Conducting bar on a rail question
  • Thread starter Thread starter lovelyrwwr
    Conducting
The discussion revolves around a conducting bar placed on sloped conducting rails, with a voltage source and a perpendicular magnetic field. Participants explore the implications of Faraday's and Lenz's Laws regarding the motion of the bar when voltage is applied.
  • Participants examine the relationship between the applied voltage, induced current, and the resulting motion of the bar. Questions arise about the role of changing magnetic flux and the forces acting on the bar as it climbs the slope.
There is an ongoing exploration of the concepts involved, with some participants suggesting that the current generated by the voltage creates a magnetic field that interacts with the external magnetic field. Others question the assumptions made about the magnetic field and the forces at play, indicating a lack of consensus on the explanation of the bar's motion.
Some participants note the complexity of the topic, with references to the Lorentz force and the limitations of the current due to resistance. There is also mention of the impracticality of infinitely long rails in real-world applications.
lovelyrwwr
Disclaimer: this question is really just for my own edification in preparation for a test.
In the figure above, we have a conducting bar that is placed onto two sloped conducting rails. The box labeled V is a voltage source. Lastly there is a magnetic field starting from the "base", rising up to the top of the plane of the computer screen. So basically the B field is perpendicular to the base, which is labeled in the figure.
My question pertained to Faraday and Lenz's Law. Say the bar is set at the very bottom of the bar at f-a.
My first question is: If there is a voltage applied between points a and f, why does bar begin to climb the slope? Eventually coming to rest at an elevated point?
My logic is as follows: the current created by the voltage opposes the external magnetic field, reducing its strength somehow. According to Lenz's law, this decrease in magnetic flux must be opposed by an induced magnetic field and induced current... so the conducting bar climbs the slope to create both the induced magnetic field and induced current. And it does so by rising up the slope, increasing the area. And using the right hand rule, the direction of the current induced by the rising conducting bar would be from a-->x-->y--> f? Is this logic correct?
Disclaimer #2: The next question follows on the assumption that all of my logic above the dotted line is correct...
My second question is: which direction is the current (initiated by the voltage) going if the conducting bar is rising? My logic is that the current (initiated by the voltage) MUST be reducing the field strength, as I have explained above the dotted line. By using right-hand rule, this means that the current initiated by the voltage MUST be going from f --> y --> x --> a --> f.
Is this the correct direction and logic?
Thank you so much PF! I have been learning from yall for years! :) you guys never fail me :) this site is so helpful. I wish every subject had a site like this. Someday, I'm sure.
Letz's law needs changing magnetic flux. Your magnetic field is constant. Initially, the bar is stationary, so the loop formed by the bar and the rest of the circuit is also constant. So the flux is constant.
Even if it were not constant, the bar would not magically climb the slope. A force must act on so that it could go up. What force could that be?
What is changing is the current. It will climb until the it generates enough force to be repelled by the magnetic field. But I am not clear on why the current would not continue to build.
Right, the current is changing as .Scott said.
Since there is current due to voltage, this would mean that there is a second magnetic field created right? And say this current created a magnetic field that opposed the external magnetic field. Would this be the reason the bar rises? I mean, if the current were to create a magnetic field that opposed and decreased the strength of the external magnetic field, this would be considered magnetic flux? Is that right?
And if this IS magnetic flux, an induced magnetic field would need to exist according to Lenz's laws. My conclusion is that the rising bar creates this needed induced magnetic field. By rising up the slope, it increases the area of the circuit.
Is this right? :/ Motional emf is a subject I am very weak on. I've looked through several textbooks at the library...and still the subject is pretty scary to me!
Also to .Scott: wouldn't the current stop when the bar reaches the end of the rails?
I say that because my textbook says that this is the only reason we use rotating coils in real life, because having infinitely long rails to produce current is impractical.
yes, I think the bar does climb the slope (as long as the current is in the correct direction). But I can't think of how to explain it with Faraday's law. I think it is simpler to explain with the idea of the Lorentz force.
The passage says it definitely does climb it, but gives no explanation as to why. I think they assume I should know :/ lol
personally, I can only understand it by thinking about the Lorentz force law on a current-carrying wire. have you learned about this yet?
The current will be naturally limited by the resistance of the bar and the power supply. Anyway, Lenz's law seems irrelevant here, it says nothing about the force acting on the bar.
I also believe that the interaction with the magnetic field produced by the circuit itself should be neglected, in most lab setups the self-force on conductors is negligible. Not in a rail gun, though.
Yep. Maybe the problem has an external magnetic field that the OP has missed?
It is there :)
This problem is way over my head. :/ *white flag* I surrender. Hopefully it doesn't come up on the MCAT!
voko said:
It is there :)
oops
Have you studied the Lorentz force?
I took physics a while back and am only just refreshing before the MCAT. I remember the equation F = Eq + qvB.
Very well. Note the second term on the right hand side has charge and velocity. Can you express that as current?
qvB = IxB? Where x is distance?
yep. often you'll see it written as BIL (where L is x). You can work out the angle at which the bar will stop moving, if you also consider that there is a gravitational force downwards, and a normal force perpendicular to the rails. That is the most likely question they will ask you, I think ;)
According to the problem, the bar stops "at an elevated point" - I presume that to be short of the top. Should the current ever be interrupted by the bar reaching the end of the rails, the result would be explosive. The magnetic field would collapse and all the accumulated energy would be directed in heating the air in the conduction gap.
We're presuming that there is no resistance. That's the way these problems work.
What is happening is that the external magnetic field is actually pushing the rod back and the rail is directing it upward. There is nothing to stop the current from climbing, but the amount of force require to climb becomes greater and greater as the slope increases - eventually matching the rate at which energy can be pumped into the circuit given the inductance.
I didn't quite catch on to the whole system last night. I must be a little more awake tonight.
