What is the formula for calculating the density of a composite material?
The formula for calculating the density of composite materials involves a weighted average based on the proportions of the constituent materials. Specifically, if one material weighs 30 kg and the other weighs 70 kg, the resultant density can be expressed symbolically as a combination of their densities multiplied by their respective weight fractions. This approach provides a straightforward method to determine the overall density without needing complex equations or additional parameters like Young's modulus.
  • Understanding of composite materials and their properties
  • Basic knowledge of density and weight calculations
  • Familiarity with symbolic expressions in mathematics
  • Experience with material science concepts
  • Research the principles of composite material density calculations
  • Explore the significance of weight fractions in material properties
  • Learn about the role of Young's modulus in material science
  • Investigate common applications of composite materials in engineering
Material scientists, engineers, and students studying composite materials or involved in material selection and analysis.
joemte
A composite material of silicon carbide-filled borosilicate glass is designed with a mixture of 30% of silicon carbide by weight. Given the densities of the consituent materials below:
Silicon carbide = 3.2g cm^-3 (Young's modulus 406 GPa)
Borosilicate glass = 2.23g cm^-3 (Young's modulus 63.7 GPa)
None
Does anyone have an equation for the resultant density of the composite materials? Having a look around the internet and I can't find anything, there was this one website that gave me a step-by-step but the answers did not match (sciencing.com)
Hi,
Your problem lies with
Homework Equations: None
Forget about the Young modulus and add 30 kg of the one to 70kg of the other in a symbolic expression
