Confused about the reactive power
Reactive power (Q) is defined as Q = UI sin(a), while apparent power (S) is S = UI. To determine the percentage of heat loss in a power grid due to reactive power with a power factor of cos(a) = 0.85, the relationship Q/S = sin²(a) is used, derived from Q = I² R sin²(a) and S = I² R. The confusion arises in knowing when to use the voltage-current relationship versus the current-resistance relationship. The first equation is applicable in voltage-based scenarios, while the second is used when analyzing power losses in resistive components. Understanding these contexts clarifies the appropriate application of each formula.
Gavroy
hey,
i am a little bit confused about the reactive power.
we defined it as
Q=UI sin(a)
and the apparent power as
S=UI
Now I have to solve this excercise:
Which percentage of heat loss in a power grid is caused by the reactive power, when the powerfactor is cos(a)=0,85?
Now I thought:
Q/S=sin(a) would be the solution
but instead of this it is said that one has to set:
Q= I² R sin²(a)
S= I² R
and therefore Q/S=sin²(a)
now my question is: when can I use Q=U I sin(a) and when do I have to use Q= I² R sin²(a)...can somebody explain this to me?
Put it in the homework section
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 76 ·
12K
