Concrete and pressure no air nothing more than gravity
The discussion centers on the theoretical construction of an extremely tall concrete tower under the influence of gravity, starting from sea level. Key considerations include the gravitational effects of the tower itself, external gravitational forces, and the structural integrity of concrete under pressure. The participants emphasize the importance of calculating base crush load and the use of high-strength concrete, which has a compressive strength of 130 MPa and a density of 2400 kg/m³. The consensus suggests that the base of the tower would likely fail before the tower's gravity could significantly affect external gravitational fields.
  • Understanding of gravitational attraction equations
  • Knowledge of concrete properties, specifically high-strength concrete
  • Familiarity with base crush load calculations
  • Basic principles of structural engineering and trigonometry
  • Research the mathematical models for calculating maximum tower height using compressive strength and density of materials
  • Explore advanced structural engineering concepts related to tall structures and their foundations
  • Investigate the effects of external gravitational forces on large structures
  • Learn about the design principles of existing tall buildings, such as the Sears Tower
Structural engineers, architects, physics students, and anyone interested in the theoretical limits of building construction and material science.
mike232
So I'm looking for how tall I could make a tower of concrete, using any reinforcments, in an environment of only gravity starting at sea level. Could it get so tall it'll own gravity would effect it, the moons, or the sun's gravity, or would the bottom give out will before that?
c
What do you think? What would be the Relevant Equations/Concepts that would help you calculate this? One Relevant Equation is the gravitational attraction between two masses -- are you familiar with that equation yet? And how can you calculate under what pressure the concrete will fracture?
I have about a Jr level physics knowledge. So my guess would be that the base of the tower would give out before the towers gravity effected anything to a significant degree, but I don't know. So before I went into the math behind the material science I am hoping someone knows if just conceptually we could ever make a concrete tower that its own gravity is significant, in the described environment.
For my guess on relevant equations and stuff, probibly a lot of trig in the design on the support structure. So a lot of triangles forming polygons making framework. But I also disn't initially give a base so I guess theoretically I could have a 70 mile radius at the base and then the height would potentially be enormous. I was thinking more realistic though like a normal kind of magnitude for a tower we have made. So I guess I'm asking for the max height of a tower with the base roughly the same as the sears tower or many like a 200m base radius. But I'm more looking for gestamates like order of magnitude.
What would any external gravitational attraction do? Would it pull the tower down sideways? Would it unload the base pressure some? What is your thinking about how this would modify the base crush pressure calculation?
The Sears Tower does not use reinforced concrete for its structure. Why not?
So is this called a base crush load calculation? I was only showing a parallel in the size of the base with the sears tower, I'm taking about a 200m ish radius concrete tower, and was thinking that if the tower could be tall enough its gravity could interact with other fields and like you said cause to fall or take pressure off the base. But how can I find out if the tower could even get tall enough at that magnitude base so that I would even have to start thinking about gravity?
With a very deep foundation The Himalayas reach a few miles. Should your tower be slimmer?
A quick Google tells me:
high strength concrete has a compressive strength of 130 M Pa (Mega pascals, or Mega Newtons / square metre)
And a density of 2400 kg / m ^3
Along with 'g', you can calculate an upper limit for the tower height from these values.. (assuming a prismatic tower)
And: P = ρgh
  • · Replies 45 ·
  • · Replies 27 ·
  • · Replies 28 ·
