Concentric conducting cylinders
  • Thread starter Thread starter hmparticle9
    Electric field
7 replies · 1K views
hmparticle9
Consider a hollow conducting cylinder parallel to the ##z##-axis, of radius ##a## and charge ##\lambda## per unit length surrounded by an outer hollow conducting cylinder of radius ##b## with charge ##-\lambda## per unit length.
(i) Find the field for all ##r##
(ii) What is ##\sigma##, the charge per unit area on the inner cylinder?
(iii) Consider the field between two cylinders when ##(b-a) << a## is very small and compare the field to that inside a parallel plate capacitor.
Gauss's law:
$$\int_{S} \mathbf{E} \cdot \text{d}\mathbf{S} = \frac{q}{\epsilon_0}$$
To make a start. In part (i) we can use Gauss's law to show that inside the smaller cylinder and outside the larger cylinder the field ##\mathbf{E} = 0##. I am not sure how to progress in the remaining case.
This is like the last problem I posted in the sense that I find it hard to get off the mark. Could you offer me some advice?
Why don't you post your attempt for part (i)? We'll take it from there.
How about using Gauss's Law to answer part (i). You said
hmparticle9 said:
In part (i) we can use Gauss's law to show that inside the smaller cylinder and outside the larger cylinder the field ##\mathbf E=0.##
Follow a similar process except that your Gaussian surface is a coaxial cylinder that encloses the smaller cylinder but not the larger cylinder.
I have solved part (i).
$$\int_S E(r)\mathbf{e}_r \cdot \mathbf{e}_r dS = E(r) \int_S dS = E(r) 2 \pi r h = \lambda \frac{h}{\epsilon_0}$$
Hence
$$E(r) = \frac{\lambda}{2 \pi r \epsilon_0}$$
Hence
Very good. How much charge, do you think, is enclosed by this Gaussian surface?
I am not sure. We know that the inner cylinder has charge ##\lambda## per unit length.
$$\lambda h = \sigma 2\pi a h \implies \sigma = \frac{\lambda}{2 \pi a}$$
This answers (ii)
Now for part (iii). In that case we have a massive "ring". If we are local to the space between the two conductors then it looks to us that we are in between two planes. One with positive charge and the other with negative charge???
I understand now. ##r \approx a## Hence
$$E(r) \approx \frac{\lambda}{2 \pi a \epsilon_0} = \frac{\sigma}{\epsilon_0}$$
