Compound gear train ratios and how to assemble gears?
The discussion focuses on achieving a gear ratio of 1/256 using a small 1.5v/3v motor with a maximum speed of 14,000 RPM. The user utilizes a gear kit featuring a driver gear with 12 teeth and compound gears with 48 outer and 12 inner teeth. The solution involves stacking two compound gears on each of the two available shafts, allowing for the necessary gear ratio to be achieved despite the limitation of shaft space. This innovative assembly method successfully meets the project's requirements for a torque/speed test.
  • Understanding of gear ratios and their calculations
  • Familiarity with compound gear systems
  • Basic knowledge of motor specifications and performance
  • Experience with mechanical assembly techniques
  • Research advanced gear ratio calculations in mechanical engineering
  • Explore different methods for stacking gears in limited space
  • Learn about torque and speed testing methodologies for small motors
  • Investigate the impact of gear material on performance and durability
Engineering students, hobbyists in robotics, mechanical engineers, and anyone involved in designing gear systems for torque and speed applications.
unseenfootage
Hello fellow Physics Forumers
My first post and , hopefully not my last. I've been lurking for a long while and the tempo has increased since I started my 1st year engineering course last semester.
So I decided to register today as I have a bit of a puzzle.
We have a project to construct a truck which will be used in a torque/speed test.
First we have to do a speed - torque test of a small 1.5v/3v motor using a gear ratio (output shaft speed/motor speed) of 1/256.
I have the following kit:
http://www.mfacomodrills.com/gearboxes/multiratio.jpg
The motor is 1.5-3.0v with 8200 rpm and 14000 rpm respectively.
The driver gear has 12 teeth.
There are 6 compound gears with 48 outer and 12 inner teeth.
Two shafts , one with pulley
Assembly kit.
My question is how to achieve the gear ratio (output shaft speed/motor speed) of 1/256, with what I have?
Kind regards.
Gear ratio = (No. Teeth on gear B/No. Teeth on gear A) * (No. Teeth on gear D/No. Teeth on gear C) * (No. Teeth on gear F/ No. Teeth on gear E) * (No. Teeth on gear H/No. Teeth on gear G).Gear A is the driver gear with 12 teeth. The rest are compound gears with 48 outer and 12 inner teeth.
48/12 * 48/12 * 48/12 * 48/12
= 4 * 4 * 4 * 4
=256
This appears to be the solution, except I only have two shafts and the assembly plate seems to have only space for two shafts.
Is there a way of assembling it (maybe 2 gears per shaft) which might work?
Kind regards...
Solved, by myself.
I stacked two compound gears on each shaft...One green and one orange.
The orange ones are fixed to the shift and the green ones are free.
So instead of all the gears positioned side by side on four different shafts in a line, I have only two shafts with two gears stacked on each.
Thanks anyway.
Now for the speed torque test.
  • · Replies 26 ·
23K
