Compute Torque About Point A - 3 SF
  • Thread starter Thread starter Peter2288
    Torque
The discussion revolves around calculating torque about a specific point (point A) for three forces, with a focus on the third force (F3). Participants are exploring the relationship between force, distance, and angle in the context of torque calculations.
  • Participants discuss the formula for torque and question the appropriate distance (r) and angle (θ) to use in calculations. There are inquiries about whether to use the hypotenuse of a triangle for r and how to break down the force into components.
The discussion is active, with participants providing guidance on the use of angles and components in torque calculations. There is a mix of interpretations regarding the setup and calculations, but no explicit consensus has been reached.
Participants are working under the constraint of using three significant figures for their calculations, and there is an emphasis on understanding the geometric relationships involved in the problem.
Peter2288
[SOLVED] Torque Question
See diagram for problem
additional instructions
For each of the three forces shown, compute the moment (N m, + CCW) about point A. Assume 3 SF for all numbers.
I am trying to solve for the moment(torque) of F3
Force * (Distance between force and point A) * sine(theta)??
too many to name.
That's it! Problem over right there. Tounet = F.r.sinX. Add the torques separately, one by one.
For force 3, the r value is supposed to be the direct line between it and the point of pivot right? Do I use the hypotenuse of the triangle for the r value? Also what angle do I use (arctan (3 / 4)??), and am I supposed to somehow break up the force into x and y components? I've tried some of this stuff, but none of it seemed to work. Thanks for your time.
Right.
Sure.
When using [itex]r F \sin\theta[/itex], the angle is the angle between the position vector and the force vector.
You can always break a force into its components and then find the torque for each component and add them. (That would be much quicker, especially if you realize that [itex]r \sin\theta[/itex] is the perpendicular distance to the line of the force.)
Thanks guys.
  • · Replies 42 ·
