Computing the expectation value of momentum, kinetic energy, and compute
The discussion focuses on calculating the expectation values of momentum and kinetic energy for the wave function ψ(x) = (√(30/L^5))(L-x) for 0 ≤ x ≤ L. The momentum operator in the position basis is defined as \(\hat{p} = -i \hbar \frac{\partial}{\partial x}\), while the kinetic energy operator is expressed as \(KE = -\frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2}\). The expectation value of momentum was calculated to be
= 0, and the kinetic energy was found to be \(\frac{5}{L^3} \frac{\hbar^2}{2m}\). The discussion also touches on the uncertainty principle, specifically Δp⋅Δx.
  • Understanding of quantum mechanics, specifically wave functions and operators
  • Familiarity with the concepts of expectation values in quantum mechanics
  • Knowledge of the momentum and kinetic energy operators in the position basis
  • Basic calculus skills for performing integrals and derivatives
  • Learn how to compute expectation values for various quantum mechanical operators
  • Study the derivation and implications of the uncertainty principle in quantum mechanics
  • Explore the properties of wave functions and their normalization conditions
  • Investigate the differences between classical and quantum mechanical representations of physical quantities
Students and professionals in physics, particularly those studying quantum mechanics, as well as researchers working on problems involving wave functions and expectation values.
laser123
1. consider this wave function ψ(x)=(√(30/L^5))(L-x) if 0≤x≤L
and 0 else
2. Compute the expectation value of the momentum. Compute the expectation value of the kinetic energy.
Compute Δ p⋅Δ x for*this*wavefunction3. I have already proven that the wave function is normalized so it's equal to one. I just have no idea how to do the following. Thank you so much in advance!
Hi laser123,
Recall that the definition of the expectation value \langle A \rangle for any operator A is defined as \langle A \rangle = \langle \psi | A | \psi \rangle. Do you know the operator forms of momentum, position, and kinetic energy in the position basis?
Additionally, recall that \Delta A = \sqrt{ \langle A^2 \rangle - \langle A \rangle^2 }. Once you calculate the square of the expectation value and the expectation value of the square of the position and momentum, you can do some simple calculations to solve for \Delta x \Delta p.
Hope this helps!
I am familiar with the momentum operator. Not so much with the kinetic energy or position operator
Thank You!
Remember that, for the transition from classical dynamical variables to quantum dynamical variables, we replace the respective variable with its operator (where applicable).
In the X basis, when we act on a ket | \psi \rangle with the position operator, we obtain the position. As an eigenvalue equation, X | \psi \rangle = x | \psi \rangle.
The classical representation of kinetic energy is KE = \frac{1}{2} m v^2 = \frac{1}{2} \frac{p^2}{2m} The transition to quantum mechanics, then, requires inserting the momentum operator \hat{p} = -i \hbar \frac{\partial}{\partial x}. (This is for the 1-D momentum operator in the position basis.) The kinetic energy then becomes KE = \frac{1}{2} \frac{\hat{p}^2}{2m} = - \frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2}
Now simply use the expectation value equations in order to solve for the expectation values of momentum and kinetic energy.
I calculated the expectation value of the momentum to be <p> to be 0. The kinetic energy i calculated this to be (5/L^3)(ħ^2/2m). I have no idea how to do the last part! A dummy walk through on this uncertainty principle part would be awesome :D. Thank you!
Thanks jmcleve
Thanks jmcleve
Before we do the dummy walkthrough, can you show me how you computed the expectation values for the momentum and kinetic energy? Since this wavefunction is a little weird, I'm wondering if I'm calculating it correctly myself.
For momentum i set up <P>=∫((√30/L^5)) P((√30/L^5)x(L-x))/1[/STRIKE] because the function is already normalized. So i subbed -iℏd/dx for p and distributed and applied the derivative function. Then I took the actual integral from 0 to L of what was left over. it all canceled very nicely, but took like a whole page of work.
For kinetic I did the same thing <T> = ∫((√30/L^5)) T((√30/L^5)x(L-x))/1. instead i subbed what you gave me inside of it (−ℏ^2/2m)(d^2/dx^2) and literally did the same as above but it canceled to (5/L^3)(ℏ^2/2m)
Sorry -- is the wavefunction supposed to be \psi(x) = \sqrt{\frac{30}{L^5}} x (L-x)? From the calculation you just did, it looks like that. But your original post is \psi(x) = \sqrt{\frac{30}{L^5}} (L-x). Frankly, I like the former more than the latter.
The forum rules require you show some effort at attempting the problem yourself. Jmceive's already given you enough information in this thread for you to make some attempt at solving the last part of the problem.
  • · Replies 30 ·
