Confused about Vector direction
The discussion clarifies the terminology used in vector direction, specifically the phrases "north of east" and "east of north." "20 degrees north of east" indicates a counter-clockwise rotation from the east axis, while "20 degrees east of north" involves a clockwise rotation from the north axis. This distinction is crucial for accurately interpreting vector orientations in physics and mathematics. The explanation helps resolve confusion regarding vector direction naming conventions. Understanding these terms is essential for proper vector analysis.
Flaming Toilet
Hello everybody! First time poster here. Anyway, as the topic stated I'm confused about the naming of vector direction. For example, the difference between north of east and east of north?
Combusting Commode
20 degrees "North of east" means "20 degrees north of the east axis. Specifically: you start with the east axis (just like the positive x axis) and rotate counter-clockwise for 20 degrees.
20 degrees "east of north" means you start with the north axis (or Y axis) and rotate clockwise 20 degrees.
Likes Dng1233
Ah, I see. Thanks for your info!
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 19 ·
