Conductor Cross Section: Small vs Large Copper Wire in 9V Battery Experiment
The forum discussion centers on the performance differences between small and large copper wires in a 9V battery experiment. The small copper wire successfully powered a light, while the large copper wire failed to do so. A potential issue identified is the insulation on the large wire, possibly a clear lacquer, which may prevent electrical conductivity. Users are advised to scrape the surface of the large wire to check for insulation.
  • Basic understanding of electrical circuits
  • Knowledge of wire insulation types
  • Familiarity with copper wire specifications
  • Experience with simple electrical experiments
  • Investigate methods for removing wire insulation safely
  • Research the conductivity differences between wire gauges
  • Learn about the effects of wire insulation on electrical performance
  • Explore troubleshooting techniques for electrical circuit failures
Electronics enthusiasts, hobbyists conducting experiments with batteries, and anyone interested in understanding wire conductivity and insulation effects.
leVanw
I connected the small copper wire and the light to a 9V battery, the light came on, but when I changed to the large copper wire, the light did not light up.
Welcome to PF.
The large copper wire might be insulated with a clear layer of lacquer? See if you can remove a clear surface layer by scraping the surface with a sharp blade.
Any luck?
  • · Replies 17 ·
  • · Replies 28 ·
45K
  • · Replies 72 ·
20K
  • · Replies 22 ·
