Condensed matter physics, area laws & LQG?
388 replies · 181K views
Tensor networks get mentioned in the abstract!
http://arxiv.org/abs/1303.1080
Time Evolution of Entanglement Entropy from Black Hole Interiors
Thomas Hartman, Juan Maldacena
(Submitted on 5 Mar 2013)
We compute the time-dependent entanglement entropy of a CFT which starts in relatively simple initial states. The initial states are the thermofield double for thermal states, dual to eternal black holes, and a particular pure state, dual to a black hole formed by gravitational collapse. The entanglement entropy grows linearly in time. This linear growth is directly related to the growth of the black hole interior measured along "nice" spatial slices. These nice slices probe the spacelike direction in the interior, at a fixed special value of the interior time. In the case of a two-dimensional CFT, we match the bulk and boundary computations of the entanglement entropy. We briefly discuss the long time behavior of various correlators, computed via classical geodesics or surfaces, and point out that their exponential decay comes about for similar reasons. We also present the time evolution of the wavefunction in the tensor network description.
http://arxiv.org/abs/1303.6716
Symmetry protected entanglement renormalization
Sukhwinder Singh, Guifre Vidal
(Submitted on 27 Mar 2013)
Entanglement renormalization is a real-space renormalization group (RG) transformation for quantum many-body systems. It generates the multi-scale entanglement renormalization ansatz (MERA), a tensor network capable of efficiently describing a large class of many-body ground states, including those of systems at a quantum critical point or with topological order. The MERA has also been proposed to be a discrete realization of the holographic principle of string theory. In this paper we propose the use of symmetric tensors as a mechanism to build a symmetry protected RG flow, and discuss two important applications of this construction. First, we argue that symmetry protected entanglement renormalization produces the proper structure of RG fixed-points, namely a fixed-point for each symmetry protected phase. Second, in the context of holography, we show that by using symmetric tensors, a global symmetry at the boundary becomes a local symmetry in the bulk, thus explicitly realizing in the MERA a characteristic feature of the AdS/CFT correspondence.
http://arxiv.org/abs/1303.6772
Renormalization of an SU(2) Tensorial Group Field Theory in Three Dimensions
Sylvain Carrozza, Daniele Oriti, Vincent Rivasseau
We address in this paper the issue of renormalizability for SU(2) Tensorial Group Field Theories (TGFT) with geometric Boulatov-type conditions in three dimensions. We prove that tensorial interactions up to degree 6 are just renormalizable without any anomaly. Our new models define the renormalizable TGFT version of the Boulatov model and provide therefore a new approach to quantum gravity in three dimensions. Among the many new technical results established in this paper are a general classification of just renormalizable models with gauge invariance condition, and in particular concerning properties of melonic graphs, the second order expansion of melonic two point subgraphs needed for wave-function renormalization.
I wonder if this is related to the line of thought in Jason Morton's work, mentioned above in #85-87.
http://arxiv.org/abs/1301.3124
Deep learning and the renormalization group
Cédric Bény
(Submitted on 14 Jan 2013 (v1), last revised 13 Mar 2013 (this version, v4))
Renormalization group (RG) methods, which model the way in which the effective behavior of a system depends on the scale at which it is observed, are key to modern condensed-matter theory and particle physics. We compare the ideas behind the RG on the one hand and deep machine learning on the other, where depth and scale play a similar role. In order to illustrate this connection, we review a recent numerical method based on the RG---the multiscale entanglement renormalization ansatz (MERA)---and show how it can be converted into a learning algorithm based on a generative hierarchical Bayesian network model. Under the assumption---common in physics---that the distribution to be learned is fully characterized by local correlations, this algorithm involves only explicit evaluation of probabilities, hence doing away with sampling.
For a comparison with standard ideas (but maybe this implementation is not so standard), how about:
http://www.cs.utexas.edu/~dana/nn.pdf
Predictive coding in the visual cortex
Rajesh P. N. Rao and Dana H. Ballard
"Lower levels operate on smaller spatial (and possibly temporal) scales, whereas higher levels estimate signal properties at larger scales because a higher-level module predicts and estimates the responses of several lower-level modules (for example, three in Fig. 1c). Thus, the effective RF size of units increases progressively until the highest level, where the RF spans the entire input image.
This is a new version of http://arxiv.org/abs/1210.6759, with a new title and new results on AdS/MERA
Holographic Geometries of one-dimensional gapped quantum systems from Tensor Network States
Javier Molina-Vilaplana
Abstract: We investigate a recent conjecture connecting the AdS/CFT correspondence and entanglement renormalization tensor network states (MERA). The proposal interprets the tensor connectivity of the MERA states associated to quantum many body systems at criticality, in terms of a dual holographic geometry which accounts for the qualitative aspects of the entanglement and the correlations in these systems. In this work, some generic features of the entanglement entropy and the two point functions in the ground state of one dimensional gapped systems are considered through a tensor network state. The tensor network is builded up as an hybrid composed by a finite number of MERA layers and a matrix product state (MPS) acting as a cap layer. Using the holographic formula for the entanglement entropy, here it is shown that an asymptotically AdS metric can be associated to the hybrid MERA-MPS state. The metric is defined by a function that manages the growth of the minimal surfaces near the capped region of the geometry. Namely, it is shown how the behaviour of the entanglement entropy and the two point correlators in the tensor network, remains consistent with a geometric computation which only depends on this function. From these observations, an explicit connection between the entanglement structure of the tensor network and the function which defines the geometry is provided.
http://arxiv.org/abs/1305.0856
The entropy of a hole in spacetime
Vijay Balasubramanian, Bartlomiej Czech, Borun D. Chowdhury, Jan de Boer
(Submitted on 3 May 2013)
We compute the gravitational entropy of 'spherical Rindler space', a time-dependent, spherically symmetric generalization of ordinary Rindler space, defined with reference to a family of observers traveling along non-parallel, accelerated trajectories. All these observers are causally disconnected from a spherical region H (a 'hole') located at the origin of Minkowski space. The entropy evaluates to S = A/4G, where A is the area of the spherical acceleration horizon, which coincides with the boundary of H. We propose that S is the entropy of entanglement between quantum gravitational degrees of freedom supporting the interior and the exterior of the sphere H.
http://arxiv.org/abs/1305.1064
On the Mutual Information between disconnected regions in AdS/CFT
(Submitted on 5 May 2013)
In this note, we compute the holographic mutual information between two separated circular regions in a 3+1 dimensional gauge theory dual to AdS$_5 \times S^5$ through the AdS/CFT correspondence, in the limit in which the separation $L$ between the regions is much larger than their sizes $a$. Our calculation uses some previous results concerning the holographic computation of the long distance correlator of two distant Wilson loops. We show that in these regimes, the holographic mutual information follows a power law decaying behaviour proportional to $\sqrt{\lambda}$ with $\lambda$ the t'Hooft coupling of the gauge theory. This result contradicts a conjectured sharp vanishing of the holographic mutual information between disjoint regions for the large separation regime and has been also compared with a recent result concerning a 3+1 dimensional free CFT.
This video appeared online yesterday:
http://pirsa.org/13050027/
Asymmetry protected emergent E8 symmetry
Speaker(s): Brian Swingle
Abstract: The E8 state of bosons is a 2+1d gapped phase of matter which has no topological entanglement entropy but has protected chiral edge states in the absence of any symmetry. This peculiar state is interesting in part because it sits at the boundary between short- and long-range entangled phases of matter. When the system is translation invariant and for special choices of parameters, the edge states form the chiral half of a 1+1d conformal field theory - an E8 level 1 Wess-Zumino-Witten model. However, in general the velocities of different edge channels are different and the system does not have conformal symmetry. We show that by considering the most general microscopic Hamiltonian, in particular by relaxing the constraint of translation invariance and adding disorder, conformal symmetry remerges in the low energy limit. The disordered fixed point has all velocities equal and is the E8 level 1 WZW model. Hence a highly entangled and highly symmetric system emerges, but only when the microscopic Hamiltonian is completely asymmetric.
Date: 06/05/2013 - 4:00 pm
http://arxiv.org/abs/1305.1045
A lattice non-perturbative definition of an SO(10) chiral gauge theory and its induced standard model
Xiao-Gang Wen
The standard model is a chiral gauge theory where the gauge fields couple to the right-hand and the left-hand fermions differently. The standard model is defined perturbatively and describes all elementary particles (except gravitons) very well. However, for a long time, we do not know if we can have a non-perturbative definition of standard model as a Hamiltonian quantum mechanical theory. In this paper, we propose a way to give a modified standard model (with 48 two-component Weyl fermions) a non-perturbative definition by embeding the modified standard model into a SO(10) chiral gauge theory and then putting the SO(10) chiral gauge theory on a 3D spatial lattice with a continuous time. Such a non-perturbatively defined standard model is a Hamiltonian quantum theory with a finite-dimensional Hilbert space for a finite space volum. Using the defining connection between gauge anomalies and the symmetry-protected topological orders, we show that any chiral gauge theory can be non-perturbatively defined by putting it on a lattice in the same dimension, as long as the chiral gauge theory is free of all anomalies.
http://arxiv.org/abs/1305.3621
Statistical Inference and String Theory
Jonathan J. Heckman
(Submitted on 15 May 2013)
In this note we expose some surprising connections between string theory and statistical inference. We consider a large collective of agents sweeping out a family of nearby statistical models for an M-dimensional manifold of statistical fitting parameters. When the agents making nearby inferences align along a d-dimensional grid, we find that the pooled probability that the collective reaches a correct inference is the partition function of a non-linear sigma model in d dimensions. Stability under perturbations to the original inference scheme requires the agents of the collective to distribute along two dimensions. Conformal invariance of the sigma model corresponds to the condition of a stable inference scheme, directly leading to the Einstein field equations for classical gravity. By summing over all possible arrangements of the agents in the collective, we reach a string theory. We also use this perspective to quantify how much an observer can hope to learn about the internal geometry of a superstring compactification. Finally, we present some brief speculative remarks on applications to the AdS/CFT correspondence and Lorentzian signature spacetimes.
http://arxiv.org/abs/1305.3908
Quantum Renormalization Group and Holography
Sung-Sik Lee
(Submitted on 16 May 2013)
Quantum renormalization group scheme provides a microscopic understanding of holography through a general mapping between the beta functions of underlying quantum field theories and the holographic actions in the bulk. We show that the Einstein gravity emerges as a long wavelength holographic description for a matrix field theory which has no other operator with finite scaling dimension except for the energy-momentum tensor. We also point out that holographic actions for general large N matrix field theories respect the inversion symmetry along the radial direction in the bulk if the beta functions of single-trace operators are gradient flows with respect to the target space metric set by the beta functions of double-trace operators.
I came across this by reading Motl's Maldacena, Susskind: any entanglement is a wormhole of a sort.
http://arxiv.org/abs/1306.0533
Cool horizons for entangled black holes
Juan Maldacena, Leonard Susskind
(Submitted on 3 Jun 2013)
General relativity contains solutions in which two distant black holes are connected through the interior via a wormhole, or Einstein-Rosen bridge. These solutions can be interpreted as maximally entangled states of two black holes that form a complex EPR pair. We suggest that similar bridges might be present for more general entangled states. In the case of entangled black holes one can formulate versions of the AMPS(S) paradoxes and resolve them. This suggests possible resolutions of the firewall paradoxes for more general situations.
Another couple of papers that draw some connections to MERA and holography:
arXiv:1306.0515
Passing through the Firewall
Erik Verlinde, Herman Verlinde
We propose that black hole information is encoded in non-local correlations between microscopic interior and exterior degrees of freedom. We give a simple qubit representation of this proposal, and show herein that for every black hole state, the apparent firewall can be removed via a universal, state independent unitary transformation. A central element in our discussion is the distinction between virtual qubits, which are in a specified vacuum state, and real qubits, that carry the free quantum information of the black hole. We outline how our proposal may be realized in AdS/CFT.
arXiv:1305.6694
Entanglement entropy in higher derivative holography
Arpan Bhattacharyya, Apratim Kaviraj, Aninda Sinha
We consider holographic entanglement entropy in higher derivative gravity theories. Recently Lewkowycz and Maldacena arXiv:1304.4926 have provided a method to derive the equations for the entangling surface from first principles. We use this method to compute the entangling surface in four derivative gravity. Certain interesting differences compared to the two derivative case are pointed out. For Gauss-Bonnet gravity, we show that in the regime where this method is applicable, the resulting equations coincide with proposals in the literature as well as with what follows from considerations of the stress tensor on the entangling surface. Finally we demonstrate that the area functional in Gauss-Bonnet holography arises as a counterterm needed to make the Euclidean action free of power law divergences.
I learned via Motl that Kenneth Wilson has died. His marriage of the long lines of work on renormalization in high energy physics with Kadanoff's critical insight in condensed matter is surely one of the great peaks of theoretical physics. Interestingly, according to Wikipedia, Steve White was his student. White invented the DMRG which was a stepping stone to the MERA.
marcus posted this intriguing paper that the boundary state in LQG is mixed! I'm not sure this is related to the concerns of this thread, but given that one way of getting a mixed state is via entanglement and a reduced density matrix, I thought I'd post it here too.
http://arxiv.org/abs/1306.5206
The boundary is mixed
Eugenio Bianchi, Hal M. Haggard, Carlo Rovelli
(Submitted on 21 Jun 2013)
We show that Oeckl's boundary formalism incorporates quantum statistical mechanics naturally, and we formulate general-covariant quantum statistical mechanics in this language. We illustrate the formalism by showing how it accounts for the Unruh effect. We observe that the distinction between pure and mixed states weakens in the general covariant context, and surmise that local gravitational processes are indivisibly statistical with no possible quantal versus probabilistic distinction.
Maldacena's talk at Strings 2013.
Entanglement and spacetime geometry
Talk: http://www.youtube.com/embed/C1NX8baM9vw
Slides: http://strings2013.sogang.ac.kr/design/default/data/juan_maldacena.pdf
On slide 25 he writes: " If one accepts very "quantum geometries" ". (Translation: if one accepts LQG;)
Let me also note the talk by Myers on RG Flows, Entanglement and Holography. It's very related to the concerns of this thread, but rather technical, so I mention it mainly because he has one LQG paper;)
What they have is a very special state (the thermofield state) where they can make a kinda/sorta/not really analogy between ER and EPR. They also argue that this holds for small perturbations away from the thermofield state. Only here do they have anything that resembles a classical geometry.
For highly quantum states (say a spin singlet system) there is no obvious classical geometry, and so if you believe the ER=EPR story, the corresponding right hand side must be described by some sort of quantum geometry, who's precise form is unknown.
http://arxiv.org/abs/1307.1132
The holographic dual of an EPR pair has a wormhole
Kristan Jensen, Andreas Karch
(Submitted on 3 Jul 2013)
We construct the holographic dual of two colored quasiparticles in maximally supersymmetric Yang-Mills theory entangled in a color singlet EPR pair. In the holographic dual the entanglement is encoded in a geometry of a non-traversable wormhole on the worldsheet of the flux tube connecting the pair. This gives a simple example supporting the recent claim by Maldacena and Susskind that EPR pairs and non-traversable wormholes are equivalent descriptions of the same physics.
http://arxiv.org/abs/1307.1367
Spacetime emergence via holographic RG flow from incompressible Navier-Stokes at the horizon
Stanislav Kuperstein, Ayan Mukhopadhyay
(Submitted on 4 Jul 2013)
We show that holographic RG flow can be defined precisely such that it corresponds to emergence of spacetime. We consider the case of pure Einstein's gravity with a negative cosmological constant in the dual hydrodynamic regime. The holographic RG flow is a system of first order differential equations for radial evolution of the energy-momentum tensor and the variables which parametrize it's phenomenological form on hypersurfaces in a foliation. The RG flow can be constructed without explicit knowledge of the bulk metric provided the hypersurface foliation is of a special kind. The bulk metric can be reconstructed once the RG flow equations are solved. We show that the full spacetime can be determined from the RG flow by requiring that the horizon fluid is a fixed point in a certain scaling limit leading to the non-relativistic incompressible Navier-Stokes dynamics. This restricts the near-horizon forms of all transport coefficients, which are thus determined independently of their asymptotic values and the RG flow can be solved uniquely. We are therefore able to recover the known boundary values of almost all transport coefficients at the first and second orders in the derivative expansion. We conjecture that the complete characterisation of the general holographic RG flow, including the choice of counterterms, might be determined from the hydrodynamic regime.
http://arxiv.org/abs/0908.0591
A condensed matter interpretation of SM fermions and gauge fields
I. Schmelzer
(Submitted on 5 Aug 2009)
We present the bundle Aff(3) x C x /(R^3), with a geometric Dirac equation on it, as a three-dimensional geometric interpretation of the SM fermions. Each C x /(R^3) describes an electroweak doublet. The Dirac equation has a doubler-free staggered spatial discretization on the lattice space Aff(3) x C (Z^3). This space allows a simple physical interpretation as a phase space of a lattice of cells in R^3. We find the SM SU(3)_c x SU(2)_L x U(1)_Y action on Aff(3) x C x /(R^3) to be a maximal anomaly-free special gauge action preserving E(3) symmetry and symplectic structure, which can be constructed using two simple types of gauge-like lattice fields: Wilson gauge fields and correction terms for lattice deformations. The lattice fermion fields we propose to quantize as low energy states of a canonical quantum theory with Z_2-degenerated vacuum state. We construct anticommuting fermion operators for the resulting Z_2-valued (spin) field theory. A metric theory of gravity compatible with this model is presented too.
http://arxiv.org/abs/1208.0206
Tensor Network and Black Hole
Hiroaki Matsueda, Masafumi Ishihara, Yoichiro Hashizume
(Submitted on 1 Aug 2012)
A tensor network formalism of thermofield dynamics is introduced. The formalism relates the original Hilbert space with its tilde space by a product of two copies of a tensor network. Then, their interface becomes an event horizon, and the logarithm of the tensor rank corresponds to the black hole entropy. Eventually, multiscale entanglement renormalization anzats (MERA) reproduces an AdS black hole at finite temperature. Our finding shows rich functionalities of MERA as efficient graphical representation of AdS/CFT correspondence.
http://arxiv.org/abs/1307.1522
Global symmetries in tensor network states: symmetric tensors versus minimal bond dimension
(Submitted on 5 Jul 2013)
Tensor networks offer a variational formalism to efficiently represent wave-functions of extended quantum many-body systems on a lattice. In a tensor network N, the dimension \chi of the bond indices that connect its tensors controls the number of variational parameters and associated computational costs. In the absence of any symmetry, the minimal bond dimension \chi^{min} required to represent a given many-body wave-function |\Psi> leads to the most compact, computationally efficient tensor network description of |\Psi>. In the presence of a global, on-site symmetry, one can use a tensor network N_{sym} made of symmetric tensors. Symmetric tensors allow to exactly preserve the symmetry and to target specific quantum numbers, while their sparse structure leads to a compact description and lowers computational costs. In this paper we explore the trade-off between using a tensor network N with minimal bond dimension \chi^{min} and a tensor network N_{sym} made of symmetric tensors, where the minimal bond dimension \chi^{min}_{sym} might be larger than \chi^{min}. We present two technical results. First, we show that in a tree tensor network, which is the most general tensor network without loops, the minimal bond dimension can always be achieved with symmetric tensors, so that \chi^{min}_{sym} = \chi^{min}. Second, we provide explicit examples of tensor networks with loops where replacing tensors with symmetric ones necessarily increases the bond dimension, so that \chi_{sym}^{min} > \chi^{min}. We further argue, however, that in some situations there are important conceptual reasons to prefer a tensor network representation with symmetric tensors (and possibly larger bond dimension) over one with minimal bond dimension.
http://arxiv.org/abs/1307.1604
Can a wormhole be interpreted as an EPR pair?
H. Nikolic
Recently, Maldacena and Susskind arXiv:1306.0533 and Jensen and Karch arXiv:1307.1132 argued that a wormhole can be interpreted as an EPR pair. We point out that a convincing justification of such an interpretation would require a quantitative evidence that correlations between two ends of the wormhole are equal to those between the members of the EPR pair. As long as the existing results do not contain such evidence, the interpretation of wormhole as an EPR pair does not seem justified.
John Preskill's Entanglement = Wormholes describes the Maldacena-Susskind ER=EPR proposal and, following a note from a commenter JM, mentions Swingle's "beautiful 2009 paper".
This paper has a fascinating result mentions both the Swingle papers and the Bianchi-Myers proposal:
I'm looking forward to Bianchi's talk at Loops 2013!
So if condensed matter systems can implement gauge/gravity duality, could experimentalists settle the firewall debate?
Interesting idea. But you would know this topic much better than me... Is there really a good condensed matter analogue for black holes? For holographic black holes? For black hole evaporation? The firewall is only supposed to exist late in the black hole's life, right?
Actually, I don't know the "real life" aspect well. Incidentally, glancing through the new version of the argument from Marolf and Polchinski, there doesn't seem to be a requirement for late time black holes any more - are they now claiming it's totally generic?
The Perimeter Institute's adverstising apparatus has an article about its http://www.perimeterinstitute.ca/node/88087. (Not sure I'd like the advertisement if I were a backhoe ...)
Some of the work described involves a collaboration between Dittrich and Martin-Benito, who are LQG folks and Erik Schnetter, who's a computational guy. The paper is Coarse graining of spin net models: dynamics of intertwiners. It's interesting compared to earlier numerical LQG work, because the amplitudes in the new spin foam models are not positive. Tensor networks were developed to overcome this problem in condensed matter physics, making simulations with fermions much more feasible. Now they've applied it to a toy version of LQG. They get the phase diagram of their toy, and also get an interesting new result: "This procedure will also reveal an unexpected fixed point, which turns out to define a new triangulation invariant vertex model."
There's also numerical work on an Ising-like model in Shenker and Stanford's Black holes and the butterfly effect. A closely related paper is Liu and Suh's Entanglement Tsunami.
Bianchi and Krasnov both gave very entertaining talks at Loops 13. Bianchi talks about spin foams and briefly mentions tensor product states in the middle of his talk, while Krasnov suggests attempting to quantize diff-invariant gauge theories by putting them on the lattice.
http://pirsa.org/13070048
Entanglement, Bekenstein-Hawking Entropy and Spinfoams
Speaker(s): Eugenio Bianchi
Abstract: I review recent developments on vacuum entanglement perturbations in perturbative quantum gravity and spinfoams, and discuss their relevance for understanding the nature of black hole entropy.
Date: 23/07/2013 - 9:45 am
Collection: Loops 13
http://pirsa.org/13070081/
Diffeomorphism Invariant Gauge Theories
Speaker(s): Kirill Krasnov
Abstract: I will describe a very large class of gauge theories that do not use any external structure such as e.g. a spacetime metric in their construction. When the gauge group is taken to be SL(2) these theories describe interacting gravitons, with GR being just a particular member of a whole family of gravity theories. Taking larger gauge groups one obtains gravity coupled to various matter systems. In particular, I will show how gravity together with Yang-Mills gauge fields arise from one and the same diffeomorphism invariant gauge theory Lagrangian. Finally, I will describe what is known about these theories quantum mechanically.
Date: 26/07/2013 - 9:45 am
http://arxiv.org/abs/1307.7738
Holography of the BTZ Black Hole, Inside and Out
Anton de la Fuente, Raman Sundrum
(Submitted on 29 Jul 2013)
We propose a CFT dual structure for quantum gravity and matter on the extended BTZ black hole, realized as a quotient of the Poincare patch of AdS3. The CFT is taken to "live" on the BTZ boundary, with components outside the horizon as well as inside the singularity, the latter containing closed timelike curves, and with different components connected by lightlike circles. Much of the paper is concerned with making concrete non-perturbative sense of these (at first sight) troubling features. After some massaging, we arrive at a simple and natural generalization of the thermal density matrix and of thermofield entanglement, to capture probes behind the horizon using specific non-local observables. Our checks include re-deriving all tree-level BTZ bulk and boundary effective field theory correlators, assuming only the standard AdS/CFT duality on the Poincare patch. This is accomplished by reanalyzing the Rindler view of standard AdS/CFT, followed by exploiting the simple quotient structure of BTZ. We study the BTZ singularity in the Poincare patch realization and show that, despite cancelations of divergences in correlators, BTZ effective field theory does break down there. Our CFT dual proposal is however manifestly UV-complete and well-defined, and clarifies the unified nature of the singularity and the horizon.
http://arxiv.org/abs/1308.0289
Are entangled particles connected by wormholes? Support for the ER=EPR conjecture from entropy inequalities
Hrant Gharibyan, Robert F. Penna
(Submitted on 1 Aug 2013)
If spacetime is built out of quantum bits, does the shape of space depend on how the bits are entangled? The ER=EPR conjecture relates the entanglement entropy of a collection of black holes to the cross sectional area of Einstein-Rosen (ER) bridges (or wormholes) connecting them. We show that the geometrical entropy of classical ER bridges satisfies the subadditivity, triangle, strong subadditivity, and CLW inequalities. These are nontrivial properties of entanglement entropy, so this is evidence for ER=EPR. We further show that the entanglement entropy associated to classical ER bridges has nonpositive interaction information. This is not a property of entanglement entropy, in general. For example, the entangled four qubit pure state |GHZ_4>=(|0000>+|1111>)/\sqrt{2} has positive interaction information, so this state cannot be described by a classical ER bridge. Large black holes with massive amounts of entanglement between them can fail to have a classical ER bridge if they are built out of |GHZ_4> states. States with nonpositive interaction information are called monogamous. We conclude that classical ER bridges require monogamous EPR correlations.
In http://arxiv.org/abs/1211.0522 and http://pirsa.org/13070048 , Eugenio Bianchi argues that black hole entropy may be due to entanglement rather than state counting.
However, that entanglement may produce thermalization in subsystems is an old idea. So perhaps the question is what is the relationship between microcanonical and canonical ensembles in "canonical typicality"?
http://arxiv.org/abs/cond-mat/9403051
Chaos and Quantum Thermalization
Mark Srednicki
http://arxiv.org/abs/cond-mat/0511091
Canonical Typicality
Sheldon Goldstein, Joel L. Lebowitz, Roderich Tumulka, Nino Zanghi
http://arxiv.org/abs/quant-ph/0511225
The foundations of statistical mechanics from entanglement: Individual states vs. averages
Sandu Popescu, Anthony J. Short, Andreas Winter
I was just rewatching the talks by Pranzetti and by Haggard which discuss things like the equivalence of von Neumann and Boltzmann entropy and the fact that boundary states are inherently mixed (no clear distinction between statistical and pure states).
Haggard's talk is based on collaboration with Eugenio--he mentions they are currently working on yet another paper. It's a lively area of research.
Pranzetti's is the first talk of the session and Haggard's follows immediately afterward (minute 20):
http://pirsa.org/13070054/
Haggard is talking about a "quantum version of the equivalence principle".
I didn't know of the Popescu et al paper, one that certainly seems relevant! The present work on foundations of statistical mechanics is aimed at a general covariant version. I'll check Popescu et al and see if they are working in a GR context.
EDIT: apparently not. What they call the "universe" (they use quotes) is a large isolated quantum system with definite energy E, distinguished time variable, and zero entropy (they assume we have perfect information about the "universe"). Still interesting though. They cite Yakir Aharonov. (Someone Bianchi has also credited in one or more of his papers. He may have cited Popescu as well, I just don't recall.)
Pranzetti's result seems sweet and mysterious - how can the Immirzi parameter be negative? 3 years ago in post #4, Physics Monkey said, "Furthermore, there are some exciting hints relating the way one computes black hole entropy in loop quantum gravity and entanglement entropy in the tensor network approach.". I believe at that time he was thinking primarily of the Ashtekar, Baez, Corichi and Krasnov state counting approach, so he was referring to a relationship between entanglement and state counting. Here's Pranzetti's paper:
http://arxiv.org/abs/1305.6714
Black hole entropy from KMS-states of quantum isolated horizons
Daniele Pranzetti
(Submitted on 29 May 2013)
By reintroducing Lorentz invariance via a complex connection formulation in canonical loop quantum gravity, we define a geometrical notion of temperature for quantum isolated horizons. Upon imposition of the reality conditions in the form of the linear simplicity constraints for an imaginary Barbero-Immirzi parameter, the exact formula for the temperature can be derived by demanding that the horizon state satisfying the boundary conditions be a KMS-state. In this way, our analysis reveals the connection between the passage to the Ashtekar self-dual variables and the thermality of the horizon. The horizon equilibrium state can then be used to compute both the von Neumann and the Boltzmann entropies. By means of a natural cut-off introduced by the topological theory on the boundary, we show that the two provide the same finite answer which allows us to recover the Bekenstein-Hawking formula in the semi-classical limit. The connection with Connes-Rovelli thermal time proposal for a general relativistic statistical mechanics is worked out.
http://arxiv.org/abs/1308.2342
Bekenstein-Hawking Entropy as Topological Entanglement Entropy
Lauren McGough, Herman Verlinde
(Submitted on 10 Aug 2013)
Black holes in 2+1 dimensions enjoy long range topological interactions similar to those of non-abelian anyon excitations in a topologically ordered medium. Using this observation, we compute the topological entanglement entropy of BTZ black holes, via the established formula S_top = log(S^a_0), with S_b^a the modular S-matrix of the Virasoro characters chi_a(tau). We find a precise match with the Bekenstein-Hawking entropy. This result adds a new twist to the relationship between quantum entanglement and the interior geometry of black holes. We generalize our result to higher spin black holes, and again find a detailed match. We comment on a possible alternative interpretation of our result in terms of boundary entropy.
http://arxiv.org/abs/quant-ph/0701002
Can EPR correlations be driven by an effective wormhole?
E. Sergio Santini
(Submitted on 30 Dec 2006)
We consider the two-particle wave function of an EPR system given by a two dimensional relativistic scalar field model. The Bohm-de Broglie interpretation is applied and the quantum potential is viewed as modifying the Minkowski geometry. In such a way singularities appear in the metric, opening the possibility, following Holland, of interpreting the EPR correlations as originated by a wormhole effective geometry, through which physical signals can propagate.
http://arxiv.org/abs/quant-ph/0701106
Might EPR particles communicate through a wormhole?
E. Sergio Santini
(Submitted on 16 Jan 2007 (v1), last revised 24 Mar 2007 (this version, v2))
We consider the two-particle wave function of an Einstein-Podolsky-Rosen system, given by a two dimensional relativistic scalar field model. The Bohm-de Broglie interpretation is applied and the quantum potential is viewed as modifying the Minkowski geometry. In this way an effective metric, which is analogous to a black hole metric in some limited region, is obtained in one case and a particular metric with singularities appears in the other case, opening the possibility, following Holland, of interpreting the EPR correlations as being originated by an effective wormhole geometry, through which the physical signals can propagate.
P. R. Holland,The Quantum Theory of Motion: An Account of the de Broglie-Bohm Causal
Interpretation of Quantum Mechanics (Cambridge University Press, Cambridge, 1993).
Another from Physicsmonkey!
http://arxiv.org/abs/1308.3234
Entanglement entropy of compressible holographic matter: loop corrections from bulk fermions
Brian Swingle, Liza Huijse, Subir Sachdev
(Submitted on 14 Aug 2013)
Entanglement entropy is a useful probe of compressible quantum matter because it can detect the existence of Fermi surfaces, both of microscopic fermionic degrees of freedom and of "hidden" gauge charged fermions. Much recent attention has focused on holographic efforts to model strongly interacting compressible matter of interest for condensed matter physics. We complete the entanglement analysis initiated in Huijse et al., Phys. Rev. B 85, 035121 (2012) (arXiv:1112.0573) and Ogawa et al., JHEP 1, 125 (2012) (arXiv:1111.1023) using the recent proposal of Faulkner et al. (arXiv:1307.2892) to analyze the entanglement entropy of the visible fermions which arises from bulk loop corrections. We find perfect agreement between holographic and field theoretic calculations.
10 pages, 4 figures
The key paper built on here is by Faulkner Lewkowycz Maldacena (2013), their reference [34].
Page 2: "Thus our results provide a very clean test of the proposed loop correction in Ref. [34]."
Incidentally they also reference [41] Bianchi Myers (2012) at one point as an earlier paper arguing along similar lines.
Page 3: "More recently still, Ref. [34] argued that the picture of quantum corrections around black hole geometries also generalized to the minimal surface situation. See also Ref. [41] for a similar earlier argument."
http://arxiv.org/abs/1301.7449
Emergent Space-time Supersymmetry at the Boundary of a Topological Phase
Tarun Grover, D. N. Sheng, Ashvin Vishwanath
In contrast to ordinary symmetries, supersymmetry interchanges bosons and fermions. Originally proposed as a symmetry of our universe, it still awaits experimental verification. Here we theoretically show that supersymmetry emerges naturally in topological superconductors, which are well-known condensed matter systems. Specifically, we argue that the quantum phase transitions at the boundary of topological superconductors in both two and three dimensions display supersymmetry when probed at long distances and times. Supersymmetry entails several experimental consequences for these systems, such as, exact relations between quantities measured in disparate experiments, and in some cases, exact knowledge of the universal critical exponents. The topological surface states themselves may be interpreted as arising from spontaneously broken supersymmetry, indicating a deep relation between topological phases and SUSY. We discuss prospects for experimental realization in films of superfluid He$_3$-B.
http://arxiv.org/abs/1308.3716
Gravitational Dynamics From Entanglement "Thermodynamics"
Nima Lashkari, Michael B. McDermott, Mark Van Raamsdonk
(Submitted on 16 Aug 2013)
In a general conformal field theory, perturbations to the vacuum state obey the relation \delta S = \delta E, where \delta S is the change in entanglement entropy of an arbitrary ball-shaped region, and \delta E is the change in ``hyperbolic'' energy of this region. In this note, we show that for holographic conformal field theories, this relation, together with the holographic connection between entanglement entropies and areas of extremal surfaces and the standard connection between the field theory stress tensor and the boundary behavior of the metric, implies that geometry dual to the perturbed state satisfies Einstein's equations expanded to linear order about pure AdS. We also provide an explicit formula for the linearized metric in terms of the set of entanglement entropies for ball-shaped regions in arbitrary Lorentz frames, making use of the hyperbolic Radon transform.
http://arxiv.org/abs/1308.3792
Entropic Counterpart of Perturbative Einstein Equation
Jyotirmoy Bhattacharya, Tadashi Takayanagi
(Submitted on 17 Aug 2013)
Entanglement entropy in a field theory, with a holographic dual, may be viewed as a quantity which encodes the diffeomorphism invariant bulk gravity dynamics. This, in particular, indicates that the bulk Einstein equations would imply some constraints for the boundary entanglement entropy. In this paper we focus on the change in entanglement entropy, for small but arbitrary fluctuations about a given state, and analyze the constraints imposed on it by the perturbative Einstein equations, linearized about the corresponding bulk state. Specifically, we consider linear fluctuations about BTZ black hole in 3 dimension, pure AdS and AdS Schwarzschild black holes in 4 dimensions and obtain a diffeomorphism invariant reformulation of linearized Einstein equation in terms of holographic entanglement entropy. We will also show that entanglement entropy for boosted subsystems provides the information about all the components of the metric with a time index.
http://arxiv.org/abs/1308.3695
Holographic EPR Pairs, Wormholes and Radiation
Mariano Chernicoff, Alberto Guijosa, Juan F. Pedraza
As evidence for the ER=EPR conjecture, it has recently been observed that the string that is holographically dual to an entangled quark-antiquark pair separating with (asymptotically) uniform acceleration has a wormhole on its worldsheet. We point out that a two-sided horizon and a wormhole actually appear for much more generic quark-antiquark trajectories, which is consistent with the fact that the members of an EPR pair need not be permanently out of causal contact. The feature that determines whether the causal structure of the string worldsheet is trivial or not turns out to be the emission of gluonic radiation by the dual quark and antiquark. In the strongly-coupled gauge theory, it is only when radiation is emitted that one obtains an unambiguous separation of the pair into entangled subsystems, and this is what is reflected on the gravity side by the existence of the worldsheet horizon.
