Compound Microscope Homework: Angular Magnification & Object Distance
The discussion revolves around a compound microscope problem involving angular magnification, transverse magnification, and object distance. The original poster presents specific values for the eyepiece and objective lens, along with the tube length, and seeks assistance in determining the object distance.
  • Mixed
  • Participants explore the calculations for transverse and angular magnification, questioning the correctness of the original poster's values and assumptions. There is discussion about the definitions of terms and the implications of the tube length on the calculations.
Some participants have provided alternative calculations and questioned the values used by the original poster. There is an ongoing examination of the assumptions regarding the tube length and the relationships between the distances involved in the microscope setup.
Participants note potential discrepancies in the values provided, such as the tube length and the focal length of the objective lens. There is also mention of the context being a web assignment, which may impose specific constraints or expectations on the problem-solving process.
dvolpe
A microscope has an eyepiece that gives an angular magnification of 5.25 cm for a final image at infinity and an objective lens of focal length 1.45 cm. The tube length is 16.1 cm.
a - What is the transverse magnification due to the objective lens alone?
b - what is the angular magnification due to the microscope?
c - how far from the objective should the object be placed?
M transverse = -I/f obj.
M eyepiece = N/f eyepiece
d of image = tube length - f eyepiece
I correctly got -11.5 for a and -60.5 for b. I am having trouble with c!
I used d image = 16.7 - 25/5.25 = 11.94
then (1/d image) + (1/d object) = 1/f obj
1/11.94 + 1/d obj = 1/1.45
I get d obj = 1.65 THIS IS WRONG - answer is 1.58 Please help.
I'm having trouble with your wordings and symbols.
How can "angular magnification" have a unit of "cm"? It should be dimensionless.
What do your symbols I and N mean?
Can I assume that your tube length corresponds to the distance between the back focal plane of the objective and the back focal plane of the eyepiece?
I is the tube length
the angular magnification is not in cm
N is the normal point for the eye - 25 cm
d is the distance to the lens (d image is distance of image to lens and d object is distance of object to lens)
Then there appears to be something wrong with the numbers you specified.
I get for a) M obj = -I/f obj = -16.1 / 1.45 = -11.1
This differs from your outcome -11.5.
How did you arrive at this value?
Using your value of -11.5 for a), I'd get for b) M = 5.25 x 11.5 = 60.4.
The difference is presumably a rounding error.
Can it be that your tube length is actually 16.7 cm instead of 16.1 cm?
Note that with the numbers you provided and the answer of 1.58 cm for the objective distance, the objective would make an image at 17.6 cm, which is longer than the tube length.
That can't be right...
The tube length is 16.7 and the f of objective lens 1.45 cm
Per the solutions the distance for the objective distance is listed as 1.58. Help.
Well, according to my calculations the objective distance should be 1.637 cm.
Btw, I calculated this differently from you, but obviously this is not your given answer either.
Can it be that your textbook answer is wrong?
I do not know if the answer is wrong but this is for web assign and I am trying to understand why they might be right. Can you tell me how you solved the problem?
The objective lens projects the object (at distance dobj) to an image within the tube.
Let's say at a distance objim from the focal plane of the objective lens.
Formula is: \frac 1 {d_{obj}} + \frac 1 {obj_{im}} = \frac 1 {f_{obj}}
This image has a distance of I - obj_im from the focal plane of the eye lens.
The eye lens projects it to a distance of -N (virtual).
Formula is: \frac 1 {I - obj_{im}} + \frac 1 {-N} = \frac 1 {f_{eye}}
So: obj_{im}=I - \frac 1 {\frac 1 {f_{eye}} - \frac 1 {-N}}
And: d_{obj} = \frac 1 {\frac 1 {f_{obj}} - \frac 1 {obj_{im}}}
Filling in the numbers gives dobj = 1.637 cm.
The tube length is defined as the distance from the back focal plane of the objective to the primary image plane.
So the image distance from the objective is
di=I+f(objective)=16.1+1.45 (cm)
Substitute for di in the lens formula
1/do+1/di=1/f(objective)
ehild
