Compression of a spring. Hooke's Law vs. Conservation of Energy
The discussion revolves around the compression of a spring when a block is placed on it, comparing Hooke's Law and conservation of energy. The initial calculation using Hooke's Law yields a compression of 0.1962 m, while the energy conservation approach suggests 0.3924 m, leading to confusion about the correct answer. It is clarified that when the block is gently placed, an external force is applied to prevent acceleration, resulting in a different equilibrium point than when the block is released from rest. The key takeaway is that the spring compresses to twice the equilibrium point due to the dynamics of the system, leading to oscillation rather than a static equilibrium. Understanding the role of kinetic energy and external forces is crucial in resolving the discrepancy in the calculations.
thindelgado
Lets say I have a spring with a stiffness of k = 250 N/m originally unstretched. I then gently place a 5 kg block on top of the spring. How much does the spring compress?
W = mg
F = -ks
mgΔh = 0.5k(Δh)2
Using Hooke's Law I get the following result
W = 5*9.81 = 49.05 N
W = F = -kx
49.05 = 250x meaning x = 0.1962 m
Using conservation of energy I get this though:
mgx = 0.5kx2
0 = 125x2 - 49.05x
x = 0.3924 m
So which one is the correct answer? Why is one double the other?
The first answer is correct. If you place it gently on the spring, then you need to apply force (and do work) to keep it from accelerating while the spring is compressing. If you don't do this, then the mass will have kinetic energy as it passes through the equilibrium point, and it won't stop until it has traveled twice as far. But this will not be an equilibrium point, and the mass will go back up in the other direction. If you apply the force to keep it from accelerating, then it will only go down to the equilibrium point x = mg/k. The problem with your energy balance was that you omitted the kinetic energy developed by the mass.
This same question has appeared on Physics Forums many times in the past.
Chet
All right, here's my confusion though. If the block is originally at rest then it has no kinetic energy only gravitational potential. Once it starts descending (compressing) it has some kinetic but when it reaches the lowest it can get, for that moment all of its energy is in the form of spring potential. So why wouldn't the initial gravitational potential energy be equal to the spring potential energy?
The "lowest you can get" is not the same as the position reached when you "gently place it".
It is actually twice as much.
You are calculating two different things so you get two different answers.
When you place it gently the energy of the weight+spring system is not conserved.You have some external force doing work on the system, as was already explained by Chet.
Ok, I think I'm getting it now. This would be my last counterargument I guess.
So if the block was released from rest 1 m above the spring then with conservation of energy:
mg(h+x) = .5kx^2
49.05 + 49.05x = 125x^2
x = .8526 m
I'm assuming this is correct since pretty much the same scenario is in an example in my book.
So again, if i was to release it from rest when h = 0, then I would go back to mgx = 0.5kx^2. How has anything changed?
Thank you guys for the help!
It will be equal to the spring potential energy. But this will not be the equilibrium point. When you get to this point, the spring will have been compressed to twice the distance to the equilibrium point, and the upward force of the spring will be 2mg instead of mg. So the mass will accelerate upward again. The mass will forever oscillate up and down in simple harmonic motion from zero displacement to twice the equilibrium displacement. Whenever it passes through the equilibrium point, its velocity will not be zero; it will pass through a maximum.
Chet
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
