Complex Potential Flow - Two Vortices offset from the Origin
8 replies · 4K views
squire636
a. Determine the complex potential for two equal counter-rotating vortices with strength [itex]\Gamma[/itex], the positive one located at z=-a and the negative one at z=a.
b/ Show the shape of the streamlines for this case.
z = x + iy = r*e^(i[itex]\theta[/itex])
W(z) = [itex]\Phi[/itex] + i[itex]\Psi[/itex]
where [itex]\Phi[/itex] is the potential function and [itex]\Psi[/itex] is the stream function
a. This part is relatively easy. I know that the complex potential for a vortex at the origin is
i[itex]\Gamma[/itex]/(2*[itex]\pi[/itex]) * ln(z)
Therefore, for the two vortices, we will have:
W(z) = i[itex]\Gamma[/itex]/(2*[itex]\pi[/itex]) * ln((z+a)/(z-a))
b. This is where I start to have trouble. I need to separate W(z) into the real and imaginary parts, and then I know that the imaginary part is the stream function. However, I don't know how to do this. It is easy for a vortex at the origin, because then I would have
ln(z) = ln(r*e^(i[itex]\theta[/itex])) = ln(r) + i[itex]\theta[/itex]
However, the addition and subtraction of 'a' inside of the log is giving me a lot of trouble. I've tried to separate it every way that I can think of but haven't had any success. Any help would be much appreciated. Thanks!
To separate real and imaginary parts, it is easier to write the log as ln(z+a)-ln(z-a). In both cases, this is just a shift by +-a.
I tried that, but still did not make any progress.
ln(z+a) - ln(z-a)
ln(r*e^iθ + a) - ln(r*e^iθ - a)
Now what? I can't split it up into ln(r)+iθ anymore.
I'm sorry I don't quite follow you, could you explain in more detail? I'm unfamiliar with that notation. Thanks.
That is a notation I invented for your specific problem.
z+a can be written as ##z+a=r^+ e^{i \theta^+}## with some real values ##\theta^+## and ##r^+## - there are formulas how to convert an arbitrary complex number to that shape.
In the same way, z-a can be written as ##z-a=r^- e^{i \theta^-}## with some real values ##\theta^-## and ##r^-##.
Would I do something along these lines?
ln(z+a)
ln(r*e^iθ + a)
ln(r*cos(θ)+i*r*sin(θ) + a)
ln((r*cos(θ)+a) + i*r*sin(θ))
And then try to find a new r and θ in order to put this back into the form of r*e^iθ ? That doesn't seem to me like it will be possible, and I can't find the formulas that you mentioned. Are they available online somewhere?
That is possible.
The standard formulas how you get r and θ if you have a complex number a+ib? They are everywhere.
I think I figured it out, thanks so much!
