Conceptual Understanding for Voltage in a Circuit
62 replies · 12K views · last reply
"For instance, in a simple circuit made up of a battery and a resistor, the voltage drops to 0 once the electrons pass through the resistor, or the energy provided by the battery is all dissipated. Then why is the current still constant? If the voltage drops, doesn't that imply a drop in velocity of the electrons? So shouldn't it lead to a decrease in current as it leaves the resistor?"
Blissed, Very good questions that many do not think to ask. The voltage doesn't drop to zero once electrons pass through the resister, Think of the arrange- ment as two sides of the circuit. In relation to the + side, the voltage is say, -12v and +12v vice-versa. The only place in the circuit that the voltage would be zero to either side would be the center of the resister. The velocity of the electrons stays about the same as the battery decays, but the electric field is less causing fewer electrons to move with their charge.
"So in the microscopic level, what exactly is happening to the charges as they move through the resistor, what causes them to transfer energy to the resistor?"
As for energy transfer, it is an interaction of electro-magnetic fields. Fields do not like to be messed with! (Or we would all be at the center of the earth). Electron fields jumping around as current bounce off other electron fields causing a sort of 'friction' which radiates as heat(another electromagnetic field). So there is a net loss of power which is supplied by the battery creating the initial field.
Another analogy is to think of the electrons as physical objects (they aren't) like ball bearings or pool balls that are packed tightly together . If you hit the ball on the left end (impart energy) the energy is transmitted through the balls and the one on the right end is ejected with almost the energy imparted to the first one. This is close to what happens as electrons are ejected from the electron cloud of one atom and displace an electron from an adjacent one. Each electron has a charge. The number of electrons passing a given point is the current. The energy that pushes them along is the voltage. An electron an be subjected to almost any voltage, just as you can clobber the left hand ball bearing or just tap it. The ball bearings have the same mass, moving or not, since the velocities are not relativistic. Similarly,the electrons all have the same charge.The movement of electrons also imparts some motion to the atoms themselves, due to the interaction of the (negative) electron's charge and the nucleus' (positive) charge. We detect this motion (the kinetic energy of the atoms in the conductor) as heat, and call the heating due to energy loss in the transfer of electrons resistance. Since the charge of the electron never changes, the energy lost in transfer has to come from the force moving the electron i.e. the voltage.
Just to confuse the issue, the heated atoms, having more kinetic energy, are moving (vibrating is a close analogy) and this increases the loss of energy to heat in the electron's transfer from atom to atom. We see this as an increase in resistance as the conductor heats up.
The above is a crude analogy. We know what happens. We can express the interactions as probabilities of ejection or capture, based on the known characteristics of the conductors and we call them laws because there are so many millions of interactions that the statistical predictions are valid to the limits of our measurements. WE DO NOT KNOW THE MECHANISM. WE ONLY MEASURE THE INPUT AND THE RESULT AND USE THEM TO PREDICT THE RESULT OF SIMILAR INPUTS.Electrons are sub atomic particles. They do not behave the same as "material objects" in our "real world" and our ability to understand how or why they do what they do is inherently limited.
The opinion of one retired student of reality.
Not true . QED (quantum electro dynamics) describes it nearly exactly. Try Feynman's famous book
https://www.amazon.com/dp/0691024170/?tag=pfamazon01-20
It is not exactly simple reading, but it is problably less difficult than you imagine.
It is my opinion that many people put more effort into these analogies than it would take to actually learn QED to the extent that you get the ideas.
Edit; the not true part was our inability to understand.
rumborak said:
why is there a drop? What happens inside the resistor that causes this?
Energy has been lost and that is described in terms of Potential Drop.
Work is done in the form of an interaction of the charge flow and the lattice, which causes energy loss within the lattice. It may be hard to accept that Kinetic Energy is not involved but the numbers (electron mass and speeds) give vanishingly small amounts of energy transfer. Furthermore, if KE were involved, the electron drift speed would be less (loss of KE) at the end of a wire or resistor. It is not.
If you think voltage as a cross variable and current as through variable comprehension may be more easy. Cross variable is a field providing Potential energy for through variable that will create kinetic energy. (Of course some obstacles (Resistance) try to slow down the flow.) The value of this resistance is defined as
R = Volt / Amper. You may use this model almost every physical event.
This is probably overkill, but I hope that bits of it may help to answer your questions about voltages and currents in a simple circuit.
BATTERY
The electrons in a charged-up battery are under an electric 'tension', a bit like a stretched elastic band. The chemistry in the battery is trying to push electrons OUT of the negative terminal, and at the same time trying to suck electrons back INTO the positive terminal. The size of this pushing and pulling is measured in volts, or 'electric potential'. 'Potential', because nothing happens until the battery is connected into a circuit. The 'potential difference' between the positive and negative terminals is the battery 'voltage', say 5 volts. By convention the negative terminal is regarded as being at zero volts, and the positive terminal at, say, 5 volts.
CONVENTION
Talking of convention, the pioneers of electricity (mistakenly) thought that positively charged particles flowed out of the battery, from the 'positive' terminal, re-entering the battery via the 'negative' terminal. They named the terminals and the current flow accordingly. We now know that in fact the electric current consists of negative electrons flowing from the negative terminal, round the circuit, and back into the positive terminal. But it's easier to stick with the conventional nomenclature, and imagine positively charged particles flowing in the wires -- in the opposite direction to the true electron flow. Which is what we will do in the following explanations, and which you will see on all circuit diagrams.
CIRCUIT
Suppose you connect a copper wire from the battery's positive terminal to one end of a resistor, and the negative terminal to the other end. This allows the 'tension' inside the battery to be relieved. Positive charges are pushed out of the positive terminal, through the copper wires and the resistor, and sucked back into the negative terminal of the battery. This flow of positive charges round the circuit is the 'electric current', measured in amperes. Unless there is a leak in the circuit, the number of charged particles flowing per unit time (current) at all points in the circuit is the same. A bit like water pumping round a watertight pipe. You cannot have more litres per second flowing in one part of the pipe than in another! The water would either pile up somewhere, or a vacuum pocket would form.
RESISTOR
A resistor is just something that allows electricity to flow through it, but resists this flow to some extent. The degree to which the resistor hampers current flow is measured in ohms. As the charged particles struggle through the resistor they generate heat energy in the material of the resistor. Which means the particles must be losing the same amount of energy, as the heat energy has to come from somewhere.
ENERGY OF CHARGED PARTICLES
So charged particles entering the resistor must have more energy than those exiting the resistor, to account for the heat energy generated by the flow. What is this energy that each particle possesses? It is the 'tension' provided by the battery, say 5 volts. To put it another way, it is the force driving each positive particle around the circuit. As the particles are pushed round the circuit they lose some energy whenever they encounter a resistance, that is, their 'voltage' decreases. Particles flowing through a thick copper wire lose negligible energy, since copper has a very low electrical resistance. So their electric potential (voltage) hardly decreases. In our example, the charged particles arriving at the resistor are very slightly below 5 volts, but when they leave the resistor they are at a much lower voltage, as we have seen. But what voltage is this?
VOLTAGE ON RE-ENTERING THE BATTERY
After the charged particles have got through the resistor, they then flow through a low-resistance copper wire to enter the negative battery terminal. Since very little heat is generated in this wire, the particles only lose a little energy ('voltage'). But we know that at the negative terminal of the battery the potential is zero volts, by convention. So the potential at points along the wire after the resistor must steadily decrease minutely and end up at zero volts at the negative terminal. This implies that the voltage at the far end of the resisitor is very slightly above zero. The current is able to flow along this section of wire despite the very low voltages (electromotive force) because of the correspondingly very low resistance of the copper wire.
WHY DOES 'TENSION' RELATE TO ENERGY?
An electron under tension is experiencing a force that tries to move the electron in the direction of the force. The greater this 'electromotive force' (measured in volts), the greater the potential energy the electron possesses. The more useful work it can do (heat up a resistor, drive a motor, etc.) if allowed to in a circuit. It's a bit like the elastic in a catapult. The more force (tension) you exert on the elastic, the more potential energy it stores, ready to give to the missile when you let the elastic go.
VELOCITY OF CURRENT FLOW
Negative electrons powerfully repel each other (as would positively charged particles in the conventional view) preventing them from 'piling up' anywhere in the circuit. The speed at which they flow through the wires is therefore pretty much the same anywhere in the circuit. They are actually flowing at a 'terminal velocity' in the wires regardless of the voltage changes at different points.
Big Al
I didn't know the answer to these questions before, and you can see my comments in a previous thread. What I really did to get intuitive grasp is to read Matter and interactions. I really liked the way they presented the topic, Everything was intuitive and just uses your previous knowledge of physics.
They used drude model which explains how electrons behave in metals, how you can in a sense derive ohm's law based on one assumption.. etc. You will really find circuits much easier to deal with
If you can't buy the book, You can watch videos on their website which is still useful and good.
"our ability to understand how or why they do what they do is inherently limited."
It would seem that our ability to understand anything is severely limited when you think about it. Our five senses detect only EM properties of what we suppose to be the real world. As our vision detects only a portion of the existing spectrum, Em is unlikely to be all that is out there. Until that is known for sure, what do we really know?
rumborak said:
But, how is the magnetic field even relevant to the electrons?
How indeed, in this hybrid world in which people seem to want to live?
I understand that, but deep inside me I feel there is some serious glossing-over going on. Or rather, that there is a good amount of circular reasoning going on. "The potential drops because work was done" and "energy is consumed because there is a potential difference between the ends of the resistor" are the same statement reworded. And as pointed out, KE of the electrons is irrelevant, so the mechanism of energy transfer is entirely unknown.
But, let me ask a different question: Would it be conceivable to shield a resistor from the external magnetic field the surrounding circuit creates? According to the Poynting vector, if there is no magnetic field in the vicinity of the resistor, there is no energy flow, which in turn would mean no Joule heating.
Is that physically not possible, or am I misunderstanding the matter?
Your magnetic field is due to the charge flow through the resistor so how could you shield from that? It's already there.
You could put the resistor in a copper box with its terminals soldered to the box at each end. Then there would be no potential across it because no work would be done in transferring the charge through the box so there would be no current through the resistor because the current path would be around the outside path.
I don't quite see why you are quite prepared to use the Poynting vector as part of an arm waving explanation which is several steps down the ladder of difficulty. That's not logical. You got as far as Poynting Vector so take it from there.
Sorry to be coming late to this discussion, but I was concerned with your opening sentence.
"I'm having trouble understanding circuits, particularly voltage."
I see that as something like "I am having trouble understanding the building industry, particularly the metreage."
Just because the the dimensions are measured in metres (or millimetres actually) does not mean we should refer to any of them as metreage (not even sure that is a word).
In a circuit, the electic potential at various points, or more frequently the potential difference between two points, is expressed with the unit volt - but that does not mean we should call the Potential, or Potential difference voltage - to do so is to lose the meaning of what we are talking about.
You could perhaps get away with referring to a "voltage drop" rather than a Potential Difference - but that is about the biggest stretch of terminology you should use.
We use a voltmeter to measure a Potential difference, and the answer is in volts or millivolts (depends on the meter).
We use bathroom scales to measure our weight, and the answer is in kilograms (or pounds / stones and pounds if the scales are old).
We would never refer to out weight as kilogramage, and similarly should never refer to a Potential Difference as voltage.
If you religously use the term "Potential Difference", I think you will find yourself half way to a better understanding of circuits.
Blissed said:
I'm having trouble understanding circuits, particularly voltage. So my question is more of a conceptual dilemma. Please correct my definitions and relations if it is incorrect. Voltage is the energy provided per charge, and this energy is converted to KE once the circuit is closed, or in other words it influences the velocity of the electrons, and in effect influences the current.
A follow up question is, why is the voltage drop the same in a resistor as the voltage provided by battery? How does a resistor "know" that it should use up the same amount of voltage provided by the battery?
Addressing your full question (again without having read all the intervening posts). I compare a circuit to the following.
Suppose you set up a running course around your nearby city. The course includes some flat ground, some gentle up slopes, some stairs going up, and of course some down slopes.
Your plan is to run around the course at constant speed.
You will not expend much energy on the down slopes, and will be working very hard going up the stairs.
Let's assume some medical/food scientist determines you will expend 1000 J of energy in one circuit of the course.
IF you were to take on food providing exactly 1000J of energy just before you started the run, you should arrive back at the Start/Finish line with exactly the same amount of energy you had just before took on the food.
(One way to ensure you ran at constant speed, would be to fill the entire circuit with people like yourself so that you were all almost touching each other. Somehow you all get moving then away you go - but remember AT CONSTANT SPEED. No slowing down on the Hills/stairs, no speeding up on the down slopes.)
If you were able to monitor your bodies energy in real time you would notice:
1. Your energy level was 1000J higher at the start (just after you ate) than at the finish. (this is like the Potential difference - sometimes foolishly called voltage - across the battery or entire circuit - a gain in Potential across the battery; a matching drop in Potential across the circuit)
2. The amount of energy you used up on the down-slopes was immeasureably small (this is like the Potential difference across the hook-up wires in a circuit - often idealised to 0 volts)
3. The greatest loss of energy occurred as you ran up the stairs (this is like the Potential Difference across the largest resistance in the circuit)
Note: if you ran too slowly, you would not use up all 1000J on a circuit. If you ran too fast you might collapse before the finish because you had no energy left. Electicity "knows" exactly how fast to run. It is not smarter than you, the Electric Field created around the circuit constantly reminds the electrons how much energy to use up at each point along the circuit (they don't go fast and slow, they just lose/use up energy at a faster rate - just as you do on the stairs compared to the flat ground).
cnh1995 said:
It is an excellent paper! Thanks for sharing @rumborak !
FYI, I found another piece of the puzzle in the Wikipedia article on the Poynting vector. There it says (and this is apparently derived in a Reitz book) that the inward-pointing of the Poynting vector at the resistor is due to Snell's law, i.e. due to the fact that the speed of light inside the resistor is significantly lower than the vacuum one:
https://en.wikipedia.org/wiki/Poynting_vector#Resistive_dissipation
Now I wonder whether the energy transfer is somehow facilitated through the same mechanism that changes c inside a solid.
I will try to get my hands on that Reitz book through my company library. This has become my personal mission now to understand. :smile:
Another good paper on this topic is this:
https://www.tu-braunschweig.de/Medien-DB/ifdn-physik/ajp000782.pdf
Dale showed me it a while back. The mathematics isn't hard at all and they provide good and accurate visual presentation unlike the paper provided above.
Good luck with what you are doing :D.
This bending effect occurs with mf and lf radio waves over 'real' ground. The poynting vector points a bit below the horizontal and maintains the signal level by directing power from parts of the wave that would spray tangentially to the horizon and keeps power near the (curved) ground. This effect is even strong enough to fill in the shadow that is formed when the wave passes over a city with many steel structures. A few km beyond the city, the signal strength is up where it should be.
Interesting!
How does that behavior change for a static EM field like in a circuit? Can you still sort of say that the field travels at the speed of light (or slower), even when it doesn't change? That is, despite it not being apparent, can you treat a static EM field to be still be traveling at c? (my hunch will be yes, as any change to it would propagate with c after all)
If the field is static then there is no change to 'propagate' at c as a wave. The frequency is zero (or at least as near zero as dammit, given a long enough time to settle down)
I was asking mostly from the viewpoint that the EM field is after all the "provider" of the energy to the resistor, and thus there seems to be a flow from the battery to the resistor, through the air. Even when not visible necessarily because it doesn't change, I guess that energy flow is still going at c.
I haven't considered this very deeply but I question how relevant the speed of light is to this particular question. Certainly, if you turn off the Power switch, the interruption would only be noticed after a time d/c. But it is not valid to talk in terms of 'individual photons' making their way around the circuit.
I could ask whether you would consider the gravitational field that is providing your weight force, is traveling at c towards the centre of the earth??:smile:
Well, it *is* a question worth asking I feel, especially when there is an energy flow associated with it like in a circuit. I mean, from a pure formula description of it, essentially nothing is happening once the EM field has been established to its steady-state value. But at the same time, we know there is energy being transported that is draining the battery and heating the resistor. *Something* seems to be traveling, likely at c, from the battery to the resistor.
Why does anything have to travel? Once you establish a ""Static field" (Force doesn't change over time, The field doesn't "evolve"). The field is everywhere, No propagation of anything happening. Energy doesn't propagate.
In a static field ( no radiation, no accelerated charges) , Then that means that the forces have to be instantaneous for momentum conservation to hold ( Isn't that right? )
What do you mean? The energy of the battery is ending up on the other end of the circuit, heating the resistor. Energy doesn't just magically appear in places, it has to travel there.
If there is no net radiation, Then that means that the forces have to be instantaneous for momentum conservation to hold ( Isn't that right?)
If the forces were instantaneous, it would obviously violate relativity. So that's a no-go right there.
*Something* is traveling from the battery to the resistor, even in steady state.
It is already there because the field is there. Energy is not an object. Wherever there is a field, energy is there too.(Limited knowledge of relativity just basics) First, we wouldn't care if it takes time or not, The field inside the conductor is constant. So how time can affect this?
Second, If you somehow have a charge moving with a constant velocity, no information can be obtained so it doesn't violate relativity?
If that was the case, and no energy would flow since "the energy is already there", the battery would never drain. Clearly, there is a flow from the battery to the resistor (I'm starting to repeat myself here).
And yes, energy *is* an object in the sense that has to abide by the same rules of transport as regular mass does. It can't travel faster than c, it has to go from A to B like any ol' other object.
I don't think you can have a static EM field, by nature it is always moving at the speed of light
don't confuse that with a static electric or magnetic field
At circuit switch on ( a DC circuit) there is a pulse of EM around the circuit. This pulse provides/impart6s the initial motion to the electrons aka charges
hence the light globe lights almost instantaneously. Once the electrons/charges are on the move, they are providing the ongoing energy to the light globe
This of course is different for an AC circuit where the EM field is always active and cycling.
I was using "EM field" as shorthand for electric and magnetic. I wasn't implying traveling waves.
But it's an odd comment to make of yours. There is no conecptual difference between a static electric/magnetic field and an EM wave other than the rate of change, right? They are just different incarnations of the same electromagnetic field.
Errrrr ... I can only presume you have not been reading the previous posts here. The very point of this discussion is that it is NOT the electrons providing the energy, but instead the Poynting vector, I.e. ExB traveling through space. That's what was mysterious to Feynman, and to me.
