Compute lorentz force from charge
6 replies · 2K views
tifa8
A raindrop carrying a charge of 25x10-12 coulombs falls at a velocity of 5 m/s between the poles of a permanent magnet. It passes through a 50 mm long region in which the magnetic field density of 0.9 T is directed horizontally.
1) determine the lorentz force of the raindrop
2) ESTIMATE THE HORIZONTAL COMPONENT OF THE RAINDROP VELOCITY AFTER IT PASSES THROUGH THE MAGNETIC FIELD (DIAMETER DROP=1MM)
Joined, diagram of how i interpreted the text
F=q*(vector v x vector B)=qvb in magnitude
1) by applying the formula I got F=25.10-2*5*0.9=1.125 N
However I do not understand question 2. For me the horizontal velocity component is equal to zero (going down) so it doesn't make sense to me.
Can someone explain it to me ? Thanks
the velocity will increase and change slightly direction i think. But even though there is not any horizontal component , right ? I really cannot see it...
Hi tifa8! :smile:
The raindrop is accelerated horizontally by the Lorentz Force F.
To find the horizontal acceleration you need to estimate the mass of the raindrop (F=ma).
To find the horizontal component of the velocity you need to calculate the time the magnetic field exerts its influence (v=at).
Oh ok thanks. Now I can visualize the problem. Thank you I like serena and vela :)
