Understanding Centrifugal Compressor Flow Rates
The discussion focuses on understanding the flow rates of centrifugal compressors, specifically addressing the rated flow of 10 bar pressure at 100 m³/min. It clarifies that this rating typically refers to the flow under no load conditions, such as an open hose or nozzle. The conversation also emphasizes the importance of distinguishing between Actual Cubic Meters per second (ACM/s) and Standard Cubic Meters per second (SCM/s), with a rough conversion provided: 100 ACM at 10 bar equates to approximately 1000 SCM. A calculation example for determining flow rates in practical applications is requested for further clarity.
  • Understanding of centrifugal compressor specifications
  • Knowledge of pressure measurement units (bar, ACM, SCM)
  • Basic principles of fluid dynamics
  • Familiarity with gas laws and their application in compressible flow
  • Research the differences between ACM and SCM in gas flow calculations
  • Learn how to calculate flow rates in pneumatic systems
  • Explore the principles of centrifugal compressor operation and efficiency
  • Study the impact of load conditions on compressor performance metrics
Engineers, technicians, and students involved in mechanical engineering, particularly those focusing on pneumatic systems and compressor technology.
linguist
I need some help in understanding a few things about air compressors & in particular Centifugal Compressors, could someone help me out with this please.
This is not homework, just me trying to understand.
If a Centrifugal compressor is rated at "just for example only" 10bar pressure @ 100 m^3/min, is this the rated flow out of an open hose or nozzle into the atmosphere, no load condition?
Or is this under full working load?
As an example only so I can understand more clearly using the compressor specs above.
If we have a hypothetical cylinder of 100 m^3 volume fitted with a piston inside, the piston has a load attached externally at the other end.
The pressure needed to move the piston & the load is say 9 bar, how long will it take for the piston to move the total length of the cylinder & for the compressor to fill the full volume of the cylinder.
In other words what would the flow rate be of the compressor in this situation.
A working example of the calculation to work this out would be very helpful.
Thanks
You need to know whetther the flow rate quoted is in ACM/s or SCM/s that is actual cubic meters / sec or standard cubic meters / sec. ACM is the volume of the gas at the stated pressure SCM is the volume of the gas at standard pressure (and temperature) use absolute pressure and temperature. Very very roughly 100 ACM at 10 bar A will be 1000 SCM.
Thanks Jobrag.
I see what your saying.
Thanks again
Cheers
  • · Replies 33 ·
  • · Replies 20 ·
