Compound pulley tension question
  • Thread starter Thread starter sailsinthesun
    Pulley Tension
The discussion focuses on solving a compound pulley tension problem involving an object of mass M and gravitational force g. The key findings include that the tensions in the rope sections are T1 = T2 = T3 = Mg/2, T4 = (3Mg)/2, and the applied force F is equal to Mg/2. The solution is derived using free body diagrams (FBD) for each pulley, emphasizing that tension remains constant throughout a massless and frictionless rope system.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams (FBD)
  • Familiarity with tension in ropes and pulleys
  • Basic principles of static equilibrium
  • Study advanced pulley systems and their mechanical advantages
  • Learn about the effects of angles on tension in pulley systems
  • Explore the concept of static equilibrium in more complex systems
  • Investigate the role of friction in pulley systems and its impact on tension
Students studying physics, particularly those focusing on mechanics, engineers designing pulley systems, and anyone interested in understanding the dynamics of tension in ropes and pulleys.
sailsinthesun
[SOLVED] Compound pulley tension question
An object of mass M is held in place by an applied force and a pulley system as shown in Figure P5.55. The pulleys are massless and frictionless.
http://img520.imageshack.us/img520/7840/p445fw5.th.gif
(a) Find the tension in each section of rope, T1, T2, T3, T4, andT5. (Answer in terms of M and g.)
(b) Find the magnitude of F.
The only thing I know is that T5=Mg. I'm trying to draw the a FBD for each pulley but I'm getting confused with relating T1, T2, T3, and T4 with Mg and F.
It's easier than it looks. The FBD for each pulley should be easy since the only forces on the pulleys are the string tensions.
Hint 1: The tension is the same throughout a continuous piece of rope (since the pulleys are massless and frictionless).
Hint 2: How does F relate to T1?
F-T1=0 so F=T1?
When I'm drawing the FBD for the top pulley, what would the downward force be? F?
sailsinthesun said:
F-T1=0 so F=T1?
Right!
The downward force will equal the three tensions that pull on it.
Doc Al said:
Right!
So the downward force would be T1+T2+T3? Meaning T4=T1+T2+T3? And how do I relate these tensions to M and g?
Right.
By combining that with other equations you can come up with. What about the second pulley? And, especially, what about my hint #1? :wink:
Doc Al said:
Right.
Even if the rope goes through a pulley? So that means T1=T2=T3?
Ahh, just solved it. Thanks for all of your help. T1=T2=T3=Mg/2 and since T4=T1+T2+T3, T4=(3Mg)/2 and since F=T1, F=Mg/2
Hey guys I have a problem I got wrong similar to this. The pulley set up is exactly the same, but the outside rope is pulled at an angle (60) and I was curious to see how the force changes with the angle. Don't get me wrong here, I know that to find the x component of the force it would be FCos(60) and the find the y component you would use FSin(60), but do you use 1/2MG as F even though its pulled at an angle? And furthermore, do you do you square Fx and Fy and then take the root of it to find the final F?
  • · Replies 22 ·
  • · Replies 22 ·
