gmalcolm77
- Messages
- 28
- Reaction score
- 2
"For instance, in a simple circuit made up of a battery and a resistor, the voltage drops to 0 once the electrons pass through the resistor, or the energy provided by the battery is all dissipated. Then why is the current still constant? If the voltage drops, doesn't that imply a drop in velocity of the electrons? So shouldn't it lead to a decrease in current as it leaves the resistor?"
Blissed, Very good questions that many do not think to ask. The voltage doesn't drop to zero once electrons pass through the resister, Think of the arrange- ment as two sides of the circuit. In relation to the + side, the voltage is say, -12v and +12v vice-versa. The only place in the circuit that the voltage would be zero to either side would be the center of the resister. The velocity of the electrons stays about the same as the battery decays, but the electric field is less causing fewer electrons to move with their charge.
"So in the microscopic level, what exactly is happening to the charges as they move through the resistor, what causes them to transfer energy to the resistor?"
As for energy transfer, it is an interaction of electro-magnetic fields. Fields do not like to be messed with! (Or we would all be at the center of the earth). Electron fields jumping around as current bounce off other electron fields causing a sort of 'friction' which radiates as heat(another electromagnetic field). So there is a net loss of power which is supplied by the battery creating the initial field.
