \mathbb{C}. That is the natural way to interpret
So the OP is looking for (x,y) \in \mathbb{R}^2 such that |y - x| \leq 2 (and |x| \leq 2, but they already know how to deal with that).
So start with something easier. Take C \in \mathbb{R} such that |C| \leq 2 and consider y - x = C. What does that look like?
Likes Delta2 and DottZakapa
pasmith said:
I disagree. x \in \mathbb{R} and y \in \mathbb{R} are defined by the OP's question as being the real and imaginary parts of z \in \mathbb{C}, and conditions are then placed upon x and y in order to restrict z to a particular subset of \mathbb{C}. That is the natural way to interpretSo the OP is looking for (x,y) \in \mathbb{R}^2 such that |y - x| \leq 2 (and |x| \leq 2, but they already know how to deal with that).
i did try in such way, but the results of the instructor did not coincide. Going forward in the video, he made a mistake and corrected it. So problem sorted. Is like you say. thanks to anyone :thumbup:
Likes WWGD
The region |y-x|<2 is clearly bounded by the lines y=x+2 and y=x-2, so sketch those. Superimpose the bounds for |x|<2.
thank you, as said above i have sorted the problem. the adopted procedure before posting the problem here was the same as @pasmith and you proposed. A dubdt raised for a discrepancy between my obtained result and the one of the instructor, which later on revealed to be a calculation mistake of the instructor.
  • · Replies 27 ·
  • · Replies 17 ·
  • · Replies 19 ·
