Conceptual question regarding equal and opposite reactions
mateomy
Suppose you have a can (like a spray can) in a vacuum. You poke a hole in the can and the pressure from the can pushes it to the right. Now suppose you have a vacuumed can within a pressurized container and then you poke a hole in it. Which way (if at all) does it move?
I know this is sort of like the Feynman sprinkler problem, and because of this (I guess) similar analog I keep thinking that it won't go anywhere. Is this correct?
I don't think it will go anwhere. I actually poked a hole in a water bottle and submerged it in my sink to prove it to myself. It didn't go anywhere, but I can't explain it using Newton's laws. Any help?
Hi mateomy, :)
Here's how I believe it works.
Initially the vacuum can will have the same pressure on all sides.
When you poke a hole in one side, you effectively reduce the pressure on that side.
So the can will move towards the hole.
With an empty water bottle in a sink the force will be rather small.
But then, if you have a full water bottle and put it a table, I don't think it will move (much) when you unplug it.
