Computing in Mechanical Engineering?
49 replies · 32K views
caslav.ilic said:
I've yet to see a spreadsheet in wilderness that was developed by more than one person, and modifiable and maintainable by anyone else. At best, people other then the creator used it as a canned solution -- input numbers here, see results there, complain when it spews obvious nonsense. There is no practical way to develop a spreadsheet computation modularly and accountably by several people; no way to track history of changes, of who did what, when, and why. As opposed, this is normal and established practice with any proper programming material (Matlab's .m files amenable too), and can be performed with free and fully cross-platform tools.
I agree, everybody has their own style when it comes to spreadsheets. Excel does have a "track changes" feature which will keep track of who changed something and when. People rarely use this feature, but it is there. Even in my own spreadsheets, I can't always remember why I did something a couple months ago. So I've gotten into the habit of inserting comments into important cells.
Jupiter6 said:
[...] What no one has mentioned is the SOLVER in Excel kicks ASS. [...]
Har, har. Just waited for a mention of that one :)
Excel's solver is good, I'll even say "world class", in a certain sense. But there are two crucial problems with it. (Also, make no mistake, CAS tool like Matlab, MathCAD, etc. will contain such solvers without exception. And there are free libraries of such methods too, for use in custom codes.)
Firstly, while it uses an algorithm which is one of the several well-proven for general optimization, all algorithms of that kind (gradient-based) suffer one theoretical boundary. A boundary which, unfortunatelly, frequently gets lost to a practicing engineer. This boundary is the following: gradient-based methods can find only a local optimum of the goal, i.e. such which is optimal to any near-designs (those obtained by slight variations in design parameters), but without any guarantee to global optimality. Think of an x-y function plot where there are two "valleys" (or "humps"); gradient descent (or ascent) will give you one of them, depending on the starting point, without clue to the existence of the other, which may be better. Excel Solver's users see this effect when it gives different results with different initial cell values. Furthermore, if the goal to optimize is non-smooth (think of that x-y plot with a break in it, e.g. x-segment of undefined y-value), gradient descent methods guarantee exactly nothing for the final value they provide.
Secondly, while Excel's solver can be applied to anything that provides a value to a cell, like some complicated external add-on, thusfar I've seen in the wild, it was always used on the custom-made computations made in basic Excel itself; the number of design parameters ("by changing cells...") was usually single-digit at anyone case. This all amounts to an unusual observation: in the time Excel's Solver will take to crunch the problem, if it were written in e.g. Fortran instead, one could brute force it, do a complete parameter sweep -- the only optimizing "method" guaranteed to give global best solution. (Back to x-y plot, brute force means: subdivide x-axis into problem-significant division -- e.g. airplane wing span into ~10 cm segments -- compute for each x, pick best. Don't think now "But I can do that in Excel too!" as I'm speaking of, say, 5-parameter combinations, each varied for every other, and a worksheet that will take a second or so to evaluate for one combination.)
In my masters thesis I was faced with exactly the problem described above: multi-parameter, multi-optima goal function, and non-smooth at many segments (and aircraft conceptual design computation, on basis of Raymer, Roskam, etc.) I was to thoroughly test a specialized optimizer, having 5-figures/year (or was it 6 for companies?) license fee, on this simple, but conceptually significant problem (the real one would have CFD/CSM simulations in the background, for high-fidelity results, but still displaying same general behavior).
And then I wondered: can I actually know what the best solutions were beforehand, so that I have a hard point to benchmark against? The answer, if I used Excel (or, frankly even Matlab or another CAS in this case) would be plain and simple -- no way. However, I estimated that I could write the basic computation (one set of params in, result out) in C for the same or less time it would take me with anything else (after all, there was just one way to handle these packs of formulas); and that afterwards I can brute force the problem in several hours using 8-16 CPUs (of which there were plenty to harness around the university labs). Using a scripting language (Perl at that time, today I'd use Python), it took me a week to patch a script which will read XML setup of the computation -- with freely exchangable subproblems (e.g. different powerplant, drag models), physical units, nested parameter variations, consistency guards -- and use it to build out of the basic C code both the evaluation model for the 5-figure optimizer, and an MPI-parallel brute force sweeper for getting to the benchmark hardline.
In short, in less time than it would take me to wade through columns just to set up a spaghetti-like computation in Excel, I had a safe-guarded, readable, modular, and maintainable computation, and unlimited-CPU brute force sweeper guaranteeing global optima. In the end, it left me with spare time and means to play around with what-if scenarios, like "how about if a/c was hydrogen-fueled?" :) (I should also note that the call of the Dark Side for the user of the 5-figure heavyweight was not small -- it had a "charming" feature to happily accept an Excel spreadsheet as an evaluation model...)
Chusslove Illich (Часлав Илић)
caslav.ilic said:
I consider spreadsheets horrible hellspawn that has befallen unwary engineers, an improvement on hand-held calculators in the same way in which a diesel-powered titanium-built difference engine would improve on a slide rule.
I assert that teaching spreadsheets to engineering students cripples their computational abilities, and should be treated as professional offense.
I definitely see that you are very well versed in the pluses and minuses of the various methods for computing. I definitely respect your opinions on this and other matters. However, I still don't see anything that supports such a strong assertion as what you said previously.
I see this as a perfect example as you being a smart user and understanding what tools work best for your situation and needs. You have proven that spreadsheets definitely do not suit you for a few good reasons, however you don't really present anything to refute the usefulness of them to the rest of the engineering community.
FredGarvin said:
[...] you don't really present anything to refute the usefulness of them to the rest of the engineering community.
There are degrees of usefulness. Given that spreadsheets are heavily used by engineering community, how could I, or anyone else, present an argument that refutes their utility in total? Is a slide-rule useless, is a hand-held calculator useless? This was not my intention; more specifically, I never try to convince current hardcore spreadsheet users to stop using them. My intention is a subversive one: steer people, young people, waxing and waning in their choice of tools, away from spreedsheats. E.g. in the case of OP, if after reading mine (and others') arguments he becomes more favorable towards taking a "proper computing course", and later tries to apply the knowledge obtained there to tasks in other, programming-unrelated courses, I will have achieved my goal.
On the other hand, if we base conclusions on widespread of use, one could make a similar "utility" claim for Cobol, the programming language once favored in a certain field. One key point in its design was to make it user-friendly, such that it paralleled how people would do things "intuitively". A lot of Cobol code was written in its heyday, and a huge pile of dark-matter Cobol code is still pushing numbers today. And the field is -- yep, finance. How could one then make too a strong claim of Cobol's ill-effects on programmer's abilities? Yet, http://www.tech-faq.com/cobol.shtml (my statement on spreadsheets is a toned-down, inelegant paraphrase of Dijkstra's words); such statements made newcomers think twice before reaching for Cobol, gradually phasing it out of use.
LOL. I took classes in turbo pascal, fortran and C but I don't think I've ever met anyone who used Cobol. I understand your disdain for spreadsheets but I think a lot of that resulted from your graduate work. Excel can be a wonderful thing depending on whos using it and I have seen some wonderful things.
My undergrad was in Mechanical Engineering, we where mostly taught FORTRAN and Matlab, as for CFD we used I-DEAS NX10, and solidworks & AutoCAD, and yes spreadsheets where used too :D (only time we used it was an actual sample from a European Satelite system).
Since then I've learned C++, C#, Java, Python, and a ton of other scripting languages (and Z80 machine language, plugging binary values straight into memory on a simulator)
But no-one seems to be mentioning the Floating Point Errors of Excel, this is something that can not be avioded, during our Systems failure studies one of the case study was regarding a financial organisation that lost literally millions becuse they assumed the results from the spreadsheet where accurate!
Anways I say learn them all, they are just tools, and like I always say
"If your toolbox just consists of a hammer; consider getting a new one"
Anhar
Oops I forgot to mention, one of the best use was to see Excel used to create a real 3d engine!, each cell was used as a "pixel" ! :)
Excel is good for making your results presentable, but for solving computational math problems its not very good.
I most frequently use MATLAB, which is great because it has built-in solvers that can be used with user-defined functions. MATLAB stands for "MATrix LABoratory" and is named that because its operator syntax accommodates the laws of linear algebra. It can numerically integrate user-defined functions and discrete data sets using the most effective methods availiable. It's the best software availiable for numerically solving ODES. It also has excellent plotting capabilities. Its 3-D plotting functionality far exceeds Excel's.
I have a hard time getting it to solve PDE's. It has a toolbox for this but I can't use it yet.
I am also trying to figure out a way to put REFPROP functions into MATLAB however. It has excellent tools for solving non-linear systems, but I need that to solve heat exchanger problems which require thermodynamic property functions that MATLAB seems to lack.
I use C# because I work in a software group that develops windows applications for heat exchanger simulation.
Look into matlab.
Hello everyone!
I'm not an engineer at all, I just surfed on in because I'm you can say a Linux advocate and I'm just basically going around telling everyone about it. It's almost unbelievable luck that a thread like this happened to be going on here. Linux is a free open source OS, you can download it and use it, and there are tons of places around the net with resources and information on how to get started and get on with your work and your life.
Now the thing is I don't know what software you all use , I read some of the discussion - there is OpenOffice.org which comes with just about all distributions which has a spreadsheet. Windows software can be run under Linux with Wine, a sort of "emulation layer", and there are numerous solutions to even run Windows under Linux (you must have enough RAM and space, needless to say). So - the OS, a ton of software and help and hand holding are all free - can we ask that once you use it, you give away some of your plane designs as well? :)
I will follow this thread, and answer any questions you have, and try searching on the net for free software equivalents of whatever it is you use - just throw them at me :)
Just to add -wikipedia just told me about gnu octave and freemat as something like Matlab, and there is BRL-CAD for CADing. What does Solidworks do?
iamhere said:
Hello everyone!
I am running Ubuntu 7.10 under the OpenGEU platform name and have set up Virtual Box, which allows me to run XP within Linux. I only do this when I absolutely have to, as i despise Winblows. I have 1 GB of ram with a 2.0 GHz processor and both systems run almost natively. Linux is the way to go. Onto the thread topic:
I must agree with caslav.ilic. Spreadsheets are the spawn of hell.
From what I have observed, many engineers have replaced the program form of an engineering tool with formula-based spreadsheets. Not only is this messy if you want to share the tool with others, (Formulas may be erased, its not easy to copy outputs, can't follow thought process. etc...) but you are reliant upon Microsoft and their shoddy programing.
The other problem is speed. Most programs that I create end up taking 10-20 sec of computation time, if not more. I could speed this up by tossing my calculations out to a .dll, but such things get messy quickly. Your better off bypassing the spreadsheet and using a faster language from the start.
basically what I am saying is there is no need to be tethered to one company, one operating system or program. Spreadsheets can be useful for basic, quick and dirty calculations, or making pretty graphs for management, but anything beyond that and I believe that something like MATLAB or maple or mathmatica will better serve your purpose. If your looking for a tool that will do a lot of calculations and fast, then you need to use the right tool. Odds are VBA and excel are not the right one.
As a side note, MATLAB is capable of interfacing with excel files. Pulling info in or passing it out is a matter of a few commands. on the downside, it is not nearly as fast as c++.
If you're working on something in a spreadsheet that requires 10-20 sec of CPU time then you are missing the point of this argument completely.
(One) point of my arguments was that any computation -- something which has input parameters, number of formulas to process them, and output results -- should be trivially usable at a later point as a part of something that will take 10-20 sec, to hours and days, to compute. And if the computation could, in principle, operate on variable number of input parameters, and do two or more iterations somewhere inside (which I've seen people implement as several worksheets, each named "iteration-x"), that's from the onset a total loss with spreadsheets.
Stating that one should "think ahead" and "choose the right tool for the right job" overly simplistically assumes that this is a one-way process, neglecting the feedback that the tools have on breadth and scope of our ideas. Engineers are especially susceptible to this feedback, as they tend to think problems over constructively, in specific procedures that could lead to the solution. That's why they, of all people, should avoid constraining tools.
Not at all. I have seen Solver processes easily go for that long on newer computers.
I think Fred's point is that 10-20 seconds of computing time is nothing, and you can use any program to solve it. The argument for faster and more efficient solvers comes into play when your computer is running for hours or days. A 50% difference in solve time for a problem that runs for 40 hours is a big deal, where as with a 10 second algorithm you won't even notice the difference.
Matlab is currently US$1900 per license, whereas the same thing, Octave[/color], is free[/color]. Secondly, http://curveexpert.webhop.biz/ is excellent.
MathCAD is only around $1,000.00 last time I checked anyway.
CS
That's pretty much what I was attempting to get at. For something that takes such a short period of time, where is the time benefit of coding something yourself? Perhaps I am stubborn, but with all of the things mentioned here, only the comment about floating point errors has been mentioned to show that spreadsheets are not a legitimate engineering tool.
Spreadsheets aren't unit-aware either, that's a big minus in my book. And they don't have symbolic/exact manipulation capabilities; everything must be solved in dicrete pieces no matter how infantesimally small.
ANSYS isn't unit aware either.
Symbolic manipulation is a shortfall, but that is outside the original scope of their development. It sure would be nice if they had it, especially since it is not an unheard of thing in a piece of software.
ANSYS Workbench is :approve:
I'm not sure I consider ANSYS a calculation tool as much as a simulation tool. The line between the two is a bit of a gray area, but ANSYS is very good at what it is designed to do- generate and solve huge linear algebra problems using geometry and boundary condition inputs from the user. In a way, it's a very specialized engineering math tool; I shudder at the thought of trying to find the inverse of a 300,000 x 300,000 matrix using MathCAD...
